PastorBob
Contributing Member
Everything posted by PastorBob
  1. That's a pretty cool design. As for stitching, if everything is aligned properly, and you keep your chisels perpendicular to the work, you should have no issues punching from the outside. For non-veg tanned leather, I use straight tokonole to burnish. On thinner pieces, I will either just apply with my finger and lightly rub on it so not to apply much pressure and that seems to work, or after applying it, lay it down on a flat surface and rub with a piece of cloth or burlap-type material. Keep the images coming...again, nice work.
  2. interesting. I have not tried the vacuum approach yet. May in a few months. What type of bag were you using? What is your setup? Not sure I care for the patterning. Kind of takes away from the leather look.
  3. Welcome, Doc! peak around...very knowledgeable group here. You will find more than you can digest. Welcome from SW Missouri
  4. Love Sergey's new tool. Nice work. Love CZ's as well. Just replaced my EDC P-07 Duty with Sig 226 Legion. It was a hard choice.
  5. Wow. Nice job of execution. Very functional. Welcome to the forum. Stick around. Lots of good info here.
  6. Yep. got that same plastic tub. My recent addition was a left handed holster.
  7. Glad you're here John. You will definitely find helpful folks from all over the world that can share their knowledge and experience with you. Welcome from SW Missouri!
  8. thanks for that tidbit. What is the math behind determining the spacing of the slots? So I can make them for different calibers.
  9. Thanks @Dwight. That looks lots easier than other ideas I have seen. I will give that a try.
  10. Very nice work. Is is all carving or is there stamps involved. Either way, beautiful...and agree with @Frodo
  11. Very nice. Practice is paying off.
  12. Welcome to the forum from SW Missouri. I would go no more than 9oz and no less than 6-7 oz on the wrap. Maybe go 5-6oz on the loops for the ammo. A couple of thoughts...don't use grommets or rivets unless you have a protective layer between them and the stock.
  13. pretty cool. Wish I had the room and equipment to do wood. Always fascinates me to watch wood turning. some cigars I buy have a thin cedar wrap around them. I could probably find some of that if necessary. Have had no complaints thus far.
  14. In my uses, I either leave them in the cellophane wrapper, or they are not in their long enough to be affected by the leather "aroma" - lol. I mainly use them when heading to an event and don't want to risk crushing them in transit. When traveling for several days, I will take my herfidor (small, pelican style case), then transfer them to small leather humidor for an outing.
  15. What size holes are you making with the laser cutter? Are you only using black thread? If not, how to you prevent the "char" from getting on lighter color thread? What is it you are making using the laser cutter for your patterns?
  16. I have a hard plastic tube made for storing cigars I use to form the shape when the leather is wet. As soon as the shape is formed, i remove the tube and set the wet leather pieces in front of the fan. This piece really needs to dry. It is dyed, then laser engraved. If not completely dry, it is too dark to really see the engraving on it.
  17. It could be imperfections in the tanning process where some of the chemicals they used remained on the leather. I have never tried it, but have heard use of deglazer can help remove the surface impurities. Another thought is to wet all the leather pieces and allow them to dry. I recently made a pocket humidor and its been drying for 3 days in front of a fan and is still not completely dry.
  18. I would guess a wood router. That would shred leather, IMO
  19. PM sent on judge, glock 19, and Beretta 92.
  20. Thanks for sending info on Adam's website. had full list of parts to buy. Just can't shell out $300 right now. It's on my list. Again, Love the way the holster is defined. Great job.
  21. Great information. Thanks so much. I have watched several of Adam's Leatherworks videos, just skipped right past the vacuum. Do you line your holsters? I will check out the vacuum process and see if I can't rig something up to work.
  22. That looks great. Love the handmade tools to assist in the process. I can't ever seem to get crisp lines like that. Matter of fact, i can hardly make the impression for the trigger guard. What is your process? My steps are. Cut leather Dye Assemble and stitch Wet mold I soak mine for about 10 seconds or so then insert gun mold and begin working with fingers. I am using two 5-6 oz pieces glued back to back for holster. Thanks for any insight. Anyone else is welcome to chime in as well.
  23. Yep. Ditto on letters being hard. the bigger they are, it seems to be easier. Keep it up. You are doing good. Remember, we are our own worst critic...we see everything. There are times I have pointed out errors I made to others...glaring to me only to be told, "I would have never noticed that if you hadn't told me. Need to keep my mouth shut sometimes. LOL
  24. Those small carved areas are hard to get beveled without smashing down another line or getting into the design. I had the same issues. Finally got a smaller beveler to get into those tight areas, also got a couple with a steeper face allowing me to lightly tap, but still get some beveling in. Looking good. Keep up the practice.
