kgg
Contributing Member
Everything posted by kgg
  1. I can see a die cutter would be faster but like @AlZillaI also don't see how that will eliminated the stretch problem. Have you tried a slightly larger hole for the ring snaps and using a lever press???? What are the items going to be used??? kgg
  2. I know what you mean when we moved from Newfoundland and at time we were rural we had fiber cable. Then we moved to Ontario to another rural area and it was like we were back in the dark ages even cell phones on the property were a hit and miss. We finally went point to point with our own dedicated connection where we do not share our bandwidth with anyone else but had to install a 100' tower. That was a chuckle and a half. kgg
  3. That is get news. Before you sew anything oil the hell out of it just in case there are any filings / dirt inside. Was the delivered cost what you expected or were there any additional surprise costs like brokerage/duties/etc. kgg
  4. I think you main problem is the type of binder you are using. The ones you show are all wide mouthed binders made for sewing edging onto thick material. As @nylonRigging has said getting the correct binder is a must and setup can be a pain sometimes. You need the item to fit through the binders mouth along with the binding tape and the tape to be fairly snugly wrap around the item to prevent slop / wander and provide better tracking. Finding a 90 degree binder with a smaller throat opening maybe difficult as this depends on what you are binding. I do have the 90 degree binders but I never use them. I prefer the inline style for a couple of reasons. I can use the same binders on any of my machines flatbed or cylinder bed, cost, more readily accessible option like raw edge or double fold and I can easily bend the mouth open or close as needed. I also find the guiding the items edge through the binder easier as the inside edge of the binders body gives me a guide edge to follow. However the 90 degree binders do allow you to get tighter bends then the inline style. Maybe try modifying something like this as they only cost about $15. kgg
  5. Like @dikman has suggested I would suggest you look at Class 341 machines for cylinder arms: New: Class 341 clone machines ----- Cowboy CB341, Techsew 2750, Kobe LS-1341 Used: Juki LS-341, Juki LS-1341 or clones kgg
  6. The Cobra 26 I think is sort of a clone of the Juki LS-1341 but with a Alder hook/ bobbin assembly. The 335 based machines are less capable then either the Cobra 26 or the Consew 227R. kgg
  7. Starlink internet maybe a option?? kgg
  8. You are a little off as .8mm thread is a touch smaller then V554 thread. The size of needle you would need for V554 is a #30 and drilling out the eye of the needle probably could be done with the proper equipment but you run the chance of weakening the needle. Other considerations even if you could find the proper needle for 1.1 mm thread could the one armed bandit's needle bar accommodate the needle or provide enough punching power to drive the needle through what you are trying to sew as well as there would there be enough head space between the needle and hook? Just a couple of thoughts. kgg
  9. You are going to find two main options for binders. Your standard inline which are mainly use on flatbeds and the 90 degree binders mostly used with cylinder bed machines. Depending on the width of the bias binding tape you shouldn't have much problem finding an off the shelf binder that will accommodate the Sisal and the binding tape. kgg
  10. How thick is the Sisal???? kgg
  11. @Stratton @Double Daddy A swing away clicker press versus a the hydraulic shop press conversion: Swing Away Clicker Press 1) Can provide a single downward stroke to allow the die to cut 2) Head swings out of the way to allow access to the clicker die and HDPE bed 3) Weight wise they range from 100 to 450 lbs 4) Can typically cost upwards to $3300 USD 5) Single Function of cutting or embossing Hydraulic Shop Press Conversion 1) Weight wise they range from 100 -170 lbs 2) Typical cost for a basic conversion including the cost of the shop press would be about $500 USD for 12 ton capacity 3) Multi functional Note the top presser plate on a Hydraulic Shop Press can be also have the swing away feature similar to the Swing Away Clicker Presses with the proper adapter. For those who want a very basic clicker press on a budget I would suggest: Considering a hydraulic shop / press setup. Using US sites the cost could be very reasonable and provide more tonnage then the typical manual clicker presses. i) Hydraulic shop press floor model ---- $170 @ Harbor Freight or a benchtop model @ $234 from Amazon.com ( Torin ATY12001B Steel H-Shape ) ii) HDPE 1" X 12" X 12" ------- $25 @ US plastic iii) 2 -Steel Plate 1/2" X 12" X 12" ----- $242 @ Speedy Metals Total ------------------------------------------------ $437 floor style or $501 benchtop style Just my thoughts, kgg
  12. Thank you for sharing. Nice and compact. kgg
  13. The main limiting factor as I see it is the thickness of the rug and whether it is sisal or jute. My understanding is sisal is rougher. Another factor is getting a bias tape binder with the correct mouth opening so you can feed both the tape and rug through too the needle. You will probably need to people to sew the rug as well setting up another table alongside the machines table to keep the rug flat as it being sewn. I think the max sewing thickness of the machine is 3/8" (9.5mm). kgg
  14. With the size you specified you basically have two choices, dedicated hydraulic clicker press or converting a shop / bearing press. The hydraulic clicker presses are expensive while the shop / bearing press conversion can be done for about $500 USD for a 20 ton including the price of the shop / bearing press. I went the shop / bearing press conversion route. Here is the formulas I used when deciding on what size tonnage I would need. Example of calculations: Formula for 10 oz leather with a 3 in square die = 12 inch running length of die F (pressing force needed) = S (shear strength of leather) (2900psi / 2) x L cutting (running) length of die X T (thickness) of leather in inches X Sf safety factor of 2 F = 1450 x 12 x 0.156 x 2 => 5428.8 pounds (pressing force) 5428.8 pounds = 2.42 Imperial tons or 2.7 US tons One of my die plates will be just under 10" x 10" which will require somewhere near 9048 pounds or 4.1 imperial or 4.5 US tons to punch through. @bruce johnson any chance of posting a couple of photo's of the weaver shop press conversion? kgg
  15. A couple of questions. i) What is the largest item you are planning on cutting a pattern for??? The running length of the cutting edge on the die will determine the tonnage you will need. ii) What is your budget??? kgg
  16. Thank you. I'm still working the kinks out of the clicker press section. My previous versions were either to heavy or overly complex / complicated. kgg
  17. I know of three ways of doing this. i) Whether the machine has a bobbin winder built into the front side of the machine (Juki 1541S) or a belt drive winder (Juki LS 1341) what I do is install a bobbin on the winder, engage the bobbin winder and use a second spool to feed the bobbin. The bobbin will become wound and trip went full. Rinse and repeat as needed. ii) There are a lot of external bobbin winders off places like Amazon cost $30 - $90. iii) Then there are the cone winders for making smaller cones from a spool which are a lot more costly ($500). kgg
  18. A 750 (1hp) watt servo will only draw about 6.25 amps under full load. If you have a 20 amp circuit available great but your standard 120 volt 15 amp household circuit that isn't loaded up or has other motor loads will work quite nicely. I would check the circuit you planning on using and see what is on it. These days it is more unusual to see 120 v 20 amp circuits unless it is for a particular load reason. kgg
  19. First off the head is going to weight in around 180 kg (400lb) and the table top has a large hole cut out of it so the table top needs to be real sturdy. I would make sure with whatever material you are going to use it is going to be able to take the load and you may wind up using additional metal support under the table top bolted or welded to the existing frame. If I'm not mistaken the original table top was 2" thick hardwood plywood with a laminated top glue to it. I would NOT use Butcher block as it will not be as strong as plywood, will have a higher tendency to wrap / crack but it will look pretty. The thickest plywood I have seen is 1 1/4" which is actually slightly smaller due to the sanding process. If you choose to use the standard easily available 3/4" plywood and glue them together make sure the grain of one is 90 degrees opposite to the other. I would suggest: i) additional angle iron metal bracing under the table top to help support the front and rear edge weight of the machine along the cutout section ii) use three pieces of 3/4" plywood glue together but that would depend on the type of plywood (softwood or hardwood) and iii) do some calculations on the strength of the type of plywood for the load to determine the type and size of plywood needed. Remember that plywood will warp / buckle / fail if not properly supported. Just my thoughts. kgg
  20. The last time I checked about a year or so ago they were still made in Japan but to be 100% you should phone or email Juki USA. My experience with my Juki 1181N which was made in China is NOT of the same quality as my Juki 1541S made in Japan. If the Juki LS-1341 are being made in China or Vietnam you would probably be just as well off buying a similar clone. kgg
  21. I purchased my Juki TSC441 clone from a Canadian, Ontario supplier for about 60 percent plus of the more popular names. This included a table which I modified for my needs and brushless servo motor. Kinda hard not to buy when you can save $1500 plus for a similar machine. As long as it is a Juki clone parts / manuals are easy to get should something go wrong but you will be on your own as far as support goes and may have to do some adjustments. On the flip side of the coin is where the brick and mortar dealers excel, support. kgg
  22. @PEU I looked at both video's and see you made mods to the last thread tensioner and added a thread guide to the needle bar. Adding the white guide on the needle bar has changed the angle that the thread enters the eye of the needle and by changing the thread guide just above the last tensioner it also changes the thread angle. Did you have this problem before you made changes?? kgg
  23. I would call one of the four Seiko dealers endorsed by Seiko on their website. They should be able to put you onto a Japanese made one. I don't think you are going to find one made in the USA. Most of the stuff is made in China or Taiwan. If you go with the Chinese or Taiwan versions just go to the websites like Aliexpress and buy direct for considerable savings. SUPERIOR SEWING MACHINE & SUPPLY LLC [MASTER PARTS DEALER] 48 West 25th Street, New York, NY 10010-2758 TEL: +1-212-691-3400 FAX: +1-212-807-8743 HOFFMAN BROTHERS [MACHINE] 1795 Birchwood Avenue, Des Plaines, IL 60018-3005 TEL: +1-847-671-1550 FAX: +1-847-671-1320 CIVIT PRODUCTS, INC. [MACHINE] 2 Maple Street, East Rutherford, NJ 07073 TEL: +1-201-896-9292 FAX: +1-201-896-8588 UNITED SEWING MACHINE SALES [MACHINE] 3230 Highland Ave. NE P.O.Box 3055 Hickory, NC 28603 TEL: +1-828-327-0115 FAX: +1-828-327-3468
  24. When I am looking for a machine for myself my rule of thumb for a used machine in excellent condition and depending on age is 65 to 75 percent the list price of a new machine. Hope that helps. kgg
  25. To get better help with your problem it would be helpful to know what machine you are using, thread size that you are using for the top and in bobbin, needle size also a couple photo's of the thread path from the spool. kgg
