shoepatcher
Everything posted by shoepatcher
  1. It should be the same as a front plate used on a Singer111W155. Consew copied that machine when they designed the 226. glenn
  2. Contact Weaver Leather and as to speak to Allen Burkholder. He has worked on these machines for over 25 years and is probably the best mechanic on them in America. He can walk you thru the timing. glenn
  3. Backlash springs work no matter how fast you are sewing. I use one in my Juki 1508 and it does make a difference despite some earlier comments. We used them in all our 767 and 867 Adler's. They do help. Cheap to try. glenn
  4. Some companies paints are available from dealers. I might give Consew a buzz in NY to see if they carry anything. The silver grey hammertones were built by Seiko for Consew. Try Hoffman Brothers in Chicago. Primary Seiko dealer and distributor in the US. glenn
  5. Plates are not that expensive and I think they are still available. I would order that and the 2 screws to attached. Plus, if you decide to sell the machine down the road, it has the original plate on it, not some thing you made to just get by. glenn
  6. I just sent you an email. Disregard it. I have only seen on Claes with a foot lift and that took some time to set it up but it was nice.
  7. John I set them up on an off the arm stand with a servo motor and speed reducer. I can text you some pics if you would like to see it. What are you planning on sewing with the machine? You are missing the spool pin and thread holder that is below the bobbin winder. Can you send me a pic or two of the back of the machine. It looks like you have the zigzag attachment on it. sorry for the late reply. Computer been down for two weeks and no WIFI too boot. glenn
  8. Just so you know, the tip of the needle, feed dog and inner presser foot should reach the top of the throat plate all at the same time. In your machine, the tip of the needle is way late. That adjustment needs to be made. The feed dog looks like it is coming up a little to high. Feed dog should never rise more than the bottom of the teeth are above the top of the throat plate. glenn
  9. There has to be a timing issue of some type here. Thread should not be that tight. Post a few pics of the machine and a video if you can of the machine sewing. glenn
  10. sounds like the old hook and bobbin that used to be in the Pfaff335 before they came out with the 335-G which has the larger bobbin. Hockey mender and I have switched out the old hook for the larger G bobbin size hook with no problem. Send us some pics of the hook and bobbin in the Yamata.
  11. Synchronizer plug installed. Synchronizer installed and working fine. glenn
  12. Never have seen a places to get System#88 needles in size 90. What are you sewing that you need a needle so small? glenn
  13. Don't forget me cdthayer! glenn
  14. Go for it. Just be careful not to disassemble it to much. If it is a 111W153, there should be three shafts counting the needle bar. I only see one. There is a army manual out there on this machine you should get a copy of before you disassemble the head. Much more info than any Singer manual. Written for the military during WWII. glenn
  15. Call the company you ordered it from and get a replacement part. That is due to the shipping of the item and it got bent. If they will not back the part, you probably can bend it back in a vice but first must remove from machine and tap it lightly with a rubber or plastic hammer being very careful not to break the support as you bend it back. glenn
  16. You can use lubricated polyester in the Landis 3 DESPITE what other sewers say. They use both linen and polyester thread in curved needles so sew on soles of shoes. You will have to try both to see what woks best for you.
  17. OH my God. Sorry to hear such sad news. Do you have telephone number for her? glenn
  18. Keith Palmer out of South Dakota is considered the expert on that machine! glenn
  19. shoe machines for sure Landis or McKay machines. Contact Gateway in St. Louis or Shoe Systems Plus in New York. glenn
  20. Mikesc, What do you use to clean machines in France? I am curious! I would like to know. I have rebuilt sewing machines for over 30 years. I have used all kinds of chemicals from brake cleaner to Carburetor cleaner to paint thinner to kerosene to parts cleaner. You name it. Most petroleum based cleaners may etch paint and they are not good for you either. What is available in the US may not be available in France. That does not make it bad however. Most of the time you are dealing with old grease, oil, dirt, rust and who knows what. They key is getting something that works and is not harmful to you or the machine.
  21. I would use Greased Lighting. It is great for removing grease and oil and it is water based, not petroleum based. glenn
  22. Damn. It is an early Pfaff 335 and has only a 4 mm stitch length max. That means the 6mm stitch length on the model plate number should read 6n for a 6mm max. stitch length. I was wrong. This old girl is going to need a massive clean on to get it back to good sewing status. Be prepared to do that. glenn
  23. Grease on the gears is good. Oiling everything is good to start. The cams should have a very fine grease on them because oil will run off. Sends us some pics so we can see the machine. Is it a #20 or #30? glenn
  24. dtklunk, Early Pfaff 335's had only a 4 mm stitch length max. I think yours is 6mm because of the N in the model plate. Send us a pic of the reverse lever and the plate behind it. H3 so 11mm lift of foot, B means a B class which is for lighter material, S for cloth. No M which is safety clutch, no P for 4 motion drop feed. She is dirty. I would go thru and clean it up, check for worn parts and even repaint it.. But that's me. glenn
  25. You would have to find a flip down roller guide for a singer 111W155 which I do not know if they ever made one. Todays flip down guide will work but it means drilling and tapping I am afraid. glenn
