shoepatcher
Everything posted by shoepatcher
  1. Nope, not the same. Sorry. I would check the stud on a Seiko or Consew 744. They normally copied the Singer machines. glenn
  2. I believe there is a screw made by Seiko to screw the cover plate down so it will not move. glenn
  3. A stud from a 111W will not work? glenn
  4. Max. stitch length is 9mm. Foot lift is 20mm. that is what makes the 669 so nice. glenn
  5. I have sewn on the 69 in a couple of subclasses. great machine. However, I own a 669 eco. It is fabulous. Until about 1.5 years ago, only machine built in this class in the new generation. Seiko came out with one in 2019 i believe but not as good in that stitch length is not as long or is the lift as high. My question is what do you want to sew and what weight of thread do you want to use? Answers will determine what machine I would recommend. I can give you the differences between the machines. glenn
  6. Unusual for Eli. I would still call him. He is the leading expert on the Landis 16 right now! aaaaaaaaaaaaa Something pissed him off for sure but what? I give people 2 chances. Like James Bond said. " Once is chance, twice is coincidence, 3 times is enemy action!" Glenn
  7. Contact Eli Schalbach at Landis Sewing In Port Aurthur, IL. He rebuilds them. glenn
  8. The 2341,42 are Juki copies of the DA869. It is just like the 2810 is a copy of the 867. Juki is a very good machine. To my knowledge, the 2341,42 and the 869 are the only new 3rd generation machines out in the cylinder arm. Pfaff, Consew, Seiko and clones are not available at this time. The Juki's should be cheaper than the Adler. I sewed and worked on an 869 with all the toys for about 6 years. Hell of a machine. glenn
  9. I have bobbins that will fit this machine and I have a bunch of hooks coming in from Germany. I hope some of these are Durkopp hooks. check with me in about 2 weeks. glenn
  10. The jog dial is a super great feature of the 967, 969. So good, DA has incorporated into other new models. You can position the needle where ever you want using just your index finger. great piece of engineering. They now have the 969 Pure out which is the stripped down version of the 969 Eco. No jog dial on that one. glenn
  11. call Shoe System Plus in New York or Gateway Shoe in Illinois. Both are shoe Repair machine companies. They should have manuals on these machines. glenn
  12. That is a UFA Singer shoepatcher. Early one. Contact Horse&Harness in Ohio. They have parts for 29-4 which includes the spring tension bar. I have the parts but they are for other machines that I am rebuilding. glenn
  13. Nakajima developed the 441 in the early to mid 1980's. they also made parts for Juki as well as their own machines. Juki bought the company in he very early 1990's if i remember correctly. Their engineers went thru every machine and tweaked some things. In some cases, Juki kept the sample model number. In other cases, they change the model number completely. the Nakajimi 441 became the Juki 441! glenn
  14. Contact Luke at MJ Foley in Detroit. They are the master distributor for Juki in North America. glenn
  15. Pneumatic motors used mostly by the Amish. I would remove and replace with servo and speed reducer unless you are Amish. If not, I would then sell the pneumatic motor to he Amish. They cost more than servos. Not so noisy as the compressor is usually outside in Amish establishments. Great machine. I have one with all the toys on it. It needs a good cleaning and going over. Take your time and do it thoroughly. Bob at Toledo or Allen Burkholder at Weaver can answer any questions you may have. glenn
  16. A 7 class might work. I would contact Cerliani and Hirose and see if they make hooks for the 120 class still. That machine is still being made to order in Germany last i Knew by another company for Adler. I think it is the same one producing the 30 class shoe patchers for Adler. glenn
  17. Keep us posted please!! great job Matt!
  18. The Chandler 305-64 is a clone copy of an Adler 105-64. Chandler had these made in Japan after they lost the Adler distributing rights for AMERICA . Should thread the same as ther Adler glenn
  19. JIMI 7 PATCHERS and a mountain of boots!!!
  20. great Job 29K15engine! I have been playing with these gears and rack over the last couple of years. SItamaco in Spain has the 29K1parts made in China I believe. They are new. The drive gears, short rack, following gears, shuttle carrier and set screws are all needed today for 29-4, 29K1-33, 29K51-56machines. Other than Sitomaco, no one is making them. thee is a big need for these parts. Singer made over 250,000 29-4 machines! Gear #8608 was used in 29K1-4,10-18,21-23, 32, 33. right of of original singer parts book. I know no one is making gears for the 51-56. glenn Very nice result!!!!! glenn
