shoepatcher
Everything posted by shoepatcher
Dürkopp 18 Patcher Restoration - long journey...
shoepatcher replied to Constabulary's topic in Leather Sewing Machines
Black Dogg. Can I see some pics of your machine? I have 5 of them to restore. glenn -
The Juki 2810 is a copy of the Adler 867 with cost saving of about 25--33% over the cost of the Adler. What I have seen of it, great machine. Yet to sew on one but have looked at them at MJ Foley which is the largest Juki dealer in the US. Bigger machine , longer throat, higher lift, new bobbin winder system, central lubrication. New generation machine over the 1508 and the 2210. I believe if you get the 2810-7 which has the toys, cost is around $5,200.00. The Adler 867 with toys is over $7,000.00 You do the math. glenn
Uwe is right. This is an Adler 220-76-73 which is a 30" single needle long arm. Great machine. Singer contracted with Adler to build the 144A305 which was a 220-76-73 with the Singer name and model number on it. These machines were $7,000.00 plus. A very good price today in America would be anything under $2,000.00 I have a 220-50-73 which is the 20" machine and it cost me $4,000.00 rebuilt head only in 1998. Great machines for sewing truck covers, outdoor furniture, tarps and canvas. Not to good for leather. They are built like tanks and better than the Singer 144W's.
Anyone have experience with THOR sewing machines out of Texas??? glenn
What parts are you looking for? I may have a source. glenn
Raised needle plate for a Juki 246?
shoepatcher replied to Matt S's topic in Leather Sewing Machines
Plate may have to be custom made. Let me know if you need info on people that do this. Sorry for the late response. glenn -
Also, Look at the Durkopp Adler 768 which preceded the 868. they could sew up to #207 thread. glenn
Opinions on new Patch/Shoe Machines
shoepatcher replied to sjharumph's topic in Leather Sewing Machines
Having worked on most of them, the best shoepatcher made is the Claes. It has superior engineering and Claes has made shoepatchers since about 1869! They are not cheap but they go and go and go. A new Adler cost almost as much as a Claes. No one has tried to Clone the machine. If I was 20 years younger, I would have sent it to China to be knocked off. Great machine. Biggest drawback is the price. However, still a shoe patcher and there is know way it is worth $5000.00 for the head. Hell, an original Adler 205 head was about $5,000.00 and that was so much more machine both in sewing capacities and what was involved to manufacturer it. Claes is not built in large numbers and that is one reason they cost so much. If you are going to use shoepatchers a lot, look at the Claes. You will not be disappointed with the machine. glenn -
Hand Crank Mechanism for Singer 29-4
shoepatcher replied to micktx's topic in Leather Sewing Machines
I believe the 29-4 does not have the front tooth cam gear that is bolted to the top shaft. It has the back half of the gear that the pitman arm fits in but not the forward section that the short shaft gear mates to drive the front mounted shaft that comes thru the hub. Some of the early 29K's had the front mounted shaft on certain models but not the 29-4. Changing means pulling the top shaft plus the bub will not mount to the casting because of a different face plate. glenn -
Manual/Literature for Claes 8345/43
shoepatcher replied to HatoriKun's topic in Leather Sewing Machines
Contact Constabulary. He found a service manual for the Claes 8346 machine while getting me a machine. He sent me the manual but I made sure he made a copy for himself. First service manual I have seen for a Claes shoepatcher in over 30 years of working on machines. It is nice. glenn -
the pin and spring were used to keep the slide plate from coming completely out. No big deal. Singer used them as well on the 111W155.
Singer only made about 40 some of these 67-1 machines. I have seen 2 of them in Ohio and they are monsters, bigger than a 5 class. Both machines are huge. The 5 class shown in the pictures has a S.D.A. on it which stood for Singer driving attachment. They were run on line shaft and the SDA is what you engaged the machine with on the drive belt. The 5-9 is indeed a big zigzag machine. The 8 class is smaller than the 5 class machine. Both are smaller than the 67-1. If you want to see the biggest machine Singer ever made, look up the 9-1 machine. That was truly a monster. glenn
Great. These are good machines when up and running. Do you have the manuals for the machine? glenn
This is a Monster. One of the biggest machines Singer ever made. Bigger than a 6 class, 7 class , 8 class. Not as big as a 9 class which was THE largest machine Singer ever made. I would buy if I had it available 5-1and rebuild it just to have it. You will definitely need help moving it. Please get us more pics of it especially if you get it. I have an original parts list book to 5-1vto 5-5, 5-7, 5-10 to 5-11. Not the 5-9 however. Is this a zig-zag machine? glenn
Weaver Leather sells it wholesale ( sales tax license needed) about $3800.00
The 669 is a new generation of this design. It has a longer throat of 13" vs. 10.5", foot lift of 20mm vs. 13mm, and max stitch length of 9mm vs. 6mm. I am getting this machine in 201. More money but way more features that are for the better. Juki's new generation only has the 2341 which is like the 869. They do not make a narrow arm machine in this new generation. Pfaff made one for a while like the 669 in their Powerline series but later dropped it. Weaver Leither has the heads in stock in the ergo series. glenn
They make generic needle bars that come with the set screw for the needle. The lower thread guide is either a slot or hole cut into the needle bar. I would replace the needle bar. Despite what people tell you, there are a good number of generic bars available that are not to bad as to price. If you need genuine parts, be prepared to pay. Any screws that are "boogered up", sand and clean up or replace. Be sure to get an extra needle set screw or two because they do wear out. I recently broke the needle set screw on my Pfaff 335 and went to replace. I go into the drawer and low and behold, no extra needle set screw. I order 8 of them that day because the 545, 335, 345, 1295 and 1245 all use the same set screw for the needle. I got both genuine and generic to see which is better. The genuine was $1.18 each, the generic was $.88 each. Not a lot of money for peace of mind. To many people on this board do not keep extra parts or screws on hand until they need them. Not me. Time not sewing is money. My advice to you once you get this machine up and running is stock a few parts. Keep the pics coming so we can follow the progress on this baby! glenn
I would go with the typical tw- 341 which is a Juki l 341 clone. It is a heavier machine but will sew heavier, longer stitch length and is a vertical hook I believe. glenn
Thanks
Still has compound feeThis is the heaviest version of the 545 made. H4 high lift. Subclass D which means largest, heaviest hand wheel. In the model number the letters mean L which is for leather, M means safety clutch. N means maximum 6mm stitch length. This model has no P in the subclass which is for 4-motion drop feed. You do not have it. Rather it has compound feed but the feeding is more of a skip stitch back and forth This is used a lot in binding. Hope that helps. Clean her up, replace any worn screws or parts, slide plates, etc. Still has compound feed and a walking foot. You have a great machine there. glenn
Can you send me a few pics of the light sewing machines to?
Big Sioux, Thanks. Will keep you posted on other info I get. glenn
Thank you. glenn
A Singer Patcher, But not a 29K....?
shoepatcher replied to alexitbe's topic in Leather Sewing Machines
This is either a U.F.A. machine or the early 29s'. Singer went from letters to numbers for model numbers in 1896. The 29 and 29-1 had the arm on top and the 29-2 was the first Singer patcher to have the rack on top. I would buy the machine since it is an early one and the decals are in great shape. Make a fine conversation piece and probably still works. glenn -
Taking TK-8BL Sewing Machine
shoepatcher replied to RhodesAveDesigns's topic in Leather Sewing Machines
That is a clone of a Consew 206RB or Seiko STH-8BL. Parts and the timing belts should be the same. Send us a few more pics. glenn
