Everything posted by Frodo
What were your first leather projects? How do you grow skills efficently?
Frodo replied to Brigg's topic in Getting Started
I bought a sheet of bag stiffener or the cover of spiral note book or a file from the filing cabinet and have actually sewed it together, to completion. and then tore it apart to make patterns, sometimes you just have to make do. No template, took a picture off of the internet, glued it to wood and made a template then started making the holster using bag stiffener using some of the original components -
Is the customer EVER going to get his package?
Frodo replied to Frodo's topic in All About Us and Off Topic
NO. they lost it. and refuse to payout the $50.00 insurance claim They say when it got on the plane to go over seas then they had no way of tracking it in other words the insurance they give you is not worth a dingaling -
This how I cover a whip handle, You need, A a piece of 3/4'' pvc what ever length you need A 3/4pvc cap, for the other end, i use a 1'' coupling, a 3/4 coupling You will need 25 lengths of lace 6'' longer than the pipe 1 piece of lace that will spiral around the entire length of the pipe For the other end saw the 3/4 coupling in half. inside the 1'' coupling is a small pipe stop ridge, dermal that ridge gone the 3/4 coupling should slide into the 1'' coupling push it in half way glueed cover the 1'' coupling with a braid slide it onto the handle that you made, the coupling should over hang the pipe just enough to dress up the edge epoxy the whip into the 3/4 pipe
I have a bottle of 50/50 neatsfoot and olive oil that I sprits it as i am braiding, next iscutting about 450' of lace, then dye it, then oil it
This is the beginning of an 8' bull whip The handle, It takes me a full day just to weave the handle.
Help needed with hand crank cobbler machine!
Frodo replied to LK1's topic in Leather Sewing Machines
correction. if the top stitch is loose, it is the bobbin tension that needs adjustment if the bottom stitch is loose it is the top thread tension that needs adjustment -
the needle MUST go down Then the hook sweeps in front of the hook grabbing the thread on the NEXT revolution when the needle comes up it MUST come up in the corner opposite the hook Also..what needle size and thread size are you using? incorrect needle will cut thread also -
LK, Look at 10:40 How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube in order to set the bobbin hook exactly where you want, loosen the pitman rod nuts and adjust the hook -
PM SENT -
OK guys, I am going to try and tell you how to get your machines working go to this link here How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube if you have questions after seeing this, i can help you, i am not on this forum every day., pm me if it is the needle, put your finger under the machine, roll the crank, the neddle should tap your finger with out cutting you. if you do not feel the needle, it needs to be lowered, if it draws blood it is to long and the needle bar needs to go up -
https://www.karaco.com/marking-supplies/nails-and-tacks/4-3-4-cotton-gin-spindle-survey-spike/
# 8 is a drive pin punch also know as a drift punch here is a glock with a roll pin and punch used to remove it
#6 4-3/4" COTTON GIN SPINDLE SURVEY SPIKE usually used in asphalt
Set,Chisel,DiamPoint,11pc SKU: 011-27000 Retail: $65.00 Wholesale: $52.00 Details 11 pc Diamond Point Stitching Chisel Set. Comes with 1 handle and 10 interchangeable heads: 2mm single prong, and 1 each; 2, 4 and 6 prongs in 3/32", 1/8" and 5/32" spacing. Item #011-27000. https://www.springfieldleather.com/Set-Chisel-DiamPoint-11pc?quantity=1&page=1
Yes I have a couple of tips for you you, Here is a small wet formed pouch about the size of your watch . ...It is for my sewing needle packs Measure your watch, cut the bottom piece the measurement you want the item to be cut the top piece 1/4'' wider are you going to line the pocket with a soft 2 oz leather? add that and leave it larger than you want. trim off the excess liner go ahead a decorate, stamp dye the pieces then sew every thing together, next, drop the pouch into a pan of water for 15 /20 seconds put the watch in a baggie, shove it into the pouch, use your fingers to form the details set it out of the way and let it dry I form pistols and knives, and a baggie works just fine,
I do not have a problem with USMC black, I think it might be because I do not follow the 'normal' directions I apply the stain, wait about 5 minutes then apply the resolene, I apply the resolene liberally and set it aside to dry here is a holster i am currently working on
I use a neutral color wax, then buff
i saw a bag the other day that i thought was really nice, But if you know me, I like rustic !!1 The bag looked to be 8oz veg tan, with a neets foot oil finish It looked like 1 piec of leather folded, and the gusset was folded in, and stitched with raw hide strips I made a simple sketch of what it looked like tell me what you think, and if you draw, bring it to life, I am going to make this
Merry Christ mas and a Happy Heineken to you and yours
I sell at gun shows and for you guys that are interested, here is a link Mississippi Gun Shows Click the link, scroll down, choose your state, and you can see when/ where the shows will be held call the guy that is running the gun show, get to know him . If you are a repeat customer you might get to pick your table spot. THAT is A HUGE benefit Also, there are numerous gun shows, goggle gun show your state ,to find more or just the local guys Good luck, be safe
Explain this hammer thong
Frodo replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
MR Dwight showed me a way to install the hammer thong the thong is ran inside the 2 pices of leather that make up the holster. when you need to tighten the thong, pull the leather tail down -
I do not know which one of you rascals did this. The return address on the box was tore off But someone sent me a large box full of old leather tools. I am humbled and Feeling very Blessed at this gesture. The only thing I can say is THANK YOU I received a box with this bag inside Inside the bag is mostly vintage craftools
