JLSleather
Contributing Member
Everything posted by JLSleather
  1. I guess you're talking about stamping / carving tools? The number and type will depend on the type and size of work you'll be doing. Here's a few not-necessarily-connected thoughts about that. If you're doing basket stamped designs on portfolios and belts, you could easily do that with 3 tools (and some do). No problem. If you're doing "western floral" or "sheridan" tooling, you could do MANY designs with 10 tools. Perhaps another 10 would add some variation in your work. Tandy and Craftool are huge names in leather (some don't like it, but it's true). Both of these will show you pictures of carved designs with tool numbers used. Many people have run out to purchase those exact tools, only to realize later this wasn't necessary (or perhaps not even desirable, if you want to be noticed). You don't need EVERY beveler, though a few different is helpful. Example? Craftool makes a smooth beveler about 1/8" wide, and they make another - same profile and smooth texture - more like 3/8 or 7/16" wide. You don't NEED both -- all your designs could be beveled with the small tool. The wider one WILL speed your work (big plus on a belt with a border). Brands. I use Craftool carving tools. It's what I learned with, back when. It's all I use. But I have older ones, and i can tell you the ones at the Tandy counter today are not the same. Step 2. A number of people have realized this, and formed companies making alternate tools at (what I personally think are ) out of control prices. I don't care who you are, I won't pay $50 for a single stamping tool. Nope. Maybe enough at this point. You can still find these older "craftools" (as they were abbreviated) on Ebay and such. Perhaps a collector or historian would want them ALL, but a leather worker doesn't need them. Obviously, if you're making belts you'll need some type of punch, and lacing or sewing will require needles ... etc. The cow head was done with 8 tools, including the floral design around it. Granted, most would agree this is not particularly good likeness of a cow, but - hey - it's trying that counts, yes? Oh, if it seems like this didn't actually answer your question, we still need to know the type of tooling you want to do OOOPSy That's TEN tools, if you count the swivel knife and modeling spoon, both of which you WILL want.
  2. OOOps .. my mistake. Same sites for those, down to size 18 http://www.campbell-randall.com/shop/index.php?route=product/search&filter_name=7x3 http://www.cutexsewingsupplies.com/servlet/Detail?category=Sewing+Machine+Needles%3A7X1+7X3+7X4+7X23+Needles&no=3798&param_referer=http%3A%2F%2Fwww.cutexsewingsupplies.com%2Fservlet%2FCategories%3Fcategory%3DSewing%2BMachine%2BNeedles%253A7X1%2B7X3%2B7X4%2B7X23%2BNeedles&searchpath=46222
  3. If you do a search (which I did) you'll find that same question being asked regularly since 2010 (and likely before that). But it seems your question is 'where can i see a listing, that when i click it someone sends me 794S needles in a 10 pack and i type in a card number?" NO? Okay, maybe that was me wondering that. I like the stitch made by the LL point myself. Skip the long speech about why, you can get those here (or not, suit yourself) in size 23 - 27. Dont like the LL? You can get 'D' 'S' and "LR' points at Campbell-Randall. 10 pks or 100 pks .. probably million packs somewhere, though i admit i didn't search those.
  4. That should work. The pattern shows a 24" gusset. I haven't made one of these since the 80's, so I don't remember how much adjusting I did. But, you can still get the entire pattern cheap and quick ... https://www.leathercraftlibrary.com/p-1162-holster-and-gun-belt-pattern-pack.aspx?
  5. pm sent
  6. You may want to think it from the other way around. Since you're not "set" on a brand, perhaps consider finding the dealer or service center in your area first, then see what they have or at least what they service. If holsters and knife sheaths are as heavy as you expect it to get, then you'll have a wide range of possible options. Leather will be 1/4 - 3/8" thick for most of those projects, so any machine capable of sewing 1/2" with up to about a 25 needle and 277 thread should be fine.
  7. Ooops.. sorry -- I thought I had mentioned the hand wheel slipping possibility. Good idea when things aren't what they should be.. drop the belt off the machine. If you can turn it by hand and still have the same problem, you have eliminated the motor as part of the problem. Plus, if the hand wheel is loose on the shaft, you'll probably catch that then.
  8. Most of the "dimple" appears to be from the leather being pushed into the bottom foot. Still, I think I would increase the top tension just slightly. You ideally want to NOT see the knots.
  9. Thanks, Bob. Probably should have boogered it a bit - I think the wench wife is going to buy one of these pistols now!
  10. I don't really have ONE reason why the belt slots are the way they are. Just the way we decided to do it with THAT model. General rule is -- keep it as small as possible while retaining the strength to support the weapon. In fact, size was rather the point of that Sig, yes? Otherwise, if you just need a 9mm, might as well go with a 5" barrel for the distance. Oversimplified, the leading edge slot is generally 'started' in line with the pistol slide. I say started, cuz it has happened where i put it in like that and didnt care for it. All the while, keeping a good bit outside the slot. But here's a sketch - with that general form, and slots vertical. The slots are as close to the weapon as they can be. But, obviously, not much left outside the slot - so how long before that becomes an issue.. So, you need to beef that up a bit, one way or another. Most common, stretch or sculpt. I personally think stretched looks . well.. less than thoughtful.. and sculpted, while doable, adds considerable time to the rig.
  11. Yep, that WAS the question. He said 4", but you know how that goes. They say they need a 38 belt too But, he DID say he had the 9mm, so we should be good. I didn't realize i didn't have one until he asked - nobody around here has 'em, or at least admits it! Worst case, it doesn't fit and he can send it back. No harm. 'Preciate the response, and the response time!
  12. I see ONE blue gun for the PPQ. Anybody know which model it is? I didn't see an email ...
  13. Thanks, fellas. Here's a "happy accident" I kinda liked. It was actually stitched with unwaxed white thread and then dip dyed black. Apparently the coating on the thread kept it from getting flat black. While I certainly didn't plan it, I'm hoping that will do that again! This one was for the Colt Commander.
  14. Checking in a bit - couple things I need to pop out so they can be drying .. According to this book (which does not say techsew) 21 is a "roller follower" and 7 is a presser bar guide bracket. I'll get you the part numbers (at least what they were when this 'edition' was printed) in a bit. $8 says that part number is valid whether it says techsew, cobra, cowboy, blahblah, and prolly some others too.
  15. No hype. No frills. No kiddin. Jus' soiid leather, done with a bit of care. Purdy. Straight. Forward ....
  16. That discolored area is your shuttle race. I don't know if that level of heat could ever be produced by operating the machine - even if it was oiled , say.. never. More likely, that part was broken (by impact) and received a less than stellar repair. You may be able to see an issue by removing it from the machine, setting it upside down so the bobbin assembly can turn in there, and then turning the shuttle / bobbin. I'm not there, but just looking at a picture, wouldn't be surprised to see a welded race had warped enough to cause picture 2. Guessin, still. The machine in the video doesn't say techsew, at least not above the paint job. Still, an idea of how that might look working. White thread used on top / black on bobbin just for easy viewing... https://www.youtube.com/watch?v=n7MVSikaYEk That other part, not sure which parts you are describing. what I THINK you are calling 'collar that rides the presser foot" is in fact a clamp (of sorts), and I'm not trying to be insulting when I say I assume that you have checked those screws for tightness.
  17. JLSleather
    Rhiannon
    Well, no harm done -- looks GOOD. Are your 'hi-lites' white, or natural leather? I steer from white dye, which has never been made well, and acrylics, which don't survive well on projects that flex ...
  18. JLSleather
    Rhiannon
    Nice work. You have some 'chop' in the beveling, but you clearly have an understanding of form and shadow, so I won't harp there
  19. Does the 227 use a spring inside the bobbin case? If that's missing, that will allow the bobbin to "spool"
  20. That .1 sounds about right. And that's about the difference in the length of the port. BUT, the length variation is TOWARD the butt, so not a big issue in molding the gun.
  21. Uhhh... that listing is like a year old?
  22. I like Charlie's design above, too, but I wonder if there's anything wrong with the idea of putting the stitched seam in FRONT on this one?
  23. I prefer to use them pre-fabbed where I can, simply because in the time it takes to make them, I could have made considerably more $ doing something else.. Or, the same $, for less time, which is as good. Still, I sometimes make 'em when I want one off the beaten path. Or, if all that's available is that cheap pigskin crap. Here's a couple I did not too far back, specifically requested done this way. This is actually quite a bit more work than it looks like, and you can bet that those who "fabricate" them for sale have a set up just for this - only way to make it pay is MASS produce. Any rate, one for a "billfold", one for a "long wallet" (or whatever the kids are calling them these days). OH, and I have used the Chaylor interiors, which are okay usually (not git-on-a-soap-box-wonderful, but okay).
  24. Definitely call Ron, seems like that would be the guy to see for your machine. Meanwhile, your "LR" needle may be rotated and not oriented quite right - that hole looks awfully oblong (l to r). Here's that pic again... this is a "LR" needle and an "S" needle, with everything else unchanged. 207 thread / #23 needle / 5.5 spi (or some metric equivalent)
  25. I'm gonna go with both airbrushed, though it's possible that the first was drum dyed that way (less the silly Greek stuff in white). But that second one, pull the airbrush trigger, and go around the piece. Simple. Takes 30 seconds .. maybe.
