shoepatcher
Everything posted by shoepatcher
  1. That machine can sew #346 thread top and bottom and you may be able to use #415 in the top. They use at least #346 on tow straps. I have seen #415 on tow straps and probably higher weights of thread. glenn
  2. we need a video of it ? glenn
  3. I found some instruction manuals on Dixie Sewing web site. Not your exact subclass but some Model 96 manuals. They can be downloaded. Hope that helps. glenn
  4. Sounds like stich adjustment button is not engaging and disengaging when it should. It may be gummed up. I would oil in and around it to start. It may require taking the thing apart to see what the problem is. The LU563 is based on the Singer 111W155 but with big bobbin and reverse. send some pics please! glenn
  5. the parts manual is on the Consew site glenn
  6. Synchronizer should mount over stud on end of balance wheel. then tighten 2 set screws. send pics! glenn
  7. Feet are cheap. Try grinding the valley at top. If it fails, you order a new foot. Not expensive. glenn
  8. The u valley at the top of the foot can be ground out to help the foot sit flat. I have done it on occasion to poor fitting feet. The problem is this is an aftermarket part and quality is not the best at times.. What is so crazy is it does not take any more effort or money to make it right in the first place!!! glenn
  9. The walk of the feet is off. That has to be equalized for the feet to work properly glenn.
  10. Call Eli Schalbach in Aurthur, Il. at Landis. glenn
  11. yep they will glenn
  12. contact Hoffman Brothers on Chicago. They bought the whole company form Ferdco. Still producing the machines. They have parts. glenn
  13. It is the space to the right of the needle and the head of the machine. A lot of industrial sewing machines in the older generation work space was 10.5" glenn
  14. Shuttles damn near impossible to find. I hope to have them made next summer. I may have feet as well. I have bobbins that will work in a Durkopp 17-1-1. They are $1.50 each. glenn
  15. I time the bobbin case opener by hand. Remove the right slide plate. With machine threaded, turn balance wheel towards you while watching the hook pick up the the needle thread. Follow it as goes from 9:00 o'clock where it pick up thread to 12:00 o'clock. when it gets to about 5:00 0'clock should release from hook and be very close to bobbin case opener. Loosen adjustment for bobbin case opener and move it so thread just goes past the opening at the opener. Tighten adjustment. Turn balance wheel again and watch the thread as it nears bobbin case opener. Should clear it without being held up. If it does, great. If not, redo this procedure again by hand until your adjustment is good. Now turn machine on, hold the needle and bobbin thread in your hand and sew a few stitches. Should be good to go. glenn
  16. Sounds like it is not in time or safety clutch kicked out. Manual will tell you how to check the safety clutch. glenn
  17. Contact Robert Collier at Collier Equipment in Alabama and Jones Decker at Bill's Sewing in Hildabrand, NC. The can help with the parts and screws. I believe I have a service manual for that machine. Will check. Those are hard to find! glenn
  18. Will not sew anything bigger than #207 on top only. The smallest needle you can use with #138 thread is #22/140. I prefer to use #23 or #24 with #138 thread depending on what I am sewing,. The machine is jamming - could be timing, bobbin case opener set wrong or the slot on the underside of the the throat plate that the finger from the bobbin case may not be deep enough to give you the proper clearance for the thread to clear it as it goes around the hook. If that is the case, the slot on the throat plate has to be made deeper to accommodate the #138 thread. I have deepen that slot on a few machines!! glenn
  19. the 50616, ss418, 82833 no longer available. I have a replacement for the 50616 bolt. glenn
  20. No service manual for 269 sorry. glenn
  21. also check the spring i in the needle bar above the needle clamp, Machine sews good but a lot of slack in the needle thread as it enters the leather you were sewing, Spring may have a grove worn in it or be broken. glenn
  22. Bobbin case opener needs adjustment. Check your timing on the machine as well. The reverse feed is out of adjustment and has to be corrected so that it is the same as the front. Sevice manual will tell you how to do that. I will check to see if I have a 169 manual. Never saw one for a 269. glenn
  23. Consew 206 uses Singer feet. A lot of feet are available. glenn
  24. they do not put them on hook anymore. My suggestion is a drop of oil on the gib after every bobbin change. that will work. Used it in production for 7 years. glenn
  25. Spray the needle with silicon spray and see if that helps glenn
