Everything posted by BOB BRENNER
Shipping issues...USPS coming and going
BOB BRENNER replied to BruceGibson's topic in Leatherwork Conversation
I have also seen a slow down. I realize the Covid deal is the problem. But what I do not understand is how items are being routed. One first class item that was to go only about 70 miles from here in Colorado Springs took 8 days by way of Billings MT - an extra 1,200 miles. Another going 150 miles took 5 days and went from Colo Spgs to Denver back to Colo Spgs then to it's destination - an extra 200 miles. Last month shipped an item to Montana and one to Utah. Both went from Colo Spgs to Denver then to Iowa and back to Denver then on to their destinations - an extra 1,300+ miles. I track all items. Yesterday, got a notice that an item was being returned for Insufficient Address - going to a PO Box in a town of around 1000 people. Called the customer and the address is correct. Go figure! I think the system has been broken for some time and Covid is the trigger. While the items do get delivered, the extra handling and transportation costs is costly and compounds to the USPS's overall problems. -
Inskirt riggings
BOB BRENNER replied to T Moore Medicine Hat Saddlery's topic in Saddle Construction
Each rigging dee or plate has its own requirements for installation. One rule I always follow is to use plugs on all inskirt riggings. Without plugs a ridge is created that over time with the stirrup leathers rubbing on the rig, will wear the leather down to the rigging. A couple of weeks ago at the Colorado Saddle Makers Assoc. we were working on some saddles for the Pine Ridge Indian Reservation and had a saddle with a 5053 rigging plate. On both sides of the saddle, the leather was worn away. Here are some examples. -
There are many choices when it comes to the foam for the insert. Would suggest an open cell or closed cell neoprene foam in the thickness required, with 1/4" to ½" common. I use 3/8" closed cell. Closed cell holds up a little better than open cell, but has a harder feel.
- 16 replies
- english saddle
- knee rolls
(and 2 more)
Powder River saddle
BOB BRENNER replied to compound's topic in Saddle Identification, Restoration & Repair
Power River Saddles was the store brand for the Denver Dry Goods Co. Denver Dry Goods was the major department store in Denver Co. They also owned the Heiser Saddle Co before selling it to Keyston Bros. -
This conversation is not appropriate on this forum. Request it be deleted
Do not want to discourage you In the project, but would advise that you do not use the tree pictured. Some of the rawhide lace stitching is broken and and there are a couple of places the rawhide is beginning to fracture. You are going to spend $1000.00 give or take in materials with a tree that questionable. Could endup as an expensive decoration.
An hourly labor rate based on the national median household income is $50.00 (rounded up) and the household poverty hourly labor rate is $17.00 (rounded up). So with 2 hours removing the stitches and 5 hours replacing them (7 hours of labor) - between $119.00 and $350.00 for labor. If one adds in overhead expense then $207.00 to $438.00. At minimum wage it would be $ 77.00 plus $88.00 for overhead or $165.00.
You might look into Goliger Leather in Ventura CA. 6-7 OZ "A" grade is $9.49 a foot.
- 14 replies
- slc
- hermann oak
(and 1 more)
Barry King
Matt, You need to find the Ordnance Memoranda for the model of McClellan you have. These Memoranda should give you the details. For example, stirrup leathers in the 1891 Memoranda are 1 3/8" wide, cut length is 56" with a finished length of 53"
removing stirrup leathers martha josey saddle
BOB BRENNER replied to cloehorse's topic in How Do I Do That?
Generally, when stirrup leathers are attached with a bolt, a "TEE" nut is used. The "TEE" nut is set into the bottom of the bar and has prongs that hold it in place. If these prongs were bent on installation or not griping the bolt and nut will spin. You will have to drop the skirts and replace the "TEE" nut. Depending on the construction method you may have to cut out the fiberglass covering to replace the nut. It is a pain in the rear end. This method of attaching the stirrup leathers is a take off of the Fallis balance ride saddle known as the Monty Forman saddle. When this happens I charge double my regular charge for replacing the leathers. You will spend more time fixing the nut than replacing the leathers. Have fun. Bob -
Got an interesting letter from Weaver today. As of April 1, 2016 if your do not buy $1,200.00 in 2016 you will lose your wholesale account. You will be able to buy at retail or you can buy a wholesale membership for $200.00 that is non-refundable. Can you say super Tandy?
Can A Western Saddle Seat Be Replaced?
BOB BRENNER replied to CourtneyLynn's topic in Saddle Construction
Yes it can be done, but the cost will probably be more than the saddle is worth. Replace the seat $500.00 to $700.00. Replace fenders $240.00 to $300.00. So could spend $740.00 to $1,000.00 and have a saddle worth $400.00. Best to look for a new saddle. -
I agree with Keith’s thoughts. Saddle making in my observation is a time warp in respects to the old or traditional ways. If any industry is to be viable is must innovate. It has been my experience, that saddle makers by in large resist innovation. For example, should a tree that is ten times stronger, 90% lighter, with the same qualitites and at a similar price of a wood tree covered with rawhide be rejected because it is not traditional? Think carbon fiber in ten or fifteen years. As to the question at hand. I have heard and have been told many times that when building a saddle you must be very careful to not cut into the rawhide as that will weaken the rawhide and lead to failure of the tree, which I understand. But, then we drill 1/4" to 3/8” holes in some of the weakest points in the saddle tree. A cut is bad but several holes are OK? Think about it. This is something I have never understood and never received a reasonable answer other than it is traditional. If tradition is the way to go then cowboys need to do away with the internet, smart phones, GPS, etc. Just an old saddle maker’s opinion.
I use 11/13 oz in my trail saddles. What the others have said is good advice. Building a light weight saddle requires a different set of construction techniques and a different thought process than a conventional saddle. The only way you can reduce the weight is reduce the amount of materials used, i.e. 2 ½" stirrup leathers, smaller fenders, smaller round skirts, etc. It’s 5 oz here, ½ lb there, 9 oz over there, and so on. Also, you need to use a tree with a built-in seat strainer or ground seat. I have been refining my light weight trail “traditional”saddles for over twenty years and so far the best I can do is about 28 pounds fully rigged. I also, make another trail saddle with a Ralide tree “the saddle Gods are not happy” that comes in at around 24 to 25 pounds. Here are some examples. Currently about 75% of my business is trail saddles. Respectfully, Bob Brenner
I Have 1St Choice On O.f. Bard Leather Secrets 1951.
BOB BRENNER replied to Cogs's topic in Leatherwork Conversation
Bruce, I have the first copy that came off the press. They have a name for the first copy off the press but I can't remember the name. Given to me by the printer in 1980. The original printing was done by Out West Printing here in Colorado Springs. Also, have an original design and tooling pattern for a "Western" purse by FO done in 1953. A friend of mine had a saddle shop and when he got into a bind, FO would come down and get him back on track and he gave me the purse design. Bob -
Denise and Rod, I always enjoy you insightful comments, you are ahead of the curve. Your info on flexible bars answered the question to my next research project. In your other reference the comments by Watsabaugh and Severe were very helpful. So, thanks. Also, and this is for every one. This weekend I was down at Harry Vold’s place helping them get ready for their summer run when Harry said you need to see something. I just about died. There was a saddle tree with the swell made out of a tree fork and a cantle made out of the bend in a limb. The person that gave to him said his great grandfather used it. I’m thinking around the time of the Civil War. Did not have my camera and my cell phone is an antique like me and doesn’t have one. Will get pictures this fall.
oltoot, Thanks, I figured that would be your answer, as I talked to Sonny several years ago and he gave me the same answer. Makes sense and I agree. The problem as I see it is that this test only indicates that the tree has the properties to flex and therefore, does not suggest that the tree will flex during use. The test was static. During actual use everything is dynamic with other factors and forces being introduced that may or may not cancel out the results of the static test. Randy, Thanks, How did I arrive at the comments in my post like: "a tree would flex regardless of the covering"? Is the question. The only way I can see to test this is a computer model, as how would one put all the equipment needed on a horse, saddle, and rider in the roping arena. Bob
Stephen, I would suggest that you first give them a call and explain that situation and see what their response is. No matter the out come of the conversation follow up with an e-mail stating your understanding of the resolution or non-resolution. If positive: no problem If negative: with that dollar amount then legal advice is recommended. A letter from a lawyer can move mountains. Spending some money in this case is better than losing your business. Good luck, Bob
oltoot, I have heard what you said "...allowing just a bit of flex and rebound..." for years. What do you base your conclusions on? Randy, What principle or methodology are you using in your determination? Thanks, Bob
Thanks for the replies. Let me rephrase the question. I have been told that a tree needs to have flex or “give” in it when roping or you can cause problems with the horse. Cowboy, ropers and saddle makers have said to me that the flex or “give” is needed disperse the force of roping on the withers of the horse. My question is: How do we know a rawhide covered tree flexes and a fiberglass covered tree does not? Troy, Understand. Many moons ago I threw a loop on a big bull, heard a pop and saw my swell bouncing behind the bull. Bob
Here is a question that may open a big can of worms. This question has been on my mind for many many years like a itch I can’t scratch. While at the Sheridan leather show this year, I was ask if I used wood trees covered with fiberglass and resin, to which I said I had switched to them several years ago. With that answer I was told you can’t use them because they will not flex like a rawhide covered tree, especially when roping. I have heard that statement made by other saddle makers for years and I have not understood the explanations. So, the question is: Will a rawhide covered tree flex and if so, why??? Bob
