Everything posted by Gregg From Keystone Sewing
Singer 132 K6 Question
Gregg From Keystone Sewing replied to Mitchell's topic in Leather Sewing Machines
I think you are on the correct path, Singer 132K6 is a capable machine, much heavier capacity than a standard canvas and upholstery machine. I think it would be great for that kind of application, and the foot lifts more than the 10mm you need. -
Adler 267-373 Problem
Gregg From Keystone Sewing replied to chiocciola's topic in Leather Sewing Machines
http://www.keysew.com/Webpages/DemoImages/Adler267ServiceBook.pdf Check out this attached book, hope it helps. -
Seiko Ch-8B Or Singer 45B8Bc
Gregg From Keystone Sewing replied to MLCook's topic in Leather Sewing Machines
See attached, this may be a better book than what you have for this Seiko made machine. Consew757R.pdf -
Best Motor For Adler 867?
Gregg From Keystone Sewing replied to The Dawg Club's topic in Leather Sewing Machines
I was told from Efka America that the DC-1250 is not ready yet, and that I was advised to stick with what I was used to, the DC-1550 with AB321 controller. BTW...if you really want to see the differences for yourself between DA and AB per say, the best thing to do is download the available owners and parameter lists and cross reference them. Like said, don't think you'll be at all limited with either or on a general lock stitch or chain stitch setup, but don't quote me or hold me to it. -
My suggestions are this; If possible, find a local enough dealer and ask for a demo with your samples and thread. If you can't show up anywhere, at the very least send the samples of materials and thread you want to use to someone who can work with the test samples and send either pics or the sewn samples back to you. Also note, and it's not too hard for a guy who knows a bit about this machine, but this machine ships from the factory setup with a size 14 needle, and the larger size 18 is likely to deflect off the hook point unless moved slightly away. Each machine is going to be different here. Tensions, upper and lower bobbin case tension, would have to be adjusted. Keep in mind max. thread size is V69 as well. Hope this helps, the worst thing that can happen is that you buy a machine that will not do what you want. Clearly, this would be going backwards.
Like said, the out of box setup is key. Eric made mention of an internal bobbin winder with O ring running off of a serrated metal plate. Lots of machines to this, and this is not at all a Highlead exclusive. And, like Eric said, I've seen lots of problems with the internal bobbin winders, but never one on a side table mount running off the motor drive belt.
Disconnected The Eps
Gregg From Keystone Sewing replied to VanDutch's topic in Leather Sewing Machines
What Ho Hsing motor are you referring to? I have setup and continue to work with a variety of functions and programming on Efka, Mitsubishi and Ho Hsing motors that I support and stock. I find the Ho Hsing to be at worst on par with the Ekfa and Mitsu motors, and in some cases, even more easy depending on what I'm doing. Ho Hsing has good support for us in the States as well, and Ho Hsing is very good with support for their equipment. I don't know the going rate for some of these products overseas, but full function motors used on underbed trimmer full function machines are about the same across the board. Mitsubishi nor Efka have low end motors, but Ho Hsing has a few items that are less money, less features, and perfect for a general lockstitch canvas upholstery machines that require low torque and low speed with needle positioning. -
Consew 255RB, RB-1, RB-2 all have max. SPI of 4, and use a push button on the bed of the machine and a turn of the handwheel forward or backward. Same a Singer 111W, Juki LU-563, and many, many other popular models. Consew 255RB-3 has max. SPI of 2 1/2, and is easy to differentiate from the predecessors by the stitch length dial that is on this machine to adjust the stitch length.
- 2 replies
- consew 255rb-2
- consew 206
(and 1 more)
Seiko Model Lsw-8Bl Maybe ?
Gregg From Keystone Sewing replied to ponypome's topic in Leather Sewing Machines
Nice machine, Consew's Flag Ship walking foot model, same as 255RB, 255RB-1. -
Singer Model 96-10 Vs. Model 31-15
Gregg From Keystone Sewing replied to Mike516's topic in Leather Sewing Machines
Singer 31-15 can do some heavy work, if you change feed, plate, needle, heavier than the 95/96 class. Singer 31-15 is an oscillating hook, better for heavy work than the rotating hook of a 95/96. Again, Wiz is correct, unless you are on a real shoestring budget, or are looking to grow into something, a walking foot is better suited for what you are doing. -
Ideal Stitch Length For Specific Thread Size?
Gregg From Keystone Sewing replied to BDAZ's topic in Leather Sewing Machines
Here is some more specific information I have on my Keystone file from A & E. Some interesting stuff buried in there. Seam-Engineering-2-5-10.pdf -
Like fine artwork, the value is what someone is willing to pay. Check out Ebay or Craigslist, see what they are going for. BTW...there is message board section here for selling used sewing equipment, Marketplace - Items For Sale - Machinery - Sewing and Stitching Good luck!
Singer 112W Gauge Sets
Gregg From Keystone Sewing replied to Texas Heritage Woodworks's topic in Leather Sewing Machines
Roger that. In case some folks care to know more about this, check out this page from Groz-Beckert attached. Groz-Beckert_Needles_Page7_doubleNeedle.pdf -
Everything is on point here gottaknow. One more thing I can add, some folks like to use a right twist thread in the left side hook, this should give the same performance as the left twist in the right needle. Not everyone has that stuff laying around, but if the top thread is heavy bonded, it should work well. -
First off, check that the vibrating/inside presser foot, when mounted, does not have excessive play side to side. Often, the same inside presser foot will contact the feed dog and get pushed to one side slightly. If that's all good, either swap the feet out for new ones, or grind off the sides until there is enough clearance. It's not that big of a deal, and they will work fine. Just make sure the needle goes straight down the center of the inside foot, so it does not deflect the needle or pinch the thread.
Juki 563-3 Specs Needed
Gregg From Keystone Sewing replied to oldskoolbob's topic in Leather Sewing Machines
http://www.keysew.com/Webpages/Owners&PartsBooks/Brochures/Juki_LU-562-3_ProductBrochure.pdf I uploaded Juki LU-562/3 and subclass brochure from way back when, specs are listed on the back second page. Two things that nobody may care about at all, but I've found so much information about machines that is not found in their parts or owners books, kind of like here. Also, Abco Sewing Machine Company stamped on the brochure was our previous company name and location between 1977~1980, so I'm sure this brochure is from during that time. Juki_LU-562-3_ProductBrochure.pdf -
Perfect timing, no pun intended??! Sorry, I can't help but squeeze some sewing machine humor in here, it's all I got! Really, glad to share, and it's a two way street, I learn a lot from folks here on the leatherworker. You can't replace decades of experience using this equipment that many carry with them here. In addition, I learn what speed bumps and obstacles people have getting up and running with their equipment. Folks that don't anticipate a learning curve with a new machine, new operator, etc., well that's just not realistic.
BTW, if you are making adjustments on any 206RB series, this is the book use here; http://www.keysew.com/Webpages/Owners&PartsBooks/PartsBooks/Consew206RB-5_SeikoSTH-8BLD-3.pdf
Parts book for Consew 206RB-1, as requested; http://keysew.com/webpages/Owners&PartsBooks/PartsBooks/206RB-1.pdf
Right, I just spoke with Don Ullrich at Durkopp Adler America, he is working on pricing for both the H and Eco models of this machine with two different price points and features.
- 79 replies
- 967 h type
- 969 h type
(and 1 more)
