shoepatcher
Everything posted by shoepatcher
can we see pics of it please. glenn
Pulling my hair out over tension issues with Consew 206rb
shoepatcher replied to Lokahi's topic in Leather Sewing Machines
two things. Looks like you are going around the pin that holds the tension discs in place. DO NOT go around the that pin. That alone will effect tension. Also, the smallest needle you can use with #138 thread is a 22/140. Do not use #21 with #138 thread on top. glenn -
Some parts from a 205-270 will fit this machine. glenn
JUKI DNU-1541 hook on vertical axis?
shoepatcher replied to palvim's topic in Leather Sewing Machines
The picture in the catalogue of the 1541 is wrong. They both look like the 1508. glenn -
what size thread are you using in American standards. I do not have a European chart for thread. If you are using #138 and below weight of thread, the 1541S should work fine. The DNU-1541/X55245 is for #207 and heavier. glenn
Just buy one of the flip down guides that is on ebay. It will work. You might have to drill and tap a hole or two. Not a big deal. I prefer the ones made by Kwok Hing. glenn
If it has toys on it, changing to a plain new servo motor will mean losing all the toys accept maybe needle positioner. want to keep the toys, get a phase converter and you may need a transformer as well. glenn
Adler 69 vs. Adler 669. Debating the New and the Old.
shoepatcher replied to nycnycdesign's topic in Leather Sewing Machines
No feet are not interchangeable! 69 uses same feet as 67,167,267, 169,269, 68, 168,268. 669 uses same feet as 767, 867,868,869. sorry. glenn -
early needles did not have a scarf. You had a long groove and a short grove where the scarf now is. glenn
i would buy all the 7-25parts listed if it was me. glenn
The air foot lift is on treadle pedal value I ordered from Universal Supply in St.Louis. It makes the treadle into an air powered foot lift by healing back. The regular foot lift you do not need with this set up. send an email that i can send video to glenn
contact Diamond Needle in NJ, the Organ distributor in the US about needles for the 52W22. your needle system is indeed 128x3 rd point, 128x4 leather point. glenn
New Dürkopp Adler 969 And 967 H Type Machines For X Heavy Work
shoepatcher replied to Trox's topic in Leather Sewing Machines
Good news. Weaver Leather now has the 969 Pure out!! This is a stripped down 969 with large balance wheel, no air lift rather foot lift. It is just like the 205 plane jane was but now it is the big brother. I believe the price complete is $5895.00 if you set up an account with them. So now the 969 Pure, the Eco and the Gold edition with all the toys. 3 price points to choose from depending on money and needs. 16.5" throat, self winding bobbin winder on front of machine, larger bobbin, one step oiling. Higher lift, bigger stitch length than 205. check it out. glenn- 79 replies
- 967 h type
- 969 h type
(and 1 more)
ok You need a stud to fit into the end of the 669 balance wheel. Weaver Leather makes this stud if you need to mount a synchronizer on the machine. No part number for the stud. If you want an air lift, the part number for the cylinder and attachment screw is #0667 135204. The manual foot lift kit is Adler part # 0367 595124. These parts come from Adler. I put an air cylinder kit on the treadle pedal which allowed me to have air lift on the treadle if my compressor is on. If not, I use the manual knee lift. I have both on my machine. Nice. Get me an email and I will make a video to send you. glenn
Durkopp Adler 239-125 Missing Oil Pan / Timing?
shoepatcher replied to machineage's topic in Leather Sewing Machines
Use a small left hand drill smaller than screw to drill a small hole in the screw. I would look for a titanium coated drill in left hand twist. The drill working in reverse may back out the screw. Be careful not to bogger up the threads in the feed bar. glenn -
Looks like a copy of a Singer 111w156. If so, the singer manual should work. glenn -
Machine is probably out of time. 196 is a double needle post machine. It has 2 hooks. each hook must be timed separately. 195 manual will work. I think I have a copy of the manual but only in hard copy. glenn
CALL Bob Kovar at Toledo sewing. You may have to have the parts made. Do you have these parts at all? glenn
Landis sewing in Arthur, IL. glenn
I would offer less money. Can he supply sewn samples to you to verify that it does indeed sew. These machines used to bring big money aka $5,000.00-7,500.00. Not so much any more. New the 767H which replaced the 221 is expensive. $, 15,000.00 plus. I would offer $3,000.00 tops. It is indeed a real Adler. Just so you know, the 3 pedal system on the bottom of the stand that works the motor, reverse, foot lift is cast , not stamped. The pedal system last time i check which was years ago was $950.00!! just for that. glenn
Bob, I just checked the original Adler sales brochure for the 220 I have and both single and double needle say 7x23needles which I am running. However, at Vaughn, used 794 in both the Single needle 221's. I think I will switch mine to the 794. Thank Bob for the heads up. glenn
Thus is an Adler 221-76-73 machine. Cooper when they were in business, would buy heads from various manufacturers and rework them for their own purposes. A lot of time, they made big clamp style programable machines with big clamp areas. This is a very good Adler and heavier than a 267, 767, 867. The next class of machine up from this as to thickness of sewing was the Adler 205-270. This has about a 1" lift and will sew with 207 and possibly 277 thread. Needle system is 7 x 23. they were used a lot in the tent, pool cover, truck tarp industry. I have it predecessor's, the 220 and mine is a 20" machine. What he is asking for it if I may ask? The screw holding the outside foot on is backwards. Nut should be on the right side of the foot, not left side.
Need help on value of a Pearson No 6 bobbin winder
shoepatcher replied to mogwild's topic in Leather Sewing Machines
Use a degreaser and cleaner to clean it up. I would pay more for an item that has been rebuilt and cleaned. glenn -
Help please: JUKI 1541 OR JUKI LU 2810
shoepatcher replied to Smithi's topic in Leather Sewing Machines
the 2810 may be made in China but it is a copy of the Adler 867 and that is the top machine period. Anything close to that is going to be good. glenn
