AlZilla
Moderator
Everything posted by AlZilla
  1. I'm glad we're moving forward on this one. When I get home tonight, if there's not some resolution on this, I'll go up and rotate through my similar machine.
  2. Somewhere in your settings, you can set it up to email you notifications. I'll look later on today and maybe we need to make a post on how to fix that. Evidently it's not the default. EDIT: it's a simple matter to "fix" the notifications. Desktop Click on the drop down next to your User Name (Top/Right) Account Settings Other Settings | Notification Settings Mentions & My Content Click "Email"for both notifications Android Click Menu on top/right Account Settings Other Settings | Notification Settings Mentions & My Content Click "Email"for both notifications
  3. I flipped this over to Leather Machinery. Let's see if we can get some action over here.
  4. Hey, @JoDeeH13, I moved this over to the braiding sub forum. Let's see if we can get you some responses over here.
  5. @OLDE WYLIE, Welcome aboard. I split you out into your own topic, rather than conflate your 20-2 issues with the other poster's 20-20 restoration. I turned your couple of shoutouts to a "tag", which will notify the users that you've mentioned them. I did the same thing to your user name so you got a heads up. Do that by typing the "@" symbol and start typing the users name. Then, select it from the drop down that appears. Good luck with your 20-2. Let me know if I can help you navigate the forum.
  6. I went through this a couple of years back. Just a seeming few dollars more gets you a little more capability. Then, if you're at that level anyway, why not a little more money..? Such a slippery slope. Be interesting to find out where you land. 😃
  7. AlZilla
    Used Juki 1508N
    @japty I moved you over to the Wanted section. i'd suggest starting with Toldedo Industrial. They're an advertiser here and enjoy an excellent reputation. 866-362-7397
  8. I'd look under the left side of the bed, right about in the middle of the machine. I think there's a stitch regulator adjustment under there. Just a vague memory from a machine I remember looking at some time in the last few years. One of the big dogs will no doubt know right off the top of their head.
  9. Thanks, @Einherj. The more of this that can be collected in one place, the better we all are.
  10. Is it possible that between the slightly larger needle and the fabric point punching thru the sewn material that there isn't enough friction between the needle and vinyl to hold the thread down, so the loop can form consistently? @JukiFan, does the speed of sewing have any effect on how often it skips stitches?
  11. I would say that the "right" people are going to be looking in the same place that everyone else is looking. Advertise here for a targeted audience, any leather guilds you happen to have in your area and then blanket your big classifieds. Craigslist, facebook marketplace and whatever else you have. In my rural area, the fb marketplace seems to be the hot place, then craigslist and then local publishers. In short, advertise everywhere and let the people find you.
  12. I learned this from you quite some time ago. I wondered what that little wheel looking tool was all about. It does make a huge difference.
  13. I'm about to head out the door but a couple of quick thoughts ... Sounds like it's hammering. Definitely needs cleaning and oiling internally. Especially the hook area. A dull needle could contribute to that sound. The slow start could also be related to lack of lubrication. But very often that slow start means the motor and/or foot controller need to be serviced. This is all easy stuff to do. I'll recommend going to you tube and looking up Andy Tube he has hundreds of videos, mostly on old Singers but it still applies. Also Vintage Sewing Machine Garage. I'll check in here later this evening and see if we have any updates from you. Oh, the stitching is probably a simple issue as well. It starts with cleaning, oiling, checking your thread path, using new thread and needles, things like that. It's all very Zen. Sit with the machine, go over all the parts of it, study how it works. Become One with the machine . Ommmm...
  14. Could you just make a rough out version? I can't visualize if it's just an inside out mirror. Or finish it and sell it off. Some lefty GP100 owner will be happy.
  15. I recall seeing that P-10 type setting somewhere. I think it was some kind of break in or run in thing. Seems like it would run intermittently like that until you shut it off. I think ...
  16. Yeah, I thought that's how it looked. If the smaller pockets popped off, he could adapt it job to job. Of course, the upside to one unit is he'll never wonder where the hell that little pouch went to ... 😬
  17. @pierre2171 I split this out into it's own topic so maybe we can get you some help. It looks like an interesting machine. EDIT: In fact, a search for 133k13 turned up a few hits. I'll leave you to sort through them. https://leatherworker.net/forum/search/?&q=133k13&search_and_or=or
  18. Nah, you couldn't have bought one that nice. The only way that gets better for me is if the pouches are modular. It's one of those bespoke things you can afford to have because you're a leather worker.
  19. AlZilla
    The Alamo
    She looks quite annoyed about it, too... I'm enjoying these cards you're doing. Thanks for posting them.
  20. That little black guide is called a check spring. It's a very important part of the thread path. The "snap' you mention is the sound of the thread snapping behind that teeny little tab, visible through the oval hole next to the screw. If it's not snapping in, try holding the thread that's above the check spring so that it doesn't pull from the spool. At that point in your threading process, you could drop the presser foot. That will clamp the tension discs down and should hold your thread. Based on the angle of the thread coming off the check spring, it looks like it's behind the tab. I think.
  21. More experienced voices will no doubt chime in here but you should be able to get into a used machine with that budget. A tight budget, for sure and you may end up with a fixer upper, but doable. I'm thinking something in the range of a Consew 206RB-x (x being a number up to 5), or one of it's many equivalents. Start fishing what you find past the experts here and you'll probably get great advice. I'd only suggest holding out for something with reverse. You don't need it and not having it will save you money. But you'll experience a feeling of lack every time you use an older method to lock your stitches.
  22. These look like horse saddle bags to me. Just something that showed up in my utube notifications.
  23. He's got the first 3 listings right now here: https://leatherworker.net/forum/forum/78-leather-and-lace/ He listed a green kangaroo hide and it disappeared right away. All that stuff looks top notch and Ferg is great to deal with. I've bought things from him a couple of times now
  24. Did you take that kangaroo hide Ferg had for sale? I bet that's a fantastic hide. My wallets usually feel chunky, too. That .6mm kangaroo might be the ticket. I took one of his other hides, the first cordovan one, and what a beautiful piece of leather. I need to come up with a worthy project.
  25. For me, whatever contact cement the hardware store has on the shelf. At the moment, Weldwood, I think? Something like that.
