PastorBob
Contributing Member
Everything posted by PastorBob
  1. I would guess a wood router. That would shred leather, IMO
  2. PM sent on judge, glock 19, and Beretta 92.
  3. Thanks for sending info on Adam's website. had full list of parts to buy. Just can't shell out $300 right now. It's on my list. Again, Love the way the holster is defined. Great job.
  4. Great information. Thanks so much. I have watched several of Adam's Leatherworks videos, just skipped right past the vacuum. Do you line your holsters? I will check out the vacuum process and see if I can't rig something up to work.
  5. That looks great. Love the handmade tools to assist in the process. I can't ever seem to get crisp lines like that. Matter of fact, i can hardly make the impression for the trigger guard. What is your process? My steps are. Cut leather Dye Assemble and stitch Wet mold I soak mine for about 10 seconds or so then insert gun mold and begin working with fingers. I am using two 5-6 oz pieces glued back to back for holster. Thanks for any insight. Anyone else is welcome to chime in as well.
  6. Yep. Ditto on letters being hard. the bigger they are, it seems to be easier. Keep it up. You are doing good. Remember, we are our own worst critic...we see everything. There are times I have pointed out errors I made to others...glaring to me only to be told, "I would have never noticed that if you hadn't told me. Need to keep my mouth shut sometimes. LOL
  7. Those small carved areas are hard to get beveled without smashing down another line or getting into the design. I had the same issues. Finally got a smaller beveler to get into those tight areas, also got a couple with a steeper face allowing me to lightly tap, but still get some beveling in. Looking good. Keep up the practice.
  8. Very nice. Nothing like creating something for a family member. This, I am sure, will be passed down from generation to generation.
  9. nice work!!! I am currently working on an inlay holster. How hard was it to do the ostrich with just a small amount of leather around the exterior?
  10. Very clean work. I would wear that anywhere. Nice picture as well.
  11. love it...and the play on words.
  12. Nice looking holster! Hand stitching for me is so relaxing, unless I screw it up. I think it really adds to a piece when presenting it to the recipient. A couple of things I have struggled with initially was getting the thread to lay down uniformly. With a standard sewing machine, the needle and thread always travel in the same manner while you move the piece being sewn to achieve the stitch. I practice the same thing when hand stitching...I move the piece all over the place in the stitching pony so my thread and needles go through / pass over each other the exact same way, in the same orientation. And I always use the same amount of tension when I pull the thread tight. This way it looks very uniform. Another trick I picked up...After making my stitching groove, I will place the stitch holes at all the intersections and corners first so they always align, especially when changing directions. This allows me to put a hole on the exact intersection of lines, especially on corners, so it is kept straight in the groove (otherwise it will cut a corner if no hole on the corner). I also don't stitch around the belt holes. I slick them down really good and that works well. It is stitched on the outside so as long as there was plenty of glue, they shouldn't go anywhere. I would also go ahead and run the double stich line all the way to the bottom stitch instead of stopping. When it stops like this, one is forced to do a back stitch there. It's all about how the eye perceives it. To me, it is less noticeable when hidden in the bottom stitch line. Here is an example of one of my holster. Notice the belt loop and stitching.
  13. Nothing sexier than a 1911. Even more sexy with that low cut dress. Wowser! I did notice the "extra" stitches below the trigger guard. Was that intentional? I have not seen that before. What is the purpose? Just added strength?
  14. Welcome to the Forum! Lot of great ideas, patterns, and plenty of suggestions and opinions. Jump right in! Make sure to share your journey with us through pics. There is a thread showing how to upload pics somewhere.
  15. I know Don Gonzalez does a lot of that. May check out his youtube channel. Can't remember what he uses, may be resolene. He is able to cover it using a sheepskin applicator with no smearing.
  16. Wow! Nicely done. The detail around the mouth, feathers, and hair is great. A couple of things to add as you continue in this craft...watch Joe Meling's video on tooling leather feathers. It will assist in getting the lines going in the same direction. Also, Bruce Cheney has a couple of videos on beveling. This will help remove the light and dark spots around your circle, making it more consistent. If this is for your table top, thank you for your service. Thanks for sharing a creative, and daunting carving with us.
  17. if you don't have an airbrush, or a place to use it with proper ventilation and easy cleanup, you can get Saddle-Lac from Tandy. You could probably find its comparable at a wood working store as in spray on lacquer. I am sure one could find a MSDS sheet for it. It sprays on from an aerosol can. I have used it with great success. Kind of pricey, but lasts a while.
  18. I have never used atom wax. Is it more like a conditioner / protectant (like sno seal or mink oil)? If so, that would make sense. If you don't have some type of top seal on it, it will definitely rub off over time. Keep us posted on progress. You could even use Super Shene or Satin Shene, depending on the look you desire. or for that matter, saddle lac
  19. Pretty ingenious. Thanks for sharing. Another great idea! Thinking i could either laser engrave on the board itself, or attach some decorative pieces of carved leather. what is the dimension of the gap, where the plant hangs?
  20. Nice find. Thanks for sharing. Do you have one? I thought the ones I've seen were 1/2" thick. This looks to be less than 3/8" in thickness. Should still work okay though, right? If that's the case, I may go by my local glass shop and see if I can get a scrap piece smoothed down from their discard pile.
  21. I know there are a lot of custom stamped / carved motorcycle seats out there. You might try contacting one and asking them how they keep theirs looking so nice for so long. They may divulge their method. I would make the call as a potential customer and ask how they guarantee it won't fade, etc.
  22. Glad to hear it. Make sure to post pics of your work when done. Excited to see what other crafters are creating!!
  23. My wife's purse had an outside zipper area that would open up to a padded, generic holster velcroed in place inside the pocket. It was sold out of a gun shop. I would think if you are making a custom bag for someone, you could make a removable holster attached with velcro to hold it in place that was specific to the firearm. Then, should they ever change the firearm they carry to another model, they come back to you for another insert.
  24. I use Tokonole by spreading it on the back and rubbing it in really well. There is a glass slicker out there that is super nice, but super pricey. I don't have one of them. I just smear on the tokonole and rub it in really good with by bone creaser. It essentially slicks the back of the leather to super smooth. Check out this video by Fischer...
  25. Yeah, it doesn't take long at all. I think the one above took about 15-20 minutes to create.
