Everything posted by terrymac
Gator Wallet
terrymac replied to Chief31794's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
If you feather the edge of the gator as thin as possible, it will burnish and edge just fine. Look at some of Bobby Park's (Hidepounder) work and you can see what I am talking about. The edges on the items I have made look great. Terry -
For 6 stitches per inch, either 1mm or .8mm will work. When you get to 8 or more stitches per inch, the .6mm becomes more appropriate. Hope this help Terry
Problems With Fiebings Antique Finish Paste
terrymac replied to KBCustom's topic in How Do I Do That?
Clearlac is an excellent finish for antique paste,as well as a resist. It will stop the splotcchy effect you can get with the paste on some leathers. Terry -
High Contrasted Antiquing On Natural Colored Leather
terrymac replied to addieleigh's topic in How Do I Do That?
The key is getting good cover with your resist(Wyosheen or Clealac). Both products are one in the same. I use antique paste without Tankote, and get all the antique off by using wool pads to wipe. Just keep getting new pads until you have removed all the paste. I use the synthetic wool pads from Tandy, and cut them in half. Tankote will remove some the color and can be used to thin the paste. Never liked the resulting color as a result of thinning. If you are using a different resist, then all bets are off Terry -
Gluing Edges Instead Of Stitching
terrymac replied to seabee's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It will eventually come apart. Terry -
Problem When Antiquing With Wool
terrymac replied to Oceanstreetleatherco's topic in How Do I Do That?
Could not tell you, have never used the stuff. Strictly a Clearlac user. Terry -
Use Clearlac as a resist before applying antique paste. Never experienced problem using wool. Terry -
Watch the Nigel Armitage videos. He is also left handed and does not seem to bother him at all. Terry
It must really a trade secret as I have no clue to what you are talking about. Tallow??? Terry
Finish with Neatlac ( Clearlac) That is what Hidepounder uses on all of goods. Terry
Springfield Leather sells the Barge Thinner. Advertise on this site Terry
Recommended Drive Punches...and How To Sharpen Them?
terrymac replied to SantaFeMarie's topic in Leather Tools
For larger sized punches, I use my Dremel with a cone shaped grinding stone and lightly insert into the drive punch. For smaller, Barry King sells round, tapered diamond stone that works well. The strop as explained above. Hope this helps, Terry -
Get a pair of smooth jaw pliers, I use them all the time. When you get to the point you have to do some backstitching, pliers are the only way I can get the thread pulled. Watch some of Nigel Armitage's videos, he uses pliers extensively. Hope this helps, Terry
Rediculously Simple Question : Sharpening A Swivel Knife
terrymac replied to lydian8's topic in How Do I Do That?
SK3 from Leather Wrangler gets my vote. Paul has come up with metal alloy that stays sharper longer than anything I have ever used. If you are just starting, I don't think an angle blade is the way to go. Flat blades are a lot easier the use, and angle blades present their own problems with sharpening. Regardless of brand you choose, having a sharp blade is the most important consideration you have. Most people don't have a clue what a sharp blade is, and the Leather Wrangler comes sharp and ready to go to work. Hope this helps, Terry -
Isn't is amazing how the old, tried and proven products work better than others. Maybe those old time saddle makers knew what they were doing after all. It is good to know about the Waterstains as I have just started playing with them.. I tried Clearlac with the Ecoflo antiques and ended up with a mess, bunch of the ugliest colors I have ever seen. I threw them all away. Clearlac is also available from Sheridan Leathers except they label it "Wyosheen" Terry
Saddlelac is a Fiebings product. I will add that Clearlac works as a finish over the Ecoflo products. I agree with Nev, if it ain't broke, don't fix it. Terry
- 14 replies
- eco-flow
- waterstain
(and 5 more)
Sorry gang, Saddlelac and Neatlac are two different animals, unless Saddlelac has changed their product. I only use Clearlac in the pourable form. Neatlac used to be available as a spray, but people had problems. When the Eco antiques firts came out, I tried using them along with Clearlac as a resist. Got the ugliest bunch of colors you ever saw. Ended up throwing them all away. Fiebing antique pastes work well with Clearly. Terry
- 14 replies
- eco-flow
- waterstain
(and 5 more)
Appears to me to be the a moisture issue. The deepest part of your cut should also burning the darkest when beveled. Camino is probably right in that your moisture is not deep enough. Terry
You can do the same with dying the background, it just a matter of how much contrast you want between the various elements. I recently finished a belt where I dyed everything except the floral elements, applied Clearlac over everything, and then applied antique over the whole thing. Even if you apply the resist with a brush, the cuts will still be highlighted by the antique. One thing I will advise is to use wool when removing the excess, or you will never get it all and will end up with the mud puddle look. Terry
A brush will work fine. The question, what are you using for a resist? I antique all of my work, but only use Clearlac as the resist, and Findings antique paste. I tried the Ecoflo stuff and threw it all away. Same with the resist which I was told would work as well as the Clearlac. I use a pointed brush on the tooling leaving the background alone, or alot of times dying the background, and using the antique to highlight the cuts and bookmarks as you are wanting to do. Look at some of Hidepounder' work, and you will see what I am talking about. Hope this helps, Terry
The EZE LAP diamond stone set works great. Just remember you have to set the clamp on one side and sharpen the opposite, both sides. When you go finish this side, then move clamp to the other side. The clamp has a 15 degree option that will get a round knife scary sharp. If you do not move the clamp, the angle will be wrong for the side it is attached. Just keep a band aid handy. Terry
Get yourself a bottle of "Bee's Saddle Oil w/fungicide". I use their natural saddle oil all the time as it doesn't darken the leather as neatsfoot oil will. Good stuff and they advertise it for just the kind of problem you are having. Terry
Thanks guys, that is what I was looking for. No, I don't have a book for the splitter. Thanks again, Terry
