shoepatcher
Everything posted by shoepatcher
  1. Don't blame you. I have a few suppliers I don't give their names out either. glenn
  2. Remember , if you set up for one make 5. Most of the cost in machining is set up and there are guys looking for parts all the time. glenn
  3. Where did you get them? glenn
  4. Most of those machines will sew up to about 3/8" leather. Depends how hard the leather is. I might have recommended Miami Sewing machine but not anymore. I would call Bob Kovar at Toledo Sewing and pick his brain. He has a number of machines he can recommend. glenn
  5. Genuine contact MJ Foley in Detroit. largest Juki dealer in America. Generic Bob Kovar at Toledo Sewing or Steve at Cobra in California.
  6. The adjustment on the back of the flat tension spring is set at its lowest position meaning that foot has almost lift. As Folker stated, Loosen the wing nut and move the block clamp to the left like in Folker's pic. That will raise the walk height of the foot. A lift lever from a 29-4 machine should fit yours. glenn
  7. A 29K3 is a lot like a 29-4 in that it has a solid horn. The problem with these machines is the area in the horn around the bobbin case wears and the only way to fix it was an insert put into the bobbin case area that took up the wear. I looked at doing this years ago and then the clones came out so why bother. The other problem as Folker mentioned was this: there was no adjustments to take up the wear on the parts. Once they wore, you had to replace them. With Pilgrim Shoe no longer in business, the source for parts for these early model machines has dried up i.e., pinions, needle plates, screws, etc. glenn
  8. The one thing you forgot to mention is what weight of thread you be sewing with. That has a baring on which machine to get. glenn
  9. That looks like a copy of a singer 211. Maximum thickness to sew would be about 3/8". These machines were designed for the auto industry upholstery and seat covers. maximum stitch length was 5-5.5mm. glenn
  10. I prefer to use round needles on soft leather. That's just me. Wiz might have better insight for you on that question. glenn
  11. I forgot to tell you I have drawers for your Singer stand. I had then made here in the US by an Amish drawer maker. These are to the original specs, dovetailed and unfinished so you can either seal or stain it. Your choice. glenn
  12. Steve, I wish I had known you were looking for parts. I have most of the parts you are seeking as well as the original stands for Adlers. You can use big bobbin hook and bobbins from Singer big bobbin machines. I new genuine hook from Adler is about $234.00 and change. Generic Singer hooks will work in this machine. A lot of pats for the 30-1, 5, 7, 15 are no longer available. Let me know if I can be of any assistance. glenn
  13. Isn't that that Pfaff 145? If so, a good machine
  14. I would agree. Get a simpler machine to start with. glenn
  15. Rather than try to explain it, I think UWE or Wiz has a video on how to adjust it. I would try that first. Take your finger and see if the take up spring which is to the left of the tension adjustment nut and flick it up a couple of time to see if it hangs up at all. That is sometimes and indication if the spring is not functioning correctly. glenn
  16. Black always stiffer. I still think the take up spring needs to be adjusted a little more. Tension not always just top and bobbin tensions springs. Take up spring can cause or correct some problems. glenn
  17. Weaver indeed coming out with the machine in the spring. Will have the hand crank instead of the pull down handle. This should make it easier to use than the Cub or Boss. I do not know about reverse. As I know more, I will post. Glenn Miller
  18. Nice machine for the price. Looks like a 105-64. glenn
  19. You can get parts from Adler but be prepared to pay handsomely. glenn
  20. C, From what I hear, surgery cures for a while but it comes back over time. My late aunt had it done years ago and went back to work in about 3-4 months. Two years later it was back and she had to retire on disability. Not fun.
  21. Costabulary, Great job on the Singer 108. Really looks good. glenn
  22. Contact Bob at Toledo Sewing or Luke at MJ Foley in Detroit. You can get a generic hook by Hirose of Japan or Cerliani of Italy. Both make very good generic hooks and will be cheaper than an original Adler. I have used both manufacturers for years. glenn
  23. Looks like a bottom feed machine. older. may be good for light leather. glenn
  24. How long is the reverse stitch? glenn
