@Dwight I am a professional patch sewer. I sew for MCs. As such, I'd like to respectfully pass on this advice to you. If you intend to get into the patching business to make money, especially from bikers in MCs, don't dink around with f'n Chinese sh*t. Invest in either a good condition used Singer 29k71 or 29k72, or an Adler 30-1, -7, 0r -70. Also, try to find one that is already on a powered steel base. The Singer patchers were usually mounted on cast iron treadle bases that require a lot of foot power, plus hand spinning the balance wheel to get the treadle going in the right direction. The Adlers on steel power bases have 1/2 HP clutch motors that start spinning the right direction on their own. The clutch motors are easy to adjust for slack before they engage. Or, you can replace the motor with a servo motor to save weight, noise and heat. Here's the difference in bobbin sizes between the aforementioned models. The Singer 29k71 was made in Scotland and has a 12" arm, with a 5" vertical harp, and takes a small (read, tiny) bobbin that is 5/8 wide by just under 1/4 inch deep, outside. It only holds 3/16 X ~8/16 inches of thread inside. The nose is 1 inch wide by 7/8" deep and gets into tight front pockets. The balance wheel is mounted on the right read. It is best limited to Number 69 bonded nylon thread. Use a #18 round point needle. The Singer 29k72 has a 17 inch arm and takes a larger bobbin. The nose is 1.25 inches wide. It may struggle sewing patches onto front pockets if the patch is close to the sides or bottom of the pocket. It holds about twice as much thread. This model can sew with up to #138 thread. Use #69 for patches on thinner pockets, or #92 on thicker leathers. If you have to open the bottom or a side, use #138 thread with a #22 leather point needle to close them after your patches are sewn on. The needles to stock are #18, 19 and 22. The Singer patchers originally used system 29 needles, which are obsolete. They didn't have a cutout scarf. We now use System 135x 16 (leather) and 135x17 (cloth) needles, which are the same geometry, but have a scarf that the hook can pass through to pick off the thread loop. These machines are pretty much limited to a maximum sewn thickness of 5/16". But, I find they struggle past 1/4 inch. The Adler 30-1 has a small bobbin and an 18 inch long arm. The balance wheel in mounted on the front right side. Use #69 thread and a #18 round point needle for patches. The Adler 30-7 and 30-70 have 18: arms and take a Singer large bobbin and shuttle. They can easily sew with thread sizes from #69 through 138, and even #207 (on short seams). These Adlers use a much longer needle than the Singers: System 332LLG (round point) or 332 LLLG (leather point). Thus, they are able to walk and sew higher, sewing into 3/8 of an inch seams. I use the 29k71 to sew patches over front pockets, or inside pockets that the patch gets close to the inside of the pocket lining. I use the long arm machine to sew farther into big pockets that might have a thicker seam that the Singer can clear or sew through. I use the Adler about 90% of the time. Another difficulty you are going to experience is that a lot of the vests being sold now have a zip-open back lining for a cooling pad or bullet proof insert. The owners may not want that lining closed when you sew on club patches. For these jobs, a long arm Adler (or Claes) patcher is a must have machine. The Adler can get 18 inches in from the zipper before you need to start folding the bottom to get near the top for upper rockers. As for thread, buy good quality #69 (T70) bonded nylon or bonded polyester thread. Stock it in black, white, straw, light brown, medium brown, dark brown, red, bright yellow, gold, orange and some shades of blue and maybe green and gray. Buy Schmetz needles if possible. As mentioned, use #18 with #69 thread, top and bottom. Regarding invisible thread; it can sew over any color border. But, the stubs where you cut it are strong and can irritate the skin if they touch the rider's body. Monofilament doesn't lies as flat as twisted strands in bonded thread.
I have a CB4500 and it came with a t-bar bracket and roller guide. But, my roller guide has a cast or milled flange hanging down on the front edge. The flange stops the backward movement at about the center of the t-bar. It is not adjustable at all. I've had two ULS machines and neither of their roller edge guides were adjustable. They looked exactly like the one that came with my Cowboy, which was in 2012.
The main advantage of a lockstitch sewing machine is the stitches resemble each other on the top and bottom. As leather sewers, we are accustomed to a different result on the bottom and sometimes fight to hide the lockstitch knots from both sides. This stitch is very strong and can hold together somewhat if some of the stitches get cut, or simply break under stress. Off course. a lockstitch machines stops forming stitches the moment it runs out of bobbin thread. The answer to this is the chainstitch machine. It only has a top thread. There is a looper mechanism on the bottom, under the needle plate, which forms a loop around the thread on the bottom. The top will almost always look perfect, unless the tension is way too tight. The stitches are as strong as the thread rating. But, if one stitch breaks, the entire chain could unravel. In the days of yore, hard shell rifle cases, some boots and luggage were sewn on chainstitch machines. The loops were hidden behind material glued to the inside of the cases, or the insole on the boot. In many instances, the machine had a top mounted wax pot containing heated beeswax that the thread ran through. The hot wax hardened after a minute or so and those stitches could last a century. From the late 1800s through the mid-1900s, Puritan was the premier brand of needle and awl chainstitch machines. Some are still in use in the RedWing factory, making work boots using two or three needle chainstitch machines. But, now they usually run dry, bonded polyester thread.
The Landis 12 sole stitchers have a curved awl and curved barbed needle, called a "hook" in the shoe repair trade. They are only meant to sew the outside edge of a shoe or boot sole. Originally, they used linen thread run through a heated wax pot. In modern times, you can run bonded polyester thread in them, on top and in the bobbin. One notable oddity in these stitchers, vs modern industrial sewing machines, is that the huge flywheel is spun clockwise, away from you when you are in front of the machine. If you were to clamp a stack of veg-tan leather under the foot and rotate the wheel towards you, you will probably break the needle at the barbed tip. This is because the awl hasn't stabbed a hole for the needle to pass through. The correct operation calls for using an awl that is one size (number) larger than the needle. These machines typically run linen thread ranging from 6 to 10 cords. The shoe is sewn upside down, with the bottom facing up. As was mentioned earlier, Lisa Sorrell Bespoke Bootmaker, has a YouTube channel in which she has posted three video tutorials about her Landis curved needle sole stitcher. It's a Boot Life: threading the curved needle 12: Curved Needle Straight and Curved Needle Machines
Can’t get better customer service than Leather Machine Co.!
Wizcrafts replied to Timmmm's topic in Leather Sewing Machines
I've always gotten great service from both Leather Machine Company and Toledo Industrial Sewing Machines, on the phone, or via emails. Techsew has also been helpful when I had issues with a used model 2700 I bought locally.- 7 replies
- customer service
- cobra4
(and 2 more)
UL not tracking straight
Wizcrafts replied to Cumberland Highpower's topic in Leather Sewing Machines
Always try to use at least a #3 needle, or #4, if possible, when sewing heavy stacks or harness leather. The thicker needles experience less flexing. Use a correspondingly one size larger awl.. -
If I recall correctly, the needle is attached to a mounting bracket (aka: Needle Bar) that has rods on the front and back. The rods fit into a moving housing that has small 4 sided screws to secure them. It is possible to install the rods out of forward/backward equal alignment and still operate the feed. This would account for the left pull of the needle bar. Also, as unlikely as it may be, the needle bar housing could in theory be bent from a bad jam, like if the needle misses the hole on the way up and pushes up the leather, or worse, hits the throat plate. While a thinner (e.g., #1,2,3) needle would give before the needle bar, that might not be the case is someone used a very large needle, like a #5 or #6, to sew something very thick and dense with #554 thread. I mention the needle deflection because it happened to me more times that Carter has Little Liver Pills! -
Singer 111W152 Foot Height Adjust Questions
Wizcrafts replied to JBes97's topic in Leather Sewing Machines
The Singer 111w155 and 156 had the highest working foot height of that series. Previous models were more limited to typical upholstery height. My 211g156 has higher lift than my 111w103 -
Here is a link to Google Translate. You can input any language and translate it into English, or any other supported language. I use it to read and reply to non-English posts asking for assistance. It is fast and easy to use if you know how to copy and paste. Please don't shoot the messenger. I'm just offering a solution.
The first take-way is that your needle bar takes domestic needles that have a flat side on the top of the mounting shank. This leaves out using industrial sewing needles which are completely round at the top. The needle sizes in the manual were typical in the later 1800s and early 1900s. There is no reference to compare those numbers to the modern numbering systems. One would be to measure the diameter of the needle to create a cross reference. For instance, a #18 needle measures about .018" or 0.110mm diameter. That could be similar to one of the larger needles in that ancient manual. You'd need to actually get a pack of each size from somebody selling ancient stock. On a happier note, almost all domestic sewing machines still use a flatted shank needle. They are sold using the modern numbering system. You can buy packs in sizes from 9 up to 20. Most are round points for cloth. But, I've bought leather point needles in the domestic needle system HAx1, aka: 15x1. They sell them on Ebay.
I would use a #18 leather point needle with #69 bonded thread on the top and in the bobbin. Mind the alignment of the needle according to the manual. One side has a cutout scarf that must face the shuttle, which appears to be on the right. The other side has a rib for the thread to sit in as it goes through the eye. If the machine doesn't take standard domestic needles and sew, open the left endplate and look at the needle bar and locate the bolt that secures it to the crank that moves it up and down. If you can loosen that screw you can reposition it to accommodate modern needles, like System 135x16 and 135x17, which are about 1.75 inches long. You'd set the height so that the point of the shuttle intersects the needle about 1/8 to 3/32 inch above the eye on its upstroke. That's when the best loop is formed on the scarf side of the needle.. I used to fix old iron body sewing machines and resell them in an antiques shop where I was set up. The bullet shuttle machines or the late 1800s were able to sew 10-12 ounce bridle leather with up to #92 thread once properly set up and tensions tweaked. I used a #19 or 20 leather point needle to do that. They were Singer model 27 and 127 bullet shuttle domestic machines that were built like tanks.
@ethereal, if that's a piece of canvas, or denim, lose the tri-point needle and use a simple round point. The tri-points are for leather. They, like most other leather point configurations, will never look anywhere near the same on the top and bottom. Leather points tend to slice and rip the fibers in synthetics and regular cloth. Anything woven, or embroidered can be damaged by leather point needles. Once you get the round point needles, play with the top and bottom tensions until the knots are evenly hidden in the material. At that point the stitches will look as close as they ever will, for that machine. Also, play with the position of the check spring disk set screw in the curved slot. Some manuals refer to this adjuster as the thread control adjuster. It adds or subtracts some slack in the top thread to tighten or loosen the lay of the stitches. A looser stitch may look more uniform on the top and bottom. In fact, running with less overall tension usually makes for a prettier stitch appearance in cloth or light weight leather. Thin and soft leather can easily pucker if the top or bottom tensions are too strong. This distorts the lay of the thread.
Why is my sewing machine giving me these stitches?
Wizcrafts replied to Lugubrious's topic in Leather Sewing Machines
Oil inside the head. Cover all of the crank shafts and rods that move. This might loosen it up. Lower the feet and see if it moves freely with the feet down all the way. It could be that something slipped and when you tried sewing your usual thickness, the cranks bound up. There should be an adjustment on the rear of the machine where a shaft sticks out and connects to the cranks that move the feet. This shaft would be adjustable up and down by loosening a large screw on the joining knuckle on the back. You can set the alternating height to only what you need, and which avoids a lock up. -
Something is jamming the feed motion. It may be that the top or bottom thread is binding. It could be on top, or in the bobbin and shuttle. Remove the cover plate over the shuttle and inspect the entire area to see if there are threads wrapped around it. Pull on the bobbin thread and see if it is binding. Look to see if any thread is trapped around the spring latch that holds the bobbin in place. I've had this happen when I did some jerky starts and stops. I also have found the top thread jammed on the back side of the tension disks, instead of being inside them. Then I've had top thread twist around a thread guide and bring the proceedings to a halt. If none of the above applies, verify that the stitch length hasn't changed to almost nil. If it has shortened unexpectedly, a part inside the head may have slipped. See if the stitch length spindle affects the length as you turn it. Turning it in shortens the stitches, and vice versa. -
Yes, it still has a bobbin. But, when this machine came out, its bobbin was actually on one of the tiny spools they used to sell to home sewers. I have some of those wooden spools. People could stock up on the colors they needed on the bottom and sew for a long time before they had to swap spools. I can sew a long time on my cb4500 (441 clone), but rarely with thin thread like the home machines use. I'm not advocating for a new 2 spool machine, just comparing it to our current technology.
Is Pfaff 331 a good all-round sewing machine?
Wizcrafts replied to trikvart's topic in Leather Sewing Machines
I looked up the typical breaking strength of #46 bonded thread and it is just 7.5 pounds for nylon thread. Number 69 bonded nylon has 11 pounds breaking strength. You should take these numbers into consideration before buying the machine. IOW, it might sew the seams and hide the knots. But, will the seams hold up against any stresses trying to separate the stitches and pull them apart? -
WOW! That bottom spool resembles the bobbins in the 441 and 205 style machines. That ancient National 2 Spool was way ahead of its time. It's like having a Cowboy cb3200, 3500, or 4500 bobbin in a domestic machine using common cotton thread. Amazing!
Type of needle for thin pliable leather.
Wizcrafts replied to DG1's topic in Leather Sewing Machines
Leatherpoint of some shape. Match the needle size to the thread size. Most upholstery is sewn with either b69 or b92 thread using a #18 or #19 needle. -
Leather Sewing Machine Drive Belt Sizing (thickness)
A type 3L v-belt is 3/8 inches across the outside edge. If you must use a leather belt, use either a 5/16 or 3/8 inch diameter belt. But, expect slippage unless the belt is very tight at all times. The leather belts expand with use and the motor mount will need to be tightened now and then. If at all possible, buy a suitable v-belt. -
Is A Singer 153 K 102 Equal To A 31-15
Wizcrafts replied to Suemi's topic in Leather Sewing Machines
@Bugg, the only reason that this machine would not be great for leather flat presser foot. A flat foot machine like this one only has bottom feed. That's the same feed as virtually every domestic sewing machine. While a flat foot works fine with cloth, it drags leather and vinyl, or any bulky material. To overcome this limitation, Singer invented a so-called compound feed walking foot system. Their walking foot has triple feed, with the needle, inside foot and feed dog moving in sync as the presser foot lifts and lowers, pivoting off of the inside (alternating/vibrating) foot. Some versions of the Singer 153 have compound feed, like the 153w103 and 153k104. Unfortunately, yours isn't one of them. So, what can you do to make this a leather sewing machine? About the only thing that may be doable is to search for a roller foot and presser bar set that will fit into your machine. I don't know the specifics of that conversion. The bar would have to be the same exact diameter as the original. But, it would have to be shorter to accomodate the longer roller foot. This was just mentioned in a toopic in the leather sewing machines forum. If you are even able to obtain a roller foot and preser bar, you'll probably need to also find a single row feed dog and matching throat plate. This can get real tricky since Singer's industrial sewing machines has been out of business for many decades. -
Needle "system" 135x16 (leather point) or 135x17 (round/sharp point for cloth or synthetics) I use #69 (T70) bonded nylon thread to sew patches onto vests. If the leather is very thick, like a leather jacket, I'll move up to #92 (T90) thread. I almost never run #138 thread in a Singer patcher. It will wear out the feed mechanism, causing ever shorter stitches, and the little spring inside the needle bar, and possibly also the hole in the take up lever. Furthermore, the tiny bobbins can't hold much #138 thread.
@tedbow, I see Facebook "groups" that specialize in sewing machine repairs, modifications, and usage. If you're a Facebooker, you might want to search some of them out and join them on a trial basis. As for guilds, the only one I personally know about is the Crispin Colloquy. I suggest you start there. It has been a source of inside information about sewing for decades.
Needles breaking on Singer 15-91
Wizcrafts replied to lukeoliver1776's topic in Leather Sewing Machines
@lukeoliver1776 I spent a few minutes looking for leather point needles in size 120/19 and found some on Thread Exchange and on Amazon. I haven't looked on eBay yet and have to go to work soon. You're going to have to use a leather point needle for your project. A round point wont get it done without great difficulty. One thing I didn't mention if foot pressure. Did you know that broken needles and kipped stitches can be caused by insufficient presser foot pressure? This is because the leather or other material can lift up with the ascending needle. This is always bad and could be part of your problem. Crank down the foot pressure screw a couple of turns and try again. But, either get #19 needle or use #69 thread with the #18 you have on hand. -
Tex 90 thread requires a #19 or #20 needle. Your #18 needles hold the thread too tight and poke a hole that is too small to pull the knots up inside the layers. Thread Exchange sells Schmetz needles for your machine in #19, here. Try them and see if they work for you. Put some grease on the gears inside the head where the motor output gear drives the guts. Don't put oil in the motor. If it has cups with lids, they are probably for special grease that is available in syringes. Otherwise, use sewing machine oil in every oil hole and connecting rod inside the front cover. Hopefully, this will loosen up the drive. If your foot controller is old, it may have lost resistance at the startup position. You can replace it with a modern solid state controller. I am telling you all of this because I used to service and resell old Singer iron body machines. The 15-91 was a solid seller and I was able to sew 8-9 ounce bridle leather belting with #92 thread, using a #19 or 20 leather point needle. But, if the controller was worn, the motor lacked punching power. I have a page on one of my websites that is about the Singer 15-91. Maybe you'll find something there that helps you. It has manuals too. -
Video: Durkopp Adler 205-370 Operating Guide
Wizcrafts replied to Uwe's topic in Leather Sewing Machines
No. You can use a thinner needle than the spacer width. It's job is to protect the hook when using a large needle.that could actually damage the tip. However, if you regularly sew with smaller needles, like #18 to 22, you might get better results by using a shim for a #22 needle. This puts the hook closer to the thin needle and the thread loop. Thinner needles actually get deflected slightly to the left as you sew on most lockstitch machines. The thread tension pulls the needle away from the hook unless I back off both tensions and have a looser stitch line. The longer and thinner the needle, the greater the deflection from thread tension alone. My Cowboy cb4500 and all of its related class 441 machines do not use hook spacer shims. I set my hook to work with the largest needle I regularly use and leave it there. I compensate for needle deflection by tweaking my check spring settings to give more top thread slack, creating a larger loop for the hook on the upstroke, and by backing off the tensions when using thin needles and thread. I rarely get skipped stitches. But, when I do, I tweak the spring again, or loosen the tensions more, or slow way down (a hot needle burns and holds leather fibers and creates more friction). Sometimes, if the inside foot rises up a little early, the leather lifts with the ascending needle and that causes skipped stitches. It happens mostly when I use a left or right toe foot instead of the standard double toe foot. I did install a narrow feed dog and throat plate set purchased from one of our members, and am limited to a #25 needle as the largest size. If I need to use a #26 or 27 needle, I have to change back to the standard feed dog and throat plate. I also have an even smaller profile set from @Patrick1that maxes out with a #22 needle. I use it to hem jeans or sew on soft cloth or very thin leather. It only takes a couple minutes to swap the feeder sets.
