                Posts1,212
Everything posted by Gregg From Keystone Sewing
	  Tacsew T111-155 Needles?Gregg From Keystone Sewing replied to rfkoen's topic in Leather Sewing Machines Suzelle, I'm only giving the systems, by the book, 'from the factory' specs. Pfaff would never from the factory send any 145, 545, or 1245 with a 135X17 system needle; only either 134-35, or a 190 system, depending on model or subclass. Now, is this the 1st time I've ever heard of someone using a 135X17 in a Pfaff machine? No, it's not. But I would have to say, if I sent out a Pfaff new or reconditioned with a 135X17 needle, I would have a hard time explaining. It's kind of putting the wrong size tires on a car, but the car will still drive anyway. Doesn't make it right, but if it works for your, that's all that matters. You and many others may have been sewing on a 145 with 135X17 needles for 20 years with no problems, so doing things by the book so to speak is not always important. That said, if I wanted to get a Pfaff machine back in order, and I was learning to make adjustments by using thier books, you can believe I would want the correct needle system; it's one less variable I have to worry about or compensate for.
	  Tacsew T111-155 Needles?Gregg From Keystone Sewing replied to rfkoen's topic in Leather Sewing Machines Just to be clear here; From the factory, Tacsew T111-155 takes a 135X17 (not a 135X7, shorter needle, but same shank, the part that goes up into the needle bar. Durkopp Adler 167/267 series take 134-35 (not a 135X17). Pfaff 145/545 take a 134-35, BUT take a 190R system needle for high lift machines, such as a 145-H4, or 545-H4.
	Timing on a 7-33 is 5/32" needle rise from hook point to center needle with the needle bar starting at the bottom most point. The machine's timing, from the factory, and from anybody for that matter, is pinned with taper pins. Going from the handwheel, the top shaft has a U in it, that drives the main connecting rod, that drives the large forked crank with slide block lower in the machine arm. The slide block is connected to the crank that is pinned onto the hook driving shaft. On the opposite side of the hook driving shaft is the hook driver, that is also pinned onto the hook driving shaft. Both crank and driver have a set screw, but they are really only for setting the parts, the pins are doing the work. So...I would check that one of the pins are not broken. You can put a mark from the driver and crank onto the shaft, and see if they move independently, this would show if that one of the pins are broken. Other than that, the needle bar height is what you have to adjust here.
	I'm only trying to help, but what is it either it's a 144W302 or it's something else. W stands for Wheeler & Wilson factory in Bridgeport, Connecticut. SV stands for Special Variety; to the very best of my understanding, this means one of two things; the machine was modified for a special application, and or the machine was made during war time where some items were substituted. I'm sure of the 1st one, not confirmed on the send part. I think this does nothing to help your situation, but your asking, I have a Ford F-150, but it could be a Ford Escort, but I'm not quite sure. This is probably why your not getting a straight answer. If you can, upload some pics, so we can see what you are looking at, this would give us all a starting point.
	  Consew Clutch MotorGregg From Keystone Sewing replied to tnawrot2's topic in Leather Sewing Machines Excellent, glad to help.
	  Consew Clutch MotorGregg From Keystone Sewing replied to tnawrot2's topic in Leather Sewing Machines If this is a Consew 'Premier II' 3/4 HP clutch motor, I know EXACTLY the problem, and it's not what many would think; they had some damn heavy grease/glue, new out of the box, that was, well, wrong with the clutch sleeve. It would stick like glue and not allow the clutch arm to return properly. I'll get right into it, since I have done dozens of these, follow by the numbers, hope this helps. Click image to enlarge. I feel your pain, and it took me a bit of head scratching to finally figure out what was going on. This was about five years or maybe a bit more these motors were new out of the box with these problems. Hope this helps, I am pretty sure you be up and running after this fix.
	  Singer 269W Bar TackerGregg From Keystone Sewing replied to Constabulary's topic in Leather Sewing Machines I certainly don't speak for Robert at Camatron, but I know he would tell you the same thing (because Robert and I have had discussions about these machines, the Singer 269W specifically); LK-980 and certainly Singer 269W machines are dead as a door nail as far as new conversions go. Nobody USA is going to convert a 269W or Juki LK-980 from one cam to another; if you have for example a bar tacker or converted machine to do the specific application, or one that you can at least use, your in the clear, and even with that, I would not spend more than a few hundred bucks. Parts and service could be a tall order as well. Hope this helps.
	  German Adler Czec AdlerGregg From Keystone Sewing replied to truenorth's topic in Leather Sewing Machines Basically, your asking someone for their opinion, so I'll try to offer mine; nobody ever complains about the quality or workmanship of the German made Durkopp Adler machines. The Durkopp Adler machines made in the Czech Republic, from what I have seen are nothing but top quality as well, especially by today's standards. As far as I know, the 205 series from Durkopp Adler was never made outside of Germany or the Czech Republic. Again, this is only my opinion, but I would be happy with either 205 model, but some here may have a different opinion on this matter.
	  3 Possible Adlers And 1 SingerGregg From Keystone Sewing replied to tomstas's topic in Leather Sewing Machines Automation direct is one of my secret weapons; they have great products, services, and ship fast. I've spent $,1,000s of dollars with them over the past few years.
	  3 Possible Adlers And 1 SingerGregg From Keystone Sewing replied to tomstas's topic in Leather Sewing Machines I can help a bit here; The original 267s were all made in Germany, and, to the best of my knowledge, all were grey or hammer grey paint. These have been discontinued for some time now. The white ones, again, to the best of my knowledge, came from China at first. These were 267-373 models. This factory that made this model is,again, no longer. We called to restock, and were told that the factory was flattened in China. They didn't have any 267 models for a good number of years after this. Now, currently , today, Durkopp Adler has another made in China 267-373. They use the same model number, but this machine does differ from previous models in that the reverse lever is push down instead of lift up for reverse. See image of this new model DA 267-373 below; As for the full function underbed trimmer model, make sure you have the required power, often it can be 3 phase 220V, and many folks don't have this available.
	  What Edge Guide For A Singer 111W155Gregg From Keystone Sewing replied to TomG's topic in Leather Sewing Machines TomG, There are lots of edge guides available, but someone would have to know what type you would like. Are you asking about a swing down guide? A T-edge guide? Roller guide on plate also? The swing guide is not going to be a direct bolt on item on Singer 111W155, and screws would have to be tapped where the guide would attach to the machine.
	  Pulley Keeps Falling OffGregg From Keystone Sewing replied to mathbishop's topic in Leather Sewing Machines
	  Pulley Keeps Falling OffGregg From Keystone Sewing replied to mathbishop's topic in Leather Sewing Machines I had to save the original picture, open it in Photoshop, and lighten the image to see what is going on. Here is the pulley type with Singer part numbers. You should be able to find them pretty easily.
	  Loose Bobbin Basket (Video)Gregg From Keystone Sewing replied to thesergeant's topic in Leather Sewing Machines That hook, for sure, has a lot of play, and may effect the sewing of the machine, for sure. If that were a repair, we would replace the hook, and we don't take that lightly, as these replacement hooks are not inexpensive.
	  Consew 206Rb-2 Vs 206Rb-5Gregg From Keystone Sewing replied to cark's topic in Leather Sewing Machines Common needles are system 135X17, common canvas needle sizes are say 20~22, depending on thickness and density of work.
	Well, IMHO anything is an improvement, I've never recommended the CS-550 to anybody for anything. Again, I like other Consew motors the sell, and a variety of others as well.
	Yeah, saw this, too. Impressive looking machine, but 1st thing I though like many here "OK, what's the price?"
- 79 replies
		- 967 h type
- 969 h type
					(and 1 more)
	  Patching Sewing MachinesGregg From Keystone Sewing replied to RoyalLeatherDesigns's topic in Leather Sewing Machines I think the time has come around these parts to just pin a topic "All things Singer 29 class and clones click here".
	  Consew 206Rb-2 Vs 206Rb-5Gregg From Keystone Sewing replied to cark's topic in Leather Sewing Machines Consew 206RB-2 is made by Seiko Sewing Machine Company, Japan. Sold under the Sieko brand, model is STH-8B. 206RB-2 is a very good machine. Reverse, as said, is lift up, with the stitch length on a ratchet ring on the lever. Stitch length is 3 Stitches per inch, presser foot lift at the knee lifter is slightly less than Consew 206RB-5, but only because of the knee lifter bell crank that is different. New style that appears on -3, -4, & -5 with roller provide additional lift at the knee lifter on any model. Consew 206RB-5 has the press down reverse, and uses a stitch length dial. Max. stitch length is 2-1/2 Stitches per inch. Presser foot lift when set correctly is 9/16".
	That has been my experience with the Consew CSM-550, it has the control of a light switch. It's not just your motor. Consew has better motors than this one for sure, CS-1000 comes to mind.
	  Consew 206Rb-2 Vs 206Rb-5Gregg From Keystone Sewing replied to cark's topic in Leather Sewing Machines I'm a little late now, but did you buy the -2?
	Warms my heart, thanks. I had a Bernina 217 commercial zig zag, a Consew 206RB-1 (until I had to bring it back to the shop for a sale) and now the 211A reg. bobbin walking foot with reverse. Like I tell folks, I sell the paint brushes, but I'm no Picasso. I do simple repairs and patches on Judo/Jui-Jujitsu gi and kimonos, patches, and hemming pants for the most part. I always find things to sew up, and used the machine last at home a few days ago actually. My next thing I want to do is work more with the embroidery machine line that we sell, so I can learn more about it, doing it, and teaching embroidery. This means I better have some kind of a handle on the equipment and software, and I'm on the path. Just need more time, and people will be able to see shirts, towels, duffle bags, you name it, with embroidery at my home.
