shoepatcher
Everything posted by shoepatcher
  1. AngieNZ, The 29U173A was built in Japan. Some of the parts or slightly different in spec sizes compared to the parts for a Singer 29K73 and 29K173. They went to metric sizing on some items and they are definitely different. glenn
  2. Jeff,
    Did you end up selling the lot that was posted in March or did you piece meal it?
    glenn
  3. C, Singer introduced the cam adjustment screw for the shuttle on the 29K51 series which I think came out in 1923. Up till then, all the 29-1thru 5 and the early 29k1-33 only had the long drive rack on the bottom with no adjustment. Glenn
  4. Send pics so we can see what she looks like! glenn
  5. There are machines with feet for ruffling. A lot of time machines will have a differential feed in that the upper feed and lower feed can be changed so that they are not the same. The Singer 144W304 comes to mind. You can change the amount of difference in the upper and lower feed. glenn
  6. Eddieb, They do make pedals for stand up operations. What motor you choose will help determine a stand up pedal. Where are you located? This will also help to recommend a dealer or place to purchase the servo motor. glenn
  7. Please us the foot from the side and front as well so we can help identify it. glenn
  8. You can but it also requires a different take up lever and some other adjustments. Not a quick change. glenn
  9. I have seen a few of the factory electrified machines. This one has a slightly different motor however with a different clutch on it. Any Singer number or identification on the motor? The table does not have the cast extension piece on the back that Singer came up with to mount the motor. I would say it is not a factory issued set up. However, still could be a Singer motor. I would like to see more pics of the motor. It has the hub and shaft for a front mount wheel which I would change the balance wheel to. Part of the take up adjustment is missing. glenn
  10. Man, that looks nice! Great job on the table. Might consider making them to sell? glenn
  11. Nuttish, I am not seeing a bobbin case opener in the picture. It may be there but I do not see it in the picture. Give us a few more pics of the bobbin case area without the flip down guide. glenn
  12. jshep, You want to use 3L v-belts. The length of the belt you will have to determine from machine to motor. 3l belts fit the pulleys on sewing machines very well. You can get them from Sewing Machine Dealers or from Automotive stores. once you know the size, i.e. 38" or 39" etc. glenn
  13. Sends us some pictures once you have the original parts back in. Make sure they are close ups. This will tell us a lot and then we can make specific suggestions to you and how to fix it. glenn
  14. Send pics of what you have once the original parts are back in. We can suggest things but pics will tell us a lot! glenn
  15. It looks like you missed the thread into the take up spring but that will not effect the needle picking up the bobbin thread. The safety clutch might have gone out. It is the silver button on the base part of the arm which is on the right side. Take out bobbin and unthread needle. Press button down and turn balance wheel towards you until your hear a click.. If you hear the click, safety clutch has reengaged. If not, it probably was not the safety clutch. That leaves timing and a trip back to the dealer. glenn
  16. C, To my knowledge, the only short arm that Singer ever made with the large hook was the 29U171 which was made in Japan in the late 70's. It looked a little different than any other Singer shoepatcher. I have an original brochure on the machine. glenn
  17. C, The side wheel was on some of the subclass up to the 29k51-56. After that, the front wheel mount was an extra charge, not standard. Machines might have the front bub, but not the shaft and gear. The 29K70 came out after the 29k58,60 and 62 series. It came out only on its own. Don't know why. It was replaced by the 29K71 which was part of the 29K72 and 29K73 which was a series . very few parts changed in that series compared to the 58,60,62 series. glenn
  18. Jerseyfirefighter, Used hydraulic clickers usually start at about $3000.00 and up. Their is someone in New Jersey that sells used machines. I will try to find their info and get it to you. glenn
  19. Proleptic is the publisher of Shop Talk. They are in Ashville, NC. Ask for Dan Preston who owns it. glenn
  20. -H-3 means 11mm lift, H4 would be the high lift version at 14mm L- leather machine C- class. the D lass is the heaviest and has the largest diameter balance wheel P- means 4 motion drop feed N- means maximum 6 mm stitch length as does the 6 in the model number M- safety clutch not sure on the 1A glenn
  21. MadMax22, that 145 can definitely restored. What is the sub class on the brass plate? glenn
  22. we need pics of the machine!!! glenn
  23. Al,
    No real reason to separate the head form the arm, even for painting.  Those bolts are usually very tight, almost like lock tight.  As to paint, you might try a heat lamp on the machine after you have painted it.  Cheaper than sending it out.
    I would just spray can it with black lacquer once you have primed it real good with a sandable heavy primer.  Make sure if you use black lacquer after you prime it that the lacquer will not lift or bubble your primer.   test it on something.  If it does, use black  gloss enamel , then clear coat over it after you have applied any decals
    glenn
    1. Evo160K
      Evo160K
      Thanks Glenn, I appreciate your support and advise.  Your help has been invaluable..  I'm going to do what you say if I can't perfect the japanning.  I've been experimenting with a couple of recipes, and actually I'm baking two small cast iron parts as I type, want to see how hard the japanning is when it cools.  Thanks again Glenn.
  24. Yes, that table is not for the Pfaff. It looks like the table was set up for some kind of serger or overcast machine. In todays world, you would want to replace the clutch motor with a servo motor for better speed control. The Pfaff 483 would sew light leather and vinyl. To make the machine work would require a new table top and motor. I would look at buying a walking foot machine , say a Consew 206 new because of the expense you would have to get this one up and running plus the 206 will sew heavier. JMHO. glenn
  25. Depending on the shape it's in, i.e. the table, type of motor, is it a 229 or 229R which has reverse, I would say it should sell for at least $800.00 and go up from there. glenn
