shoepatcher
Everything posted by shoepatcher
  1. Send us a few pics of the machine. It is probably a clone of a name brand. that way, we may be able to get you a manual. glenn
  2. Setting the stitch length to the correct length of stitch is not that hard. There are two set screws in the stitch length indicator wheel. Loosen both screws and you can rotate the stitch length wheel. Set the machine itself to 5 stitches per inch. Then loosen the wheel and rotate until the number 5 shows up in the hole indicator. Now the stitch length will correspond to the number in the hole indicator. That number may not be true so always check your stitch length on scrap. The Singer 111W152-157 were all walking foot machines. Fun to work on. glenn
  3. I would buy the Pfaff. Generally speaking, it usually is a smoother machine. If you can sew on it before purchasing, do so. I have had Adler, Pfaff, Juki and Singer. I still believe the Pfaff are the smoothest machines. Bobbins are the same size in the Pfaff and Singer machines, bigger in the Consew 206. The ultimate choice is yours. If you get the Consew, that means getting a table, stand, motor, drawer, thread stand and light. More money there. Just my opinion. glenn
  4. Grey. That was probably the original color. I always try to match the originally color when restoring a machine. glenn
  5. It has to do with restoring the "figure 8" on the end of the bell crank. The lobes wear down on each side and that causes the stitch length to shorten. If someone is a competent welder, the lobes can be welded up with a Tig or Mig Welder and reground with a Dremel and you are almost good as new. I have 30 plus bell cranks from Adler and Singers that have to be welded and reground on the lobes. That is a project for when I retire. That is normally the only thing to go wrong with a used bell crank. glenn
  6. Check out Miami Sewing machine web page. The have a lot of reconditioned and rebuilt machines and are in Florida. glenn
  7. This machine looks like it had trimmers for thread cutting at one time. Uwe, like you, I believe somethings are not quite right on this machine. glenn
  8. Like a Pfaff 1245, the 545 will sew a maximum thread of #207 top, MAYBE in bobbin as well. I always used #207 on top, #138 on the bottom. The maximum lift of a H4 High lift machine is 14mm. You could probably sew up to 3/8" thick of leather but that is a softer leather like chrome tan, not veg tan. That machine will handle #24 needle no problem. I have sewed with #46 thread and down to a #16 needle. Hope that helps. glenn
  9. ObjectMaker. Call Ryan at Neal's Saddlery because he may be closer to you than Bob at Toledo Sewing. Ryan is the importer for the Cowboy brand of sewing machines and he may have something for you. I would look at the 3200 machine that he carries. Both men are great to deal with. Take samples if you are going to test items you will be sewing. glenn
  10. Bonding on thread is a clear polyurethane that locks the spun fibers into a much stronger bond for sewing. If you have ever stitched with non-bonded thread, you will know what I mean. No nearly the strength and it frays like crazy. I simply do not use it. Only used in certain applications where the thread might be stronger than the material you are sewing. Trust me, always use bonded thread whenever possible. glenn
  11. I would also check the to see if the feeding is the same on the inner and outer presser foot. Sometimes, one foot is slight off, i.e. one foot rises higher than the other which can make a difference in stitch length. glenn
  12. Chayse, With the threads at 3/16" x32, you should be able to find grade 8 bolt on line that you can cut an make a spool pin out of. I know I could make a hell of a lot of spool pins for $97.00! As to the tension assembly, you need to determine what the threads are on the tension assembly stud. I believe Consew made a copy of the 305-64. Maybe a 754 model bracket. I know I have seen clones out there somewhere. glenn
  13. This Chandler 305-64 was made in Japan after Chandler, which had been the Adler distributor in America lost that distributorship. They went to Japan and had the machine knocked off. It is a copy of a Adler 105-64. As to the missing spool pin on top, you should be able to get one from Bob at Toledo. Probably get you one from a Cowboy. I believe this pin is only a pressure fit and not threaded. Hope that helps. glenn
  14. Catskin, I just saw the manual you got on an earlier post. That is a Fipi side arm clicker. Contact Manufactures supplies in Missouri. They can help you. glenn
  15. Catskin, Been a while. You can get a 5 horse rotary phase converter from Grizzly Tools for 995.00 plus shipping. 1-8005234777. That should be more that plenty for your machine. Want to see pics when it is finished. glenn
  16. Clicker beds are rarely wood anymore. Most companies have gone to Polypropylene. They come in different colors which correspond to the hardness. leather us usually cut on the red boards which is about a68 on the harness scale. We use the white boards at work. it is a little harder because we cut foam, plastic and carbon fiber. You can get different thickness. If you need a thick board over 2", they can be glued to plywood. Contact Manufacturers Supplies in Missouri. They sell clickers and boards. glenn
  17. Catskin, From an earlier post, I think that is either a Fipi or Atom. Contact Manufacturers Supplies in Missouri. They should have a manual. glenn
  18. With a budget of 2k, you could get two machines. One would be in the Consew 206 class or clone, and then a higher speed drop feed machine for linings say Juki 5550. If picking them up, you would have change left over even buying the two machines. Just a thought but the two machines would be more versatile then trying to find one to do it all. Just my 2 cents. glenn
  19. Juki 245 and 246 are the equivalent to a Pfaff 335 and they are made in Japan or in China for Juki. Should be cheaper than a Pfaff 335. glenn
  20. On this Adler 205, to set the needle bar to the correct height with a 794 needle which is the correct needle system, you measure from the very bottom of the needle bar to the bottom of the oil holder which is the black plastic cover piece that the needle bar comes out of above the feet. That distance should be 44mm. This sets the correct height of the needle bar. Having done that, you then go under the arm and loosen the collar that holds together the bottom main shaft that drives the shuttle driver. You then time the hook having loosen the collar to the needle in the needle bar as described by Uwe above. This is from Allen at Weaver who has worked on these machines for over 20 years. I have used this system to correct and time the 4 205's we have at my plant. Hope this helps. glenn
  21. The Adler 221 replaced the Adler 220. We have two 221 Adler here at the plant, one 20", one 30". I have a 20" Adler 220 at my home and I feel it is a better machine than the 221. I also have a Singer 144A204. Singer never had Adler make any 144W's for them, they were all 144A models. The "A" standing for Adler. These machines were Adler 220's in everything but name and paint color. I have also never been able to find a service manual for the 220, The 221 manual will work fine. These machines use a 7x23needle system. The stitch length dial can be adjusted on the main shaft to correspond to the correct length. Should be a screw to adjust the wheel the stitch length is on. glenn
  22. Very Nice job so far trash treasure. Love to see it when it is done!!!!! glenn
  23. Just keep the wick moist in the oil reservoir. When you are not sewing and the machine is at rest, put a paper towel or napkin under the feet. That will tell you how much oil is flowing out of the wick and you can adjust the amount of oil you put in the reservoir accordingly. We do that at our plant especially on Friday when the shift is over. They are checked on Monday before the operators begin their shift. glenn
  24. Woodonglass, Send us a few pics so we can the machine. That may help in identifying why it will not work. A video would also help. glenn
  25. mixmkr, That setup should keep the thread in the tension discs. I have used that on numerous machines over the years. Machine looks nice! glenn
