CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. It would probably work best to just make it on a flat top because it'll still have alot of room underneath the arm.We put alot of these on stands & sell the that way. Bob
  2. As long as your sure the needlebar is all the way down & when you hit rev & let off the handle the LESS it moves the better,for the achine to sew & feed the best it shouldn't ove at all. Also the partr we call the bobbincase position fingeer(the part that keeps the bobbincase base from spinning) seems to work best when it's pushed back towards the back of the machine. One last thing: are you sure the hook is timed correctly?if it is too slow inotherwords if you have to much rise on the needlebar when the point of the hook comes around it'll like to jam up like it's doing. Bob
  3. Ok, here's something else to check,if you put the needle bar all the way down & hit the reverse lever does the feed dog& needlebar move or stay still? Bob
  4. Hello, Well there can be a few different things that can cause this & one is like Twinoaks says some brands of threads stick to the spool as they come off & will cause problems like this,I've actually noticed the thread from the thread stand to the machine tighten up while sewing #3on the thread stand is the hooks above directly in line with the spool?if not that'll cause this too.#3are you threading around the 2nd tension 11/2x? this can cause intermitant tension,#4 bobbin case spring sometimeswill buildup with lint from the thread & needs to be taken apart & cleaned.#5 maybe this spring has been overtightened & ruined & needs to be replaced. .HTH Bob
  5. We got a real good deal on a bucn of these machines a couple of yrs ago & ended up buying 20 of them.We had a problem with the thread catching on the feed dog,so we replaced them with another style & they worked perfect. Bob
  6. I found out a long time ago to start out with the basics.So keep me posted. Bob
  7. Double check the threading & make sure the thread is pulled down in between the tension discs & don't forget to hold on to the needle thread the first couple of stitches. HTH, Bob
  8. Good Job!! Bob
  9. to the forum.The Tippman is a good starter machine as long as you can figure out how to sew with one hand & it doesn't take up alot of room. But for alittle more$$ you can buy a real cast iron & steel machine that will last alot longer & be easier to operate since the motor will run the machine & noy your hand. Bob
  10. Both your other answers by Wiz & Art are correct,but if you DO need a tacker like that I just though I'd let you know parts are still available for it. This machine is also used for sewing belt loops on jeans. Bob
  11. Russ, Yes,we have used machines too.But not any 1541 or 206's @ this time.We do have a few 562's&563's left they are like the 1508's Bob
  12. Johnny, This type of thing has been going on for years.Probably a guy named Paul had a sewing machine biz & got this machine & stuck his name on it & then closed up or retired & that's why you can't find any info. But to be honest w/you it looks like a taiwan or chinese knockoff of a consew 226. So it shouldn't be any problem getting parts & acc if needed. HTH Bob
  13. Russ, It should sew 10oz+ w/o much trouble.We sell alot of them & they are great machines.Just make sure to get the "S" model. Bob
  14. CowboyBob
    Newbie
    to the board,I'm sure if you have any questions they will be answered,there's alot of good people here. Bob
  15. Hey Guys, A word for the wise,the 29K51,53,56 all have real small & brittle gears in them that have been obsolete over 30 yrs.I get alot of calls for people wanting gears for them & have to tell them they have a parts machine.All the upper head parts are the same as the 29K58,71,71 which have larger gears in them that you can still buy & use this for parts. Hope this helps, Bob
  16. Hello Laurie, Welcome to the board. I redo alot of old Singers & they never seem to quit sewing. Bob
  17. Dwight, Hello if you talked with someone ih Toledo that must of been me & I have a toll-free # also it's 1-866-362-7397 Hope to hear from you soon as we do have alot of machines in stock. Bob Kovar Toledo Ind Sewing Machine Sales Ltd
  18. I have a Seiko to Consew machine conversion chart & it says the Seiko LDC-8BV-1 is the same as the Consew 277RFS The largest thread they can use is a #92 & sew alittle over 1/4" of leather,they are made for binding & sewing thinner material. Bob
  19. Don't forget to make sure the thread is wrapped aound the 2nd tension 11/2x Bob
  20. It's a needlefeed walking foot with no feed dog,real similar to a 31-15 only better feeding.most parts are still available.
  21. I am. Bob
  22. I don't know of any we have sold the Alpha-Sew & alot of inmates like them & use them alot & they don't seem to have alot of problems.We also have found a way to prevent the topshaft from getting bent in shipment.It probably takes us a good hour or more to go through one & get it ready,there's alot of little things that need to be done & if you get a machine from ebay that hasn't been gone over I'm sure you'd have some issues with it. Bob
  23. Wiz, The Sailrite is just an Alpha-Sew w/a large wheel & different color paint.And they also give you a big sales pitch about it. Bob
  24. Marty, Here's a pic of our stand @ almost the highest the table top measures 44" & will go down a good 10".You would have to remove the bolts on the column & move them to different holes to go from sit to stand & adjust the chain for both the motor & foot lifter also. Bob
  25. I've been in the sewing machine biz 31yrs & haven't seen one of these yet,Does anyone have a pic they can post.Of course this machine was made in UK so maybe they never imported many. Bob
