shoepatcher
Everything posted by shoepatcher
  1. Adler 120 Class. Hard to find them. Last i knew, a company in Germany that makes the 30 class shoepatchers for Adler was still making them.. Price was over $20,000.00US.\glenn glenn
  2. Yep, I agree with Constabulary. That is a Durkopp 17- class. The length of arm will tell us one thing on the subclass, the hook and bobbin the other info on subclass. Can we see more pictures? You realize it has been more than 2 years awaiting for the pics!! I hope the next pics come quicker. Neumann probably contracted with Politype or Durkopp for this machine. Private labeling. glenn
  3. take the hook and bobbin case out and derust them with Dremel and wire brush that fits on Dremel. Check the tip of the hook for burrs. Machine will work better derusted. I mark oil areas with red paint stick. Helps when oiling machine. Clean up the buggered up screw heads as well. You got a high lift version of a 545. Great machine!!! glenn
  4. The -FA means it is set up to trim thread. Other functions may be there as well. the -263 is the designation for 2 needle but not walking foot. Probably bottom and needle feed. -273 would be the 2 needle walking foot model.
  5. The 267 gk or -373 are a good medium duty walking foot machine. Foot lift I believe is 12-13mm. It will sew up to 3/8 thickness of leather depending on how hard the leather is. These machines are in demand especially the ones built in Germany. They are going for over $2000.00 rebuilt and set up. Make sure timing belt isin good shape or that will be a $100.00 expense. glenn
  6. Look at the 969 Adler Pure that Weaver sells. 969 stripped down to basic functions. Wholesale complete, $5895.00. Like 205 but its big brother!!! I have sewed on the Eco 969 and it is a beast! glenn
  7. will try to get you a pic today. Busy as hell at the moment give me an email to send pic to. glenn
  8. Ok the Consew 733 in a lot of ways is a copy of the 7 class. What 7 subclass have you got? In a lot of cases, Consew parts may be different. You will have to check the Consew parts list. Seiko machine is like the Consew . glenn
  9. No, he means the paddle shaped spring screwed to the needle bar just above the needle clamp. glenn
  10. Use a small ratchet with a screw tip in the end. will get more leverage
  11. shuttle carrier for 29K51-56 is unique to that series. Other will not work unless you do some modifications. glenn
  12. $275.00 plus shipping. I can get you a photo. You have books on the machine? I have the parts list, operations manual and the military service book on the machine. I had one years ago in the early 1980's before the 441 and 205 came out. Does yours have the stand or just the head? Mine had everything glenn
  13. Glad you got it to work. That has a huge flywheel added to it!!! glenn
  14. I have a brand new race for a 97-10 never used. glenn
  15. Bottom line-the drive gear, following gear, long drive rack , short rack, shuttle carrier are probably all worn not counting the wear on the inside of the horn. All contribute to the the missing of stitches. Keep in mind, these machines are over 100 years old and counting. If parts can be found, they need to be replaced. Finding them is not easy. I have a few parts and a few companies in Italy and Spain are making or have replacement parts. The original parts should be removed and examined for wear. Any model before the 29K58 will have certain parts that are hard to find. 29K58 and on, there are generic parts made for the machines because of the clones made today in China. OK the companies that has parts for 29K1-4 Italy www.brunoanichi.it Spain www.Sitomaco.es I have been on there sites in Italian and Spanish. No English on the site that I can see. Hope this helps
  16. Ok. Strima in Poland has a genuine for $272.03, AliExpress has a generic for $43.68. I suggest you call DAP in Atlanta which is Durkopp/Adler/Pfaff and see what a genuine hook cost and if they have it. That gives you a starting point as to price. Shipping not included in these prices glenn
  17. Do you have a parts list for the 345? I have one. A genuine hook will not be cheap. Part number is #91-014-192-31. A genuine hook if you an get it would cost over $300.00 Hirose and Cerliani both make aftermarket hooks. Very good quality. Used them for years. I will see what I can find and get back to. Can we get a few pics of the machine. glenn
  18. 29K60 really like the 29K72 which replaced it. A few parts are different but that is all. glenn
  19. Call Henderson Sewing and talk to them Lots of experience with Union Specials. glenn
  20. Your machine is a extra long high post version of a 68-72. Feet, hooks and a lot more from the 68-72 will fit your machine. Judging from the color of the machine, it was made in the 1980's. However, could be earlier as it might have been repainted. glenn
  21. pics will help I believe the Consew 733 and Seiko machines use the same feet. Call C.H. Holderby in Seattle. They deal in lots of industrial machines. glenn
  22. No the bobbin case opener is near the hook and it regulates the opening and closing of the thread as it flows around the hook. Get me a pic of your hook area. glenn
  23. WE used 2 of these machines in production. #138 top and bottom. Use #23 needles. The smallest needle you can use with #138 is #22/140. I prefer #23/160 needles . Less defection and the thread flows better thru the eyelet. We also used Organ or G-B titanium needles and they work better than the chrome plated Schmetz needles. In tensions discs on your machine, the most bottom one is the primary, the next up is the secondary and the top on is the auxiliary one. I used the bottom one the most to tight or loosen the the top thread tension. Also check the bobbin base opener to make sure it is not hold up the bobbin thread. glenn
