Everything posted by Bob Blea
I would recommend againts a design where you have to carve across the fold on the wallet. The grain of the leather is the strongest part and if you cut through it with a swivel knife you are weaking the leather at that point. All the flexing across that fold will open up the cut and probably reduce the lifetime of the leather. At least that is what I was taught. Also, your right that when you fold it you are going to loose a lot of the definition in your carving. Bob
Making Boston Bag
Bob Blea replied to hunio's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks for sharing Hunio. It's always great to see your work! -
That is cool! Glad you were able to find one and thanks for sharing. Bob
Congratulations Steve! That is a great accomplishment for any business! Hope to be a customer of yours someday. Bob
Hello Leatherworshiper, and welcome to the forum. I have a leather hat that was made in Austrialia, though I'm not sure the design would be called an outback hat. I believe it is made from black latigo leather. hope this helps, Bob
I would think smaller items, the sort of thing that can be purchased more as an impulse buy. Key fobs, hair barettes, etc. If you make wallets or small purses, that might do well. At the craft fairs I have been at, the primary customers are women, so often you want items that will appeal to them either for their use or as a gift. Bob
Try going directly to Jeremiah Watts site: http://www.ranch2arena.com/hsbtintro.html. His stamps are sold under the Horseshoe brand. Bruce said this tool doesn't show up there but you might be able to contact him and see if he can make you one.
It depends on how detailed of carvings you are planning on doing, but for regular floral carving that might be a bit too small, just in my opinion. I would want the next size up from that. Bob
Barry King Swivel Knife Blades...thick Or Thin?
Bob Blea replied to Mudruck's topic in Leather Tools
I was once given advice to start with the larger blades and become proficient with them, and then work into using the thinner, smaller blades and angled blades. The reasoning was that by learning to use the larger blade well you will develop good techniques. The other blades (I think he was mainly speaking about angled blades) could let you develop poor technique and cover it up because of the design of the blade. I have a BK knife with the 3/8 thick blade and I think it's comparable to the Tandy knife. Bob -
I use the Tandy two prong needles for all my lacing, and have never had problems with them.
Clear Lac or Wyosheen (both the same thing as Neat Lac, which isn't sold under that name anymore) would seal the leather and provide some water resistance. People who make motorcycle gear which needs to withstand the elements usually use Resolene, which is an acrylic much like Eccho mentioned above. But with both of those finishes, they only provide water resistance, not water proofing, unless you put it on really thick. Even then, the finishes will wear and eventually allow moisture to penetrate. Bob
LED bulbs may be the way of the future, and they are getting to be quite good, but still too expensive for my tastes. I liked the Ott lite but ended up buying a cheap little desk lamp with an adjustable neck and a base that holds tools like my stylus and modeling spoon, etc. I chose a CFL where I had a display with examples of each, so I could see which one looked the most 'natural' and I could decide which one I wanted.
The Right Tools A Beginner Should Be Buying
Bob Blea replied to Woodlands's topic in Leatherwork Conversation
Hello Sarah, and welcome! The problem is that the tools that are part of the basic kits have a reputation for being very low end. I don't know this from experience but I have seen many comments on here that the tools that come in the basic kits are of cheaper quality than what Tandy sells in the stores, and should be replaced at your first opportunity. If you know that you really want to carve leather, it may be worth your while to look at better tools. If you are not sure leather work is something you want to spend a lot of time doing, the kit is probably a very good way to go. Just keep in mind that the bevelers and swivel knife may be frustrating at times because of their quality. However, they may serve you well as you experiment and learn new skills, and after that experimentation you may decide you are hooked and ready to spend $20.00 on a good beveler and $45.00 on a good Barry King swivel knife. Hope this helps! Bob -
First Attempt At Sheridan Carving
Bob Blea replied to Toolerlass's topic in Floral and Sheridan Carving
Just my opinion, but I like the second picture with the darker background around the flowers, but that's just a matter of taste. Bob -
I think you are off to a good start. It does look like your leather may be too wet when you are carving. You aren't getting burnishing where you used your pear shader / thumprint on the flowers, and overall the carving looks a little off. Also, you've got some beveled lines that look kind of ragged. You can go over the flowers and leaves with a modeling spoon and smooth out the edges and eliminate any unwanted tool marks. Hope that helps! Bob -
Drawing Sheridan Pattern- First Attempt
Bob Blea replied to Karmindixie's topic in Floral and Sheridan Carving
I like you new design much better. Your vines look a lot more uniform and it does help. The only place where it looks like the flow might be a problem is the leaf above the middle flower. It's pointing in the opposite direction of the flow of the vine beneath it. You could just turn that flower around and have it cover the cross over from one flower to another, which is a pretty common practice in some Sheridan designs. However, you could also leave it that way too. I think that is more a matter of personal preference, but more knowledgeable designers might disagree. One thing I will recommend is to reduce the amount of background you have in your drawing. Once a design in on leather the background will stand out more. You actually doing yourself a favor by shading in the background in your drawing becasue it gives you a good idea what the background will actually look like, but when you go to carve this you will find that the process of beveling actually causes your flowers and vines to shrink a little bit. It makes the final vines a little thinner than what you actually draw. Drawing those vines thicker will help counter this. You can also make the flowers a bit bigger to fill the background space. Bob -
Acetone probably would work but it's pretty harsh. I would try denatured alcohol, I've had luck with that. You will probably want to add some neatsfoot oil to the leather afterward because either one will dry the leather out. Bob
Hello Karmindixie and welcome to the forum! I think I can provide a couple of pointers here. The thing that jumps out most to me is how you have draw the vinework. You've got the idea of the circular flow that is typical in Sheridan style but there is a problem with the flow. Of the three flowers within the circles, the top one is drawn as the starting point for the vines, with the flow going all around it. No problem with that, however, where the vine branches off under the leaf to the left of it, the implication is that all those vines come from something under that leaf, but they don't appear anywhere on the right side of the leaf. They are just left hanging out in space, and it breaks up the flow. Also, following the vine around to the lower flower it seems to meet the vine around the flower above, but in the opposite direction, again breaking up the flow. It would be better if you had some separation between the two vines so your eye had something to follow. Also, try to keep your vine work a uniform thickness. You have some places where the vines are very thick and some where they are very thin. Another tip is to draw the lines where the leaves or stems meet the vine longer. One of the tricks that really makes floral designs flow is to make all the lines in the vines long and flowing, and cut and bevel them so they fade out. Hope this makes sense, Bob -
Thanks for posting your results, and nice work with that crazy legs stamp. I don't know why but that one has always been a 'challenge' for me to do decent with, and yours looks good! Bob
The texture and detail on everything is amazing! Bob
Very cool!
Thanks for the link. I had never heard of this company before. Bob
Where To Find A5/a6 Binder Rings/binder Mechanisms In Australia?
Bob Blea replied to minimal Oz's topic in Suppliers
Turns out there is a thread going on in the How Do You Do This forum about getting these off of existing notebooks and mounting them in a leather binder: http://leatherworker.net/forum/index.php?showtopic=53376 Just stumbled across it. Bob -
This may not be the best solution, but can you buy the binders cheap at an office supply store and remove the mechanisms? I think that is often how people do it here on this side of the Pacific. We can often get binders very cheap around the time kids go back to school.
