badhatter1005
Everything posted by badhatter1005
  1. I use a stylus. You don't even have to wet down the leather if it's good leather. Trace your pattern that way and then cut it out. A ballpoint stylus is like $10 on Amazon or in any local hobby store pretty inexpensive.
  2. I'm with Dwight. I can do repair work. Just need the info on what I'm fixing.
  3. Thank you for following up with the photos of the buckle in action. Makes perfect sense now. Great job.
  4. I like the way this looks. Would you be willing to upload a picture of how it attaches to a belt strap? I do not have an engineering mind unfortunately so I'm having trouble seeing how this would work. Thank you in advance.
  5. Welcome my friend. Hopefully you find a niche here and start doing some leather work. We will definitely keep you in mind for the IT work as well.
  6. George McClellan invented the cavalry saddle a lot of them were used during the war between the states on both sides. This saddle is obviously an issued cavalry saddle. I would take it to a professional if I was going to do anything to it. Have to be really careful with leather that old as saddle soap and even mink or neatsfoot oil could potentially break down the fibers. You have a piece of American history there and it is beautiful. Congratulations on a great find.
  7. It looks like someone punched holes with a precision chisel set the holes with an awl and then saddle stitched that particular portion by hand. I know a lot of pro shops do that however I'm by no means an expert.
  8. I agree with Dwight. I've been using a Tippmann Boss for over a year now and my business has improved exponentially. It is a hand crank machine so be ready to have that right shoulder broken in really good however the results speak for themselves.
  9. Dwight my friend. Where in the world did you get this and also where in the world can I get one? This is genius.
  10. Beautiful work. What did you use as a filler?
  11. Look at the will gromley BBQ pattern pack. You can slightly modify the Glock holster to be a duty holster. I've done it multiple times and it is great. If you notify me I will send you a card stock pattern that I use for the Glock 17. You can do it as a paddle holster or you can make a belt loop for the back.
  12. I'd say in this situation it's a matter of preference. I can't think of anything saddle wise that was made a hundred years ago that is going to be more comfortable than a current saddle made with a fiberglass frame. Also not as light to carry back and forth. Seriously pick up a McClellan saddle Pre-World war II ride with it for 2 hours and then carry it back to the tack room. Then do the same thing with a modern saddle and feel the difference. I think it has to do more with the person making the saddle. Find a reputable tackman. I can personally recommend Don Gonzalez. Probably the best I know of.
  13. Sorry it took me so long to get back. You can use the olive oil itself to seal the product. The nature of the olive oil dictates that it will hold strong in the leather fibers. The only other option to seal would be neat's foot oil which I really like. It has the same effect but will not be as waterproof as tancoat. The good part about that is that you can go back later and add more oil if you need to.
  14. For the probably thousandth time on these threads I'm going to agree with Dwight on all accounts. Tandy is right near me and I really enjoy being able to hold something before I buy it. I've had not so great luck from Weaver with some of their leather. It started out being great when I first ordered however later on down the road the quality control went down significantly. With Tandy being so close I can go to the shop and pick out my hide off of the table or out of the deck that they have set up. I can hold the tools and see what they're actually going to do and what they feel like in my hand. My recommendation is to find the nearest shop and driving distance and go check it out. Ordering off of the web is handy if you know exactly what you want and exactly what it's going to do. However if you want to feel the stuff in your hands (And I think that is very important because every hand is different) then you'll want to go into a shop. Most of the shops have knowledgeable people working that can tell you what you need to know about each item. If they don't know then they have somebody on the staff that does. I will say I have met Chuck Dorsey several times from Weaver and he is a leather genius. You can see him on their YouTube page. However with leather I like Wickett and Craig now that I'm charging a little more for my stuff and can afford it. However buying that from a local shop is impossible so I've had to bite the proverbial bullet and order offline. A general rule of shopping. If you don't absolutely love it in the store you'll never use it when you take it home.
  15. Finally enough I use my over stitcher to mark stitching holes if I'm going to do manual stuff without a pricking iron. I actually do have several in my drawer of different sizes. Now I know what it's actually for I'll try it and see how it works.
  16. I really like this setup. I use a tippman Boss myself and have struggled with the tensioning. Is there any way you would be willing to do a video on how you set this up? Potentially YouTube it. I would greatly appreciate it.
  17. Being as to Dwight is the godfather of leather. I'm going to for the hundredth time say I agree with Dwight 100%. Same method I use except the applicator. I use a sponge opposed to a bristle brush. Although now I'm probably going to harbor freight and buy $100 worth of bristle brushes. Pretty much open-ended answer at this point. I agree with Dwight.
  18. Unfortunately some of the chems that they add to the compound can cause a breakdown in the tanning process of your leather. Might not be noticeable at first but after a while you will start to notice the wear. Same thing with mink oil. Stuff smells great and for a quick fix is fine however pure needs foot oil is definitely the way to go.
  19. I fear that I am the only one that uses barges contact cement. I do remove it from the container and put it in a glue pot. If it starts to get a little bit too thick I'll hit it with some acetone to thin it out. It will last as long as the glue does. Weldwood works extremely well and is actually a lot thinner than barges. However I just can't get used to the smell.
  20. Thank you Dwight. As usual your advice is very handy and I appreciate it. I think I can concede to the man who has sold hundreds over several years and never had one returned for that purpose. That was the answer I needed and I appreciate it.
  21. I was gifted several 2 and 1/2 in straps from European leatherworks by a friend of mine who decided he did not have the patience for leatherwork. They are 10 to 12 oz which I will skive down to 10 oz to make it even throughout. I do not want to line the straps for economical purposes. I'm thinking I can make basic belts and sell them for a lower cost. Have several buckles that I have no overhead in either. I suppose my question is how do I pre-stretch the leather so that when the person puts the belt on and sweats in it it will not start to stretch over time? May not be possible but I have seen lower quality belts do that in the past. I do understand that the quality of the leather will make a difference and these are definitely not Wickett and Craig so that is why I figured I could sell them as economy belts maybe at a farmers market or something. But I still want people to feel like they got what they paid for.
  22. I use a cutting board and a mat. I will tell you about the cutting boards having bought one from Tandy. And please don't think that I am disrespecting Tandy because I do a lot of business with him. However I got one for a quarter of the price off of eBay same size and what seemed to be the same material as a replacement. It works absolutely perfectly. I do like the mat as well and just like the others on here I bought mine at Jo-Ann fabric. I think hobby lobby sells them as well maybe a little more expensive. Depending on your needs as to which one you will use. I do not recommend using a mat for punching holes with hammer punches. But the poly cutting board is good for keeping blade cuts and scratches off of your surface.
  23. I agree with Dwight that the sun tanning works really well with leather. I've done it for a few belts and holsters as well as Bible covers and the sun will tan the veg tan as long as you keep it moisturized. Another option is extra virgin olive oil. Not only will it darken the leather but it will make it very pliable. From what I understand listening to Don Gonzalez and Will gromley they are finding sandals from the Roman empire made of leather and that were tanned with virgin olive oil that are still pliable to this day.
