Everything posted by hidepounder
There's no question about it!!!!! You should definitely send it to me for a scientific, time tested evaluation!!!!!!!!
Thanks everyone for your suggestions. I had gone to several silversmiths originally....Montana Silversmiths, Hansen's, Silver King and a few more...they all wanted $1000 to $2500 with a minimum order...it just wasn't feasable for me...but I'll pursue the plate makers...maybe stainless will be more affordable. Thanks again, Bob
Really good looking maul, Ed! How did you come up with that particular handle profile? Trial and error until it felt right? Bob
Thanks TF, Sorry to be slow replying...been out of town. They allowed us to use a smooth beveler, a mules foot and a veiner. All the shadiing you see on the skull, such as in the eye sockets, etc., is done by cross hatching with very fine cuts to create the illusion of shadow. Bob That's funny Bree! And thanks! Bob Thanks Brent!
Tina, Sorry for taking so long to answer you...I was out of town for a week. the knives I use the most are...a 3/8" Henley with a Bob Beard 1/4" angled HG blade...a Bob Beard 1/2" custom made knife with a 1/2" HG straight blade...a 5/8" custom made Bob Beard with a 5/8" straight HG blade...a 3/8" Henley with a 1/4" low angle, shallow bevel blade by Peter Main...and a 1/2" Henley with a 3/8" HG straight Henley blade. I am very impressed with the 1/4" angled blade from Paul also. Bob
Great work Randahl! You should enter more of those contests! Bob
Beautiful, Tina! Great composition, color, details....really nice! Bob
Holly, You have to know when to "hold them" and when to "fold them"! This is a hand I would fold on. I would tell him very nicely that you're concerned about meeting his expectations which you feel may not be realistic. If he can convince you that he will be satisfied with your art, then fine, go for it. Just remember, it takes a long time to establish a good reputation and one person to ruin it! Send him to Peter Main! Bob
Definitely tool the swell when it's on the tree!
Tom, I see a lot of improvement from the first one you did. Couple of things...When you use your camoflage tool, you want less separation...the tool marks should overlap and progressively stretch out as you move up the stem. I would also use the corner of the camo tool to finish the center of your swirls. Give it a good wack to make a deep impression. I would also tighten up the seeds in the seed pod. I usually do the outer arch first, making sure that each tool impression touches the last, working my way into the center. Where you used your veiner up the center of the Acnthis (sp?) leaf, bevel a little deeper and use a LOT more veiner impressions. Keep going...you're making good progress! Bob
Tapering a Belt
hidepounder replied to ABC3's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Tom, Make a pattern of the taper yu want to use, from cardboard or plastic...then use it to transfer your taper to your leather. You can always turn it over so that both tapers are the same. You can also use an end punch to create the taper...press it onto the leather to make a mark to follow, or actually use it as a punch. I have plastic patterns I've made...I place them where I want the taper to begin...mark them...then continue the taper with a set of dividers along each side. Hope this helps, Bob -
Cordovan!
Mike, I'm going to weight in with Kevin and Ed on this one. I use a 16 oz on 90% of my work. I use a 20oz for flower centers and for larger pear shading, etc. On a larger saddle pattern I would use the 20 oz more frequently. I think either one is good choice! Bob
Mark, I have used the Pro-Carve and I think it does help when leather is really tough, however I find that casing with the soap is better for me. I have a whole bottle of the stuff I will probably never use. More often than not I find that people aren't getting their swivel knife blades sharp enough and look to products like Pro-Carve to make the difference. Every now and then, however, I try it again. Bob ABOSOLUTELY!
My method for casing is similar to those already posted, but I'll go through it anyway. First I rough cut my piece out of the side. I think dip the entire piece in a bowl of water in which I've added a small amount of Joy dish soap. At this point I will slick the piece in all directions with a glass slicker, causing the leather to stretch. Next I take a piece of trimmed sheepskin..dip it in water...work up a little lather on a bar of Ivory soap and wipe that all over the piece. I then let the piece sit out until it begins to return to it's natural color...almost to the point where you would want to start carving. I feel the use of the soap helps lubricate your swivel knife when cutting leather that is "sticky" due to residual acids/chemicals resulting from the tanning process. I then seal everything in a plastic garbage bag or freezer bag and leave it alone for a day. I don't put it in the refrigertor unless I know I'm not going to get to it for a couple of days. When I'm ready to tool, I remove the piece from the plastic bag and slick the entire piece again. At this point the slicking process is compacting the surface of the leather, making the density of the leather more consistant to tool. Now I glue the leather to a piece of 1/4 acrylic, using rubber cement(on belts I use a couple of layers of packing tape). It remains on the acrylic until I'm finished tooling. I am not concerned about the residual rubber cement on the back because I line everything I do. Depending on what the project is, determines whether of not I cut the piece to size before mounting to the acrylic...it is not crucial one way or the other. If I don't want to cut a piece to size before mounting it, but need the finished edges so that I can use dividers to established a margin, I will cut the lines of the finished edge with my swivel knife. I can then finish cutting to size when I remove the leather from the acrylic. Well that's it...not real complicated. I may include some unnecessay steps, but to date this is my process.... Bob
He makes 12 oz too, Harvey. he had one at Wickenburg....I really liked it! Bob
Happy Birthday Casey! Bob
Ed, Wayne is a tool maker who goes to all the leather shows. His mauls don't have the beautiful wood handles like you made on this one, they're leather like Barry's. The contour is what reminded me of Wayne's. I would think mauls like this one would be in high demand! Function is primary of course, but function and beauty is supreme! Who wouldn't want one of those on their bench? Really nice!
Beautiful maul, Ed! Did you make it? The shape of the handle reminds me of Wayne Jueschke's mauls. Very nice. Bob
Terrific tutorial, Clay, and beautiful work as always! I specially appreciated your process on painting. It is very informative for me because I do so little coloring. Beautiful! Bob
Cute story about Jay Lynn.... 10 or 12 years ago I went to my first Leather Show in Pasadena. The buzz around the show was about a prank that Jay Lynn apparently played on Ellis Barnes. If you use any of Ellis' tools you know that the first and second knuckle on your left hand is going to be black and blue from being hit with your maul because the tools are so short. I guess Jay Lynn had teased Ellis about this in the past, and had made some tool extensions that he brought to this show. I had just walked up to the Hackbarth booth where, a few minutes before, Jay had apparently demonstrated the use of the extensions and announced their availability at his own booth. I didn't know Jay Lynn or Ellis at that time, but I'll never forget the ribbing Ellis was getting. Now that I know Ellis, I would have really liked to have seen Jay's demonstration! I still hold Ellis personally responsible for the the arthritis in the knuckles of my left forefinger! BTW...Lonnie showed me the new Hackbarth tool blanks at the Wickenburg show...they are considerably longer than the old ones!!! Troy...thanks for the catalog info...I didn't know he had one either! Bob
Sheridan Style Carving by Bob Likewise featuring Bill Gardner & Clinton Faye.
