Everything posted by Gregg From Keystone Sewing
Questions about 206RB feed eccentric motion
Gregg From Keystone Sewing replied to Dave4's topic in Leather Sewing Machines
Page #18 , "(10) Feed cam timing" has some information about this, however it may differ from the settings on the Consew 206RB or Seiko STH-8BLD-3. LU-1500N Engineers Manual.pdf -
Seiko STH-8BLD-3 Owners and Service Guide Check out section 8-5 Adjusting the needle with feed timing -
Bass guitar strap
Gregg From Keystone Sewing commented on dragonspit's gallery image in Our Leatherwork Galleries
Singer 241-11 Stitch Regulator Jam
Gregg From Keystone Sewing replied to audiohauz's topic in Leather Sewing Machines
I can make a video and post to YouTube. I've never had a problem doing it my way, and would like to share. And I'm certainly not saying my way is the best way. -
This is very common on 241s and machines of other classes with this type of stitch length regulator. *I usually get a dowel pin, push it into the screw hole for the handwheel set screws, and pull. *Make sure you know what direction to pull, clock or counter clockwise, or you can break the machine. This will depend on if the machine is jammed in the longest or shortest stitch length. -
Pfaff Timing Belt
Gregg From Keystone Sewing replied to trash treasure's topic in Leather Sewing Machines
Not going to help with this here, but I've attached the Pfaff 463 service manual that does not cover belt install. 463 463H(3-86.pdf -
New (to me) machine for skate tongues
Gregg From Keystone Sewing replied to Hockeymender's topic in Leather Sewing Machines
Like said, nice looking machine. -
Check spring range of motion
This information at the one minute mark...is impossible to find. The only place I remember reading this is, actually in the 111W manual. None of any of the modern manuals for many machines that use the same tension go into this in the owners or even engineers manuals, yet the thread controller stop is a critical setting. -
Small Motor Pulley with 5/8" Bore?
Gregg From Keystone Sewing replied to Pintodeluxe's topic in Leather Sewing Machines
McMaster-Carr is awesome, I buy a lot of stuff from them. A lot of hard to find stuff shows up at my door a day after ordering, they must have a warehouse close by to me. -
Shrinking the Table
Gregg From Keystone Sewing replied to bcurrier's topic in Leather Sewing Machines
The Merrow stand is big bucks.- 11 replies
- sewing machine
- 441
(and 1 more)
*I got 14.89mm, .0586", or .37/64" or 19/32" if you will. *Not exactly the 5/8" I was thinking of, I need to check my numbers again! -
JustPaul, I think one of the ladies you spoke with were a bit confused, and sorry if you felt like we blew you off. Nothing of the sort. See attached images, hope these help. 5/8" is the drill hole size, see approximate where to drill this hole. All of this said, often our table suppliers drill this hole for the table pin hinge, and as that may sound convenient, it's not always in the correct spot for your specific machine. It's a toss up to start drilling holes in the table or not. Anything else, please call or email, I'm eager to help. Gregg
5/8" bore pulley is very common for many new servo motors. Consew's clutch motor from I think the sixties and seventies made in Japan had this pulley bore. -
Recommend vintage textile machine with reverse
Consew and Mitsubishi Twin-Needle machines
Gregg From Keystone Sewing replied to Ogoki's topic in Leather Sewing Machines
Mitsubishi is a needle feed, the Consew is a walking foot. Gauge sets are very easy to get for both and common, and not too crazy expensive. -
Who is our Pfaff expert?
Gregg From Keystone Sewing replied to olds cool's topic in Leather Sewing Machines
91-010002-05/000 is $173.25 Pfaff list price. Replacing this top arm shaft is about as big a job as you can have with a machine like this, I would recommend thinking twice before investing money in a machine like this. Finding one used can be hard, and I'm only assuming that the machine was working well before it was dropped. I would check the casting to make sure that there are no cracks elsewhere as well. Hope this helps. -
Juki 158 Double needle thread
Gregg From Keystone Sewing replied to biggdave92's topic in Leather Sewing Machines
ROT (Right Outside Twist, also called an S twisted thread) would help, but also make sure you are using bonded thread, that remains one cord if you twist in between your fingers a few times. -
Consew 206RB, RB-1 Parts CLICK HERE Consew 206RB, RB-1 Owners CLICK HERE
Bobbin Loading Issues
Gregg From Keystone Sewing replied to Chelsie44's topic in Leather Sewing Machines
Make sure the feed dog carrier is set to the correct height. I've checked the owners book and it does not cover this. When you cycle the machine by hand, the bottom valley of the feed dog should be at the same level of the needle plate. Hope that helps. -
Source for type I bobbins?
Gregg From Keystone Sewing replied to KateC's topic in Leather Sewing Machines
Never heard of I type, but I'm sure it's out there. A, G, S, L, M, and U are the more common type. -
That the way to do it, good job getting it done.
T563 is a good quality machine, pretty sure made in Taiwan. You should be able to obtain parts that you need for about $150 or so, from what you described. Juki LU-563 parts often cross reference with other machine makes and models, and any supplier I can think of has a lot of spare quality generic parts for this machine. Not to mention genuine Juki as well. You will not have to search far to find the parts you need, and they should not cost a crazy amount. In contrast, as comes up on this message board frequently, if this were a Pfaff or Adler, you can forget it with parts like that missing. But that's not really the case here at all in my opinion.
