Mulesaw
Everything posted by Mulesaw
  1. Hi, I have no experience with gold plated items on horse tack, but I would guess that high end gold plates hardware would be plated on top of either high end brass/bronze or stainless steel hardware. So in that term I don't think that a humid environment makes any difference. I would be much more concerned with the abrasions from horse & rider, gold plating is very thin, and gold itself is soft, so it wouldn't take long time for the gold plating to wear off I guess. Especially on pieces such as buckles and D-rings etc. Please show us some pictures of your bridles, 🙂 Brgds Jonas
  2. Here is a link to another Fenda with a lot of pictures 🙂 It does look like that one has had the two arms riding on the top roller. Though I doubt that Rafflenbeul made it like that. My best guess is that the lumps on each of the arms is supposed to pres down into the little depression on top of the upper roller bearing guides (those that sit on top of the springs) So those two lumps should be the same height when you turn the adjustment handle on the top of the yoke. (It could be that if you have had them removed, that you have mixed them up, so the wrong one is on top?) Do you have any parts that look like they would fit in those depressions? Like a small disc for the arms/lumps to press on. That would raise the arms from the roller as far as I can see. If the springs are very hard to compress, you can start by screwing in a longer bolt, or a piece of threaded rod (I guess it is M12), then you put a washer on the threaded rod and a nut. You then tighten the nuts alternately to slowly press the yoke down. Once it is in place, you remove one threaded bar at a time and replace it with the original bolt. Brgds Jonas
  3. Nothing like an instruction video that messes up. Incredible that a company don't re-take" the video. Brgds Jonas
  4. Thank you for the nice comment, The best part (to me) was when the customer said the same thing, she takes really good care of her equipment, so it is fairly important to her that her equipment is well maintained. and it has to look decent. Brgds Jonas
  5. I don't have a picture of a set up, but if it was up to me, I'd just make sure that there was enough space behind the machine to catch the straps when they have been creased. For electric power, I would try to get an old sewing machine motor with a foot pedal. That would keep both of your hands free to feed the straps. It is a really cool and good looking machine! Another thing, if you can mount the rollers individually, it would be a walk in the park, to hold a scotch brite pad to them to remove the light surface rust - without fearing that it would suddenly squeeze your fingers. The rollers that you don't use often could get a light oiling and be packed away. Brgds Jonas
  6. Beautiful work! The Conway buckles are indeed a very nice touch. Brgds Jonas
  7. My dedicated leather workshop still isn't finished, so I am still making saddle repairs in the living room 🙂 it is a delicate balancing act to keep that privilege, so I am afraid that bringing in free standing work lights might be stretching the patience of my wife a bit.. So far I either hang the saddle over the back of a chair, or sit with it in my lap. I think that I'll fold a blanket if I have to lay it down on the table, like you said - it can be folded and put away after the job. A good thing about working from the living room is that I can do it in the evening and still be part of family life. My patcher is also inside, and my wife thinks it is a cozy sound when I am using it to replace zippers in riding boots. It is foot powered, so pretty quiet. There is also a steady flow of tea and cake 🙂 Brgds Jonas
  8. Welcome to the forum 🙂 There is a lot of good information to be found here on various leather projects. The best advice I feel I can give- is that many of the "complete tool sets" that are for sale are not of a very good quality, and will often contain things you might not use. Instead buy a couple of individual items and learn to use them, then you can always buy more if there is a specific thing you like/need. A good starting point is: A utility knife. marking wheel, diamond awl, a hole cutter (Lidl has a remarkably good one), a block of cork to act as backing for the diamond awl, some thread, a small pack of leather needles, some beeswax for the thread, a steel rule, a cutting mat. With the tools mentioned above, you can get a lot done. The next things I would get are: A stitching groover, an edge beveler, a skiving knife, sharpening tools for the skiving knife. It all depends on the type of leatherwork you would like to do. If you are going to focus on carving, you need some other tools, but those just mentioned will get you a long way in terms of hand sewing general items. If you plan to use a lot of rivets in your work, you are going to need a hammer and a small anvil too. Brgds Jonas
  9. @jcuk Thanks for the nice comment. The only thing stopping me from sitting in the sofa is that that the light is a lot better in the other part of the living room 🙂 I have considered getting a small head lamp though, since no matter how I do it, I always end up with some of the work being done in a shade. Especially when I have to do any stitching on the flaps. That coupled with black thread is sometimes enough to warrant a small break and a cup of tea to sort of reset myself. I have occasionally considered making a padded table where I could lay saddles on while repairing them. But then again, it takes up space, so I am debating if I should make like a padded tablecloth to put on the regular table. That would take up less space. Brgds Jonas
  10. @Jen the Canuck Another option is to attache the D-ring with an extra strap the will sandwich the breastplate itself. Kind of like a ranger belt. You could make that strap out of some dark brown leather, to make it pop out a bit. Brgds Jonas
  11. We need someone who is a lot more artistic than me to make a set of outlines of the discs that need to be sawed. If the inside of the individual laminations was sawed out, the completed heads wouldn't be terribly heavy. Brgds Jonas
  12. If you took some 1/2" plywood, and laminated a horse head. The laminations should be placed like the head of the horse was split vertically lengthwise. (Terrible description) Each layer is simply glued and tacked to the next layer. Finally you make two ears from some leather and screw them on the top. Sawing out the laminations would probably require a scrollsaw or a small band saw. The first build will probably take a long time since you have to make patterns for all the laminations, but the next ones should be copy-paste and fairly fast to do. This is the best picture I can find to explain what I mean. Your horse head will need to be bigger and more detailed, with an open mouth etc, but the same basic idea. It will be clear to people what it is, but it won't be so detailed that it will take the focus from the head gear that you have on display. I am at sea right now, other wise I would be tempted to make an experiment myself 🙂 Brgds Jonas
  13. Hi Jim, Thanks for the nice comment, and also an interesting suggestion. In theory it shouldn't matter much to me - but in reality, I think it is very interesting. I think I'll try to ask my customer next time I see her, if she knows anything about the former owner. But I kind of doubt it. Otherwise I think she would have said something when we discussed the job. Brgds Jonas
  14. If installed properly they can take a lot of beating. You need a special tool to install them. It is like a tapered punch that goes into a tapered hole. At least for very big ones. You could also use some small D-rings for the paracord. On your picture #2, the black stitch on the left (closest to the edge of your bag) - every 2" (give or take), you mount a D-ring. The D-ring can be mounted using either a thin strip of your leather or a strip of webbing. You can get D-rings in many sizes and colours, I would think that a 5/8" D-ring in brass would look good. Something sort of like on this picture:
  15. Hi Tove, Thanks for the nice words 🙂 That sounds like some very plausible causes you mention, I think that the situation in Denmark is pretty similar as in Germany, with very few people being able to invest 6-10.000 Euro on a bespoke saddle. Mys customer is petite, so though she is an adult, she has specialized in training dressage ponies, so I think it was a 16" or 16.5" saddle, And the range of people willing and able to make a huge investment on a special saddle for a pony /pony rider is even smaller than for a full size dressage horse. So it makes sense that it was one of the causes you suggest. One of our good friends had a bespoke saddle made for her horse, maybe 15 years ago. The horse had a bit of a crooked back as far as I remember, not much, but enough that a standard saddle hurt the horse. So she had someone from Kieffer coming up to her and measure her and her horse, and she ended up with a saddle that fit perfectly. I would love to be able to do that kind of work, but I haven't got the knowledge to do a proper fitting on a horse, so I just have to stick with doing repairs (but that is also a nice job) Brgds Jonas
  16. Thanks for the very nice words Chuck. It is so frustrating, that I haven't got the answer to why the wear is only on one side. It is really puzzling. I had thought about the "one way" idea too, but it just doesn't make any sense when it is a regular dressage saddle. Equestrian vaulting would fit that category, but that is a completely different type of saddle. And also I am puzzled, why the original owner didn't notice that the saddle got so worn in one side and not in the other side - and in time did something about it. Take care Brgds Jonas
  17. @Tove09Tilda Hi Tove Sorry to hear that the internship wasn't a success. I think that @BlackDragon has a pretty good point in that you can follow your passion without it being your career. So I really hope that you'll find a job where there is: Nice colleagues, A friendly and supportive environment, Enough interesting tasks to make you feel occupied. Best regards Jonas
  18. Not a chance on that one 😄We are in the southern part of Norway, and it is bitterly cold here at the moment. Plus there is some incredibly bad weather in the North Sea at the moment, so we have been told to just stay put in the harbour until the sea calms down a bit and we can deliver supplies to the platforms again. On your triple stitched halters, the edges looked fantastic. Did you only use beeswax and heated edge irons on those, or also hide glue? It sound like a very interesting experiment to use hide glue, but I think that I would be afraid that it would be sort of delicate and not handle rain too well?
  19. The stitching on the 5th attempt looks a lot more consistent than on the earlier ones, so there is a fine progress! Also the distance from the stitching to the edges is very nice and consistent on the last one. So like @DieselTech says: keep up the good work 👍, Brgds Jonas
  20. In Denmark, it is not uncommon to get a "retirement job", I don't know if that is a thing in Canada? It could be janitorial for a small business, maybe 10 hours a week, not enough to get exhausted by, but it gives a little bit of steady income and more importantly a continued connection with the rest of the world. It is just nice to have a new story to tell at home, or have someone that you can tell if you did something interesting in the weekend etc. If retirement is scary, that might be a way of slowing down. Off course it depends on if you can find a place that has a similar opening that you would like, but I have often thought about that it is a fine way of doing it. Brgds Jonas
  21. @Scoutmom Thanks, 🙂 @TomE Thanks for the very nice words 🙂 I also really would have liked to see the corresponding boots, but my customer bought the saddle second hand, so she was as puzzled as I. There was just ordinary light wear on the left side of the saddle, not even close to being worn through. I did do a bit of thinking about the shape, off course it had to cover the worn part, and after a couple of initial ideas, I ended up deciding that this shape at a quick glance could look a bit like something that was original to the saddle. And since you can't see a saddle from both sides really well when it is on a horse, I don't think anyone will ever notice. A thing that I am really happy about is that I actually timed myself doing it, and this Monday another customer asked me about a similar repair, but on a Prestige Versailles jumping saddle. So it felt really good to be able to give a ballpark figure on the time/price of such a repair job. (I just signed on yesterday, so I told her that she'd have to wait until I get back home again) I guess that repair will be a little less complicated since there isn't a lower reinforcement piece on that saddle. I'll just have to get my hands on some brown leather that matches the existing colour. All in all, a job like that almost feels like cheating: Getting paid to do something that I genuinely like to do, and being able to sit inside and have a cup of tea while doing it, all while I have two large dogs snoring away on the floor next to me. Brgds Jonas
  22. This time at home, one of my customers asked if I could repair the saddle flap of an Equipe saddle, where the outer layer of leather had been worn through. She had bought the saddle second hand since it fit both her and her horse perfectly, so she is not the one who has managed to wear the saddle flap to this extent. Actually I am kind of puzzled as to why it was only worn through on the right hand side of the saddle, but the left side had just a bit of normal wear, so either the previous owner must have had used her right leg more, or perhaps have used some abrasive things on her right leg, like an unprotected zipper? For once I have managed to take pictures through the process, to help giving an idea of how I did the repair job. In total the job took 8 hours, so it is not a super fast job, but I never expected it to be. The value of the saddle still makes it worth making a repair like this, and difficult work holding/handling and hand sewing is the main reason for the time consumption. If I had a cylinder arm walking foot sewing machine, I might have been able to pull it off a bit faster, but I am only guessing. A saddle is fairly awkward to move around, and It only takes one slip to make the stitch line look bad and making matters worse, so I think that I would probably still go with hand sewing in this case. 1) outer layer of thin leather on the saddle flap is worn through. 2) A pleasing curve shape was cut on some paper. The inspiration for the curve came from the sides of the seat, and I wanted the ends to correspond to the angles of the lower reinforcement piece. 3)The curve is lowered to show the corresponding ends of the lower reinforcement piece. 4) A piece of thin leather (approx 2 mm thick) is cut out in the correct shape. It is deliberately made so that the lower part leaves a 3/8" gap towards the lower part of the saddle flap. (This is similar to how the original worn piece was made, to give a nice smooth transition for the lower reinforcement piece) 5) The repair piece is skived along all edges. approximately 5/8" wide. 6) The stitching for the lower part of the saddle flap is cut plus the lower part of the decorative stitches. The lower reinforcement piece is carefully removed and put aside to be used again. The worn piece of the saddle is cut of, following a curve matching the repair piece. Leaving approximately 5/8" overlap. 7) The repair piece is glued on using contact cement and hand sewn along the upper part. The decorative stitching is continued as well. (I sew over the first and last 3 original stitches to lock them in place) 8 ) The lower reinforcement piece is sewn in place again. Hand sewing since I don't have a sewing machine that could do it easily and allow me to maneuver the saddle easily around. I tried my best to use the existing holes in the heavy part of the flap. 9) The completed repair job.
  23. Welcome to the forum. Lots of inspiration to be found, no matter what you like 🙂 You mention that you would like to do leather work as a side hustle, I get that you don't like to deal to much with the public or run a business, but.. Unless you can use all the leather items that you create yourself or gift it off to families, you will end up having stuff all over. (Based on experience from my other hobby which is woodworking/cabinetmaking). A solution could be in doing leather repairs. I have a small company with my son, where I do the leather work part. I am not a trained saddle maker, but I can do most repair jobs on saddles except for restocking them with wool. A lot of people are daunted by the thought of sewing leather, and while it might be more fun to craft something new, there is also a satisfaction in repairing something so it works well again. An advantage (to me) is that repair jobs are very seldom exactly like, so I don't risk making 25 of the same thing in a row, but, one week I can repair a saddle flap, and the next week a stitching in a computer bag or a set of chaps etc. It is just a side hustle, but it is a really nice feeling to be able to immerse myself in a good leather repair project and being paid for sewing and sitting and listening to a podcast or the gentle snoring of our dog at the same time. Most of my customers know of me from word of mouth, as I don't do any advertising. Equestrians often need a lot of leather work to be repaired, people with vintage motorcycles (1950'ies and older) are also possible sources of potential customers, for saddle bags, seat repairs etc. I don't repair leather items exclusively, also horse blankets and replacement of zippers in riding boots etc. I do like to create new things as well, but selling new leather products is difficult in my area, so that is one of the reasons for the repair business. Brgds Jonas
  24. Great job, very consistent sewing along the edge! Amann Serafil is my main thread for all sewing machine jobs, for hand sewing I use Amann Serabraid. I once checked Amanns homepage, they make an incredible range of various threads, from anti flammable to UV (sunlight) resistant. Brgds Jonas
