Everything posted by Hardrada
Well, it was the one from Tandy, so I guess that sums it up. I used to use a Bic lighter but I had to wipe the soot off with a heavy cloth before applying it to the leather. Quite a pain, which is why I got the spirit lamp, which I also use to heat up my brass stamps now (I used to use an iron upside down and place the stamps on it for ~40 seconds). I ordered another Tandy creaser and still use the spirit lamp, but I'm extra careful now that it only stays no more than 15 seconds under the flame (that one time I left it there for close to a minute or more: can't remember—all I remember is that I heard dripping and when I looked I saw big drops of melted steel dripping onto the lamp).
Probably a heat gun is the answer. With a spirit lamp you can get the creaser so hot that it will melt.
Happens on all leathers. I'm puzzled like heck as well. I watched Renia's demo video and got a 4 oz bottle from Rocky Mountain Leather Supply. Well, it doesn't behave like anything in the video, even though I apply it like they do in there. No permanent bond at all. Either I got a dud or, and I strongly suspect this might be the cause, it was frozen in transit and ruined. It works OK as a temporary glue to hold pieces together whilst punching holes/stitching, but not for permanent bonds. Maybe I should reorder some during the summer and try again.
I'd rather use contact cement. Haven't had good luck with water-based glue (Aquilim 315): over time it dries and the 'glued' parts come apart. In France it wouldn't be difficult to buy some Renia Colle de Cologne: very good contact cement and you can use it to glue more than just leather: think about fabric for linings or plastic pieces. I've seen some leatherworkers use Hirschkleber. Always wanted to try that one, but haven't had a chance to get ahold of some.
French style hand stitching process - where is the mistake?
Hardrada replied to justanil's topic in Sewing Leather
FatCat beat me to it. You need to pull at an angle, yes. Roughly the same angle as your holes' slant, actually. Also, get your pony perpendicular to the floor (a wee bit of a slant is OK, but not more than ~15°). Once you've developed your angled pulling into muscle memory you can change the angle on the pony and your brain will adjust your arms automatically to maintain the pulling angle with respect to the leather; but for now, do yourself a favour and set it perpendicular, mate. -
I hear you. I've done commercial photo work too. I always tried to make business owners understand that specially now in the age of the Internet, when customers who buy online cannot physically handle an item it is all the more paramount to convey as many of the item's properties (texture, dimensions, &c., &c.) visually, which requires proper lighting and styling. But no, they always think that all it takes is an elcheapo lightbox off Amazon and an iPhone and can thus 'do it in house', don't they?
Bcraig, the bit about "all STITCHING chisels" being diamond-shaped is wrong. Some chisels are European style and their holes are not diamonds but slits like these: \ \ \ \ \. I just got me a pair of those from KS Blade. They are NOT cheap, though. (https://ksbladepunch.com/product/pricking-irons-black)** Seiwa makes an economical version of the European style chisels, which you can get from Goodsjapan.com; I wasn't impressed with the reviews I watched of them, though. I've no problem swearing by the Seiwa diamond-shaped, but their European style just didn't rock my boat. Part of the confusion with these items comes from diluting the definitions/boundaries of two different items that are used for stitching: i.e. PRICKING IRONS vs. stitching CHISELS. The exhibit Spyros posted above from Blanchard is a European style PRICKING IRON, whereas the one in the picture below is a Seiwa diamond CHISEL. Note that even Goodsjapan.com is labeling the latter as a 'pricking iron' (AND as a chisel ). See? Even suppliers do it, adding to the confusion. So, what's the difference then? A pricking iron is designed to MARK where the stitching holes on the leather will go. The holes are actually made by piercing the leather with a stitching awl, whose blade is usually diamond-shaped. Pricking irons are NOT designed nor meant to pierce (punch) through the leather and make the holes –although I reckon it's possible to use them as punches if you strike them hard enough with a mallet and your leather is not too thick. A stitching punch, on the other hand is designed to not just mark where the stitching holes will go but to make them as well. They are punches—built strong enough to pierce through thick layers of leather without breaking. So, you no longer need an awl to stitch. Chisels are now preferred by many leather workers because it speeds up the process and neats up the stitching. As mentioned above, you can have chisels in both diamond and European style. They even make round ones (https://ksbladepunch.com/product/round-dent-black), and, yes, for lacing too. Lacing punches, however, are not angled, but horizontally oriented, like so: – – – –. In your specific case, I would recommend the Seiwa diamond chisels: https://www.goodsjapan.com/seiwa-diamond-leather-stitching-chisel-leathercraft-pricking-iron-tool-6x4mm/a-19162 I linked you to the 4 mm version, but they have them in other stitching measurements, such as 3 mm. It all depends on what you're making. See here: https://www.ianatkinson.net/leather/leatherguide.htm#stitching _____________________________ **Again, you have a manufacturer adding to the confusion by labeling a punch a 'pricking iron'.
WILL SOMEBODY PLEASE GIVE ME A DIRECT ANSWER TO MY QUESTIONS
Hardrada replied to bryan4christ's topic in Member Gallery
This reminds me of my days in photography: I would agonise over issues the client didn't notice. I was consistently baffled by hearty "that looks great!" comments because in my mind I was screaming to myself "the background is too in focus! The catchlights are too noticeable! [Endless et ceterae...]". Then again, it's true to a point, so careful. One thing I've seen people DO notice is the stitching. It's kind of a sign of good craftsmanship. When I shewed my goods to one of my university instructors she immediately asked if I had a machine because the stitches were so spot on. She was doubly impressed when I told her it was all done by hand and bought a pouch and ordered a belt for her husband. It's my firm belief that the dividing line between good and amateurish is a clean edge: but now I know there are two dividing lines and one of them is the stitching. -
I don't bother sanding: I always found it too messy and then the edges' edges mushroom. I glass my edges instead with my skiving knife, then proceed to applying Edge Kote or edge paint.
LOL. They E-mailed me yesterday before I tried to contact them, asking for my phone number because they will use Fedex as the post is terrible right now.
Yep, this is what I got upon ordering: Hence my asking Spyros, trying to gauge their current manufacturing and shipping times since I don't wanna be breathing down their neck with constant "is it sent, yet??" I ordered a similar set but in #7: one two-prong and one 7-prong. ADDENDUM: Hah! I just noticed, what they state might experience delays is the delivery, not the manufacture. Delivery has been abysmal all across the gamut: a small parcel from Lonsdale in Vancouver took two weeks to get to Sask. And that's just domestic post.
Hmm, I ordered on the 8th and haven't yet received anything: neither confirmation nor product. Maybe I should get in touch with them. Thanks.
When did you place your order? Did you ever get a dispatched confirmation with a way bill?
Precisely why I prefer to pay top buck for my tools even if that means I can only buy few of them at a time. As I always say: "I'm too poor to spend my money on junk".
Yup, that last tool is what I bought for curves! Except that I got mine from WindFire Designs. For perfect circles, though, I still think the hole punches are the way to go. I ordered a couple from Abbey England. Ditto for the billet ends.
Best tool for cutting curves I've used. I tried Exactos, clicking knife, steel curve tools, even bought an Olfa circle cutter (worst tool for circles, actually) and none of those cut smooth curves. Enter the Don Carlos half-moon knife and the curves just practically cut themselves.
Ditto here.
Half-moon (round) knife. They were right: once you use it you won't want to use anything else. My Barry King mallet. My Kyoshin Elle skiving knife. My Kyoshin Elle #1 edger. My ProEdge cocobolo burnisher. Last, but not least, my Schärf-Fix paring machine.
10-4. Got my Don Carlos knife from Abbey England at long last, after much hunting high and low for one from other European sellers and one American on Amazon.com that wouldn't ship to Canada. https://www.abbeyengland.com/solingen-round-knife-329-8376.html
I see. That's good info, as I might eventually buy a straight razor (using Schick twin blades currently). I want my strop mainly for this guy: The strop from Tandy is just too small and I'm afraid I'm gonna slice a wrist artery or something. Interestingly, the Tandy strop has two sides, one with grain side up and one with flesh side up. Being a noob I applied jeweller's rouge to the smooth (flesh up) side and left the other one compoundless for plain stropping.
Thanks, Tom!
Stoopid question before I make the strop: which side on top? Grain side or flesh side?
I got a side of latigo and was wondering about this too. I'm feeling kinda 'ouch' because my strop requires a piece of leather 22" x 3.5" and the side of 7 oz latigo was $310 CAD, but if latigo is the best I can muster I guess I'm gonna go that route. I also have some W&C English bridle—would that work better?
