Everything posted by DV8DUG
Is this a gorget?
Yeah... That rooster is badass!!!
Those are nice work. Just because its from an older time doesn't mean it has to look old my friend.
Leather Cuirass & Belt
DV8DUG replied to PeterO's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks good... Nice work. How many hours?- 15 replies
- leatherarmor
- armor
(and 3 more)
First off I'd like to ask what a noggin is. Secondly... I'd like to know what you used to anchor your sill to your cement lintels.
What Is Best Surface Material For Hole Punching On Bench.
DV8DUG replied to shadowryder's topic in How Do I Do That?
1/3rd of the gravestone I use for a granite tooling slab is covered with a thick piece of scrap veg-tan 12-14 oz. Contact cement REALLY holds when applied correctly. -
Waterstain thinning
DV8DUG replied to DV8DUG's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I heavily reduced the blue with denatured alcohol... Heavily. 10 to 1 and sprayed multiple coats to get it to start to even show up. But it did, and one more coat would have prolly pushed it too dark. -
Waterstain thinning
Update.... I have found some of the basic (regular 'ol) blue from Tandy. I was able to get the baby blue I was seeking. -
Waterstain thinning
This is bad for me since I am a Californian. Bill reads verbatim ...."AB 44 would make it unlawful to manufacture, sell, offer for sale, display for sale, trade, give, donate or otherwise distribute a fur product in the state. The bill exempts certain items, including used fur." Wonder if re-purposing is included in exemption....
Waterstain thinning
@battlemunky You are awesome. Doing tests like that. I totally appreciate you going the extra mile to find an answer to my question. I am a Californian and a lot of the more interesting colors of dyes are not allowed to be sold here. I'm going to travel soon, and build my color selection as well. That being said, I do have to say that the VOC compliant black dye made by Fiebings is perfectly awesome through an airbrush. -
I'm trying to get a lighter shade of blue out of Tandy's Eco-Flo Navy Blue waterstain. I have had luck with other colors but this one is giving me troubles. I have tried thinning with both water and denatured alcohol and a combination of the two as well. I airbrush all my stains. The color comes out too light or hardly noticeable at all or just too heavy. I have tried applying a light layer of resolene first to no avail. Any advice?
Denatured alcohol in CA.
You said a mouthful there. -
So I went to my local Lowe's to pick up some denatured alcohol and wasn't able to find it on the shelf... or the spot on the shelf with price tag where it was supposed to be. I asked the paint counter girl what was up and she informed me that CA has banned denatured alcohol and several other high VOC solvents. Acetone was on the shelf as well as several very caustic and smelly paint strippers. Confused, I searched the internet for an explanation and found little to nothing about this issue. I was able to secure what I needed at a local ACE hardware store and they had piles of gallons sitting on shelves. Anyone else have similar experiences and do I need to stock up?
I'll take more pix when I get a chance but here's one close up. The little rectangle tabs are lamellae with the half round tab riveted to it. The lamellar are then stitched together to make the armor.
Ha ha.... Someone else had recently posted and I overlooked the date...
You are my hero for a day....
I'm failing to see any kind of Lorica style articulation in your cuirass...
This is a rerebrace, couter, and vambrace I'm guessing? How do you keep the rerebrace and vambrace from pinching on the elbow cop? I see the holes to lace on one end, what about the other?
Ditto...
Good advice...
+++UPDATE+++ So I've now completed the clicker complete with a pair of foot pedals. What I did was I installed a small Parker pneumatic cylinder to be used to control the open/close of the jack. Controlled by a 4 port / 2 position foot pedal. I also used the original hand switch, with the addition of a small metal foot plate, to be used as a foot pedal to initiate the jack. So I step on right pedal to bring the ram down. The pneumatic cylinder is in a default position of extended/closed needle valve. After the cut, I then step on left pedal which opens the release for the jack. When I take my foot off the left pedal the ram extends again to close the release. Ready to go again and hands free...
- 7 replies
- clicker
- harbor freight
(and 1 more)
That's your first attempt? Do you mean first attempt at bracer or first attempt at leatherwork? Either way nicely done!
Love the brogue pattern. Where did you get the punches for that or did you just use normal hole punches?
