shoepatcher
Everything posted by shoepatcher
  1. ok I have a 669eco. The 669 is the best machine in its class in the world. Only Seiko makes a copy of it and it is not as good for about the same price. i can tell you who has the best price on it. You can add a air foot lift to the 669 eco. I have done it and I can walk you thru setting it up. You can use a speed reducer on a 669 eco with a servo motor but cannot add needle positioner because the speed reducer screws with the needle positioner sensors. You can add LED lights to it. I have 2 different lights on the machine. You can sewing bindings with the machine but that means new feet, throat plate and feed dog plus the binder. You can make it a symmetrical feed binder. contact me. glenn
  2. Make sure you under cut the back of the right throat plate over the hook or will not be enough clearance for the thread to pass over the hook. Ifyou can make plates, there are guys looking for them for the 67. glenn
  3. pic please. glenn
  4. You have to grind the sides of the spring down so they do not stick out past the outside diameter of the needle bar. I assume that is what you mean by a lot of sanding. Also file down the grove in the needle bar cut out if here is a thread grove worn in it. glenn
  5. Go to Kwok Hing in Hong Kong. Good feet prices. Hooks check Cerliani and Hirose. Great aftermarket hooks. Adler # is 068-00-181-4. Hirose # is HAD-68. That Hirose hook is on eBay right now for$99.99. Grab it at that price. I have used them for years. Made in Japan. Ceriiani hooks made in Italy. Aftermarket feet are cheap for the 67 Adler. Remember, this is the small bobbin model. The 167 is the big bobbin model. Aftermarket slide plates are out there as well. glenn
  6. nice job. You get the rust off the balance wheel.
  7. Start with pics of set up and items you are sewing please. glenn
  8. Original gears were hard. Try Sitomaco.es in Madrid, Spain. Making aftermarket gears for the 29K1 and a few other parts. glenn
  9. H4 Pfaff 145,545 normally use the needle system #190 which is longer than the 134-35 system. glenn
  10. Pics will help us see it functioning. glenn
  11. How long is the belt and how many cogs are on it? glenn
  12. Pic of the machine? The brochure should tell you the max. height of the foot lift. glenn
  13. That is a pfaff drop down roller guide. glenn
  14. will try to get a pic of it for you. Sorry for the lateness. glenn
  15. Consew make a copy of this. Not sure the model #. That me be a source for replacement. glenn
  16. I have an Adler 205-370 so these feet not of use to me. Sorry glenn
  17. Put the head in the front or between the seats. Take it off the table! glenn
  18. I prefer the hollow ploy belts with the aluminum burr. Even better than the solid belts. glenn
  19. 441 feet compatible with most all 441 clones. The damn blanket foot that come on the genuine 441 is useless. Whoever designed that and it is very big and wide should be shot.! Piece of junk as far as I am concerned. Not usable on most projuects. glenn
  20. Buy a used 1341 then. glenn
  21. Hook you do not want to fool with. Anyway to lower the roller foot? glenn
  22. Can you lower the roller foot anymore so as to be tighter to the roller feed ring? glenn
  23. pull balance wheel and clean that. Looks great so far! remark all oil holes with red paint stick. glenn
  24. Also look at the Juki 2341. 3rd generation machines. glenn
  25. Not interested in buying the machine if that is what you asking.
    glenn
