Ferg
Contributing Member
Everything posted by Ferg
  1. Bruce, I have found several things that need "fixing". I bought it with the idea of refurbishing so I didn't expect it to be perfect. You are correct about the blade angle adjustment. Thickness adjustment has me befuddled at the moment. I think placement of the skiving knife in reference to the rollers, close/farther away may be the adjustment for thickness. Blade is in terrible shape. Has been ground poorly plus a big knick in the edge. I am ordering a new one and will get someone to grind the old one true for me, don't think my grinder will hold it correctly. I have no idea how you could cut leather straight with the cutter but then that cutter is bad also. ferg
  2. Frank, How 'bout $225 and I will pay the postage sent to me via Priority Mail in a Post Office mailer box. The small box of theirs should fit them I think. ferg
  3. I have purchased a Fayscott Landis 5 in 1 Model 25 that I want to refurbish. I am enclosing some photos of the machine. Main problem I have? The fifth function is not on the machine. The Welt Roller mechanism is missing but when I removed the bolt covering the space for this, the bolt and cover had never been removed since coming from the factory. Undercoat etc. still around the bolt and plate. There are a few things the machine definitely needs and the welt roller would be nice to have since it is a Shoe Sole item. No manual seems to exist unless in Bruce Johnson's shop. I have given "Shoe Systems Plus, Inc." my list of parts I would like. They have some parts but not all. I downloaded a parts list and diagram of the machine from their site. Prices forthcoming. Anyone have one, know anything about them, know why there isn't a welt roller on mine, you get the idea.
  4. Ferg
    Singer 29K60
    Good luck. ferg
  5. You can wet a sponge and apply to the leather but you need it to begin returning to original shade/color before stamping. You may find that this simple and quick process gives you questionable results, just keep that in mind. I have done it and on occasion it works okay but other times the impression of the letter stamp is very shallow. Try on several pieces of scrap. Time the different semi drying times. That will give you some idea anyhow. I am not hot (no pun intended) on using a heated blower, it tends to make the leather a little hard. Leather is natural remember. ferg
  6. You case the leather before stamping. If you are unfamiliar with that process there are many post concerning that. Bob Park (hidepounder) has one of the best explanations. ferg
  7. Eric, As KingsX says, If the style of lacing you do isn't full coverage of the edge you should definitely burnish and finish them. ferg
  8. I have the wooden item. Haven't had occasion to cut as wide as you are but I have my wife hold the end of the leather as I pull the cutter away from her. For one reason or another it seems I can cut 3 or 4 straps from same piece of leather then I need to use the straight edge again. Probably just me. ferg
  9. I've got to know, where in the world did you find all this? Don't have to answer that of course. LOL ferg
  10. You hit the mother load with this. I have the Ken Griffin book. ferg
  11. If you have a Glass Shop close by you just might get a "Cut-Off" from a job they done recently. The advantage to the auto glass, it is tempered. ferg
  12. Welcome to the forum. Your work is what I like to look at. You have the touch and do beautiful work, you should be proud. ferg
  13. Jim, Wiz, Art, or Bob Kovar is better equipped to answer you than I but I believe with all the info I have read you would be best informed to look at the heavy stitchers. Long arm perhaps. Wiz has a machine that will sew the heavy lifting webbing etc. Sounds like that might be your best bet. ferg
  14. Cheryl, I think maybe you are one with a problem. Where do you get off thinking you are such a high and mighty. Why don't most of you get off it. I sent MHolzer another message that obviously most of you never bothered to read. There was nothing malicious in what I said to the gentleman. I voiced an opinion. Actually I believe he took it for what it was. He did say I was RIGHT. Oh, you didn't read that either. ferg Johanna, Please can this thread, this gets totally out of hand.
  15. I will lump ATTABOYS together. Very well done. ferg
  16. Nice design, excellent workmanship. I like the simple design of the whole thing. ferg
  17. It mounts to a machine that has heat platen with pressure. That size roll was used on a pretty good sized unit with a platen of probably 8 or 10 inches square. There is a flat metal plate with a silicon rubber mould/die in the shape of the finished product. Can be used to emboss names, logos most anything similar to that onto leather plus many other types of substrates. We had one for about five years. Now you know more than you wanted to know. LOL ferg
  18. Bruce, I agree with most of what you have to say. I know that some times I lean a little heavy but praising what is really bad doesn't help anyone get better. The gentleman knew his work was pretty bad, I simply saw no reason to tell him it was okay. I have stated before that I have had my own business since I was 18 years of age. That included Radio and TV repair, Building and remodeling fine homes and industrial buildings as well as building commercial cabinetry. I cannot think of a man or woman I ever had working for me saying in later years that how I taught them was wrong. I was director of a 32 member singing group for five years. We traveled all over Ohio and Indiana. What is your reaction to a singing or instrumental group that is lousy. If they couldn't stand the heat they just stayed home. Some times constructive criticism is harsh. ferg
  19. I assure you this is "A Miracle in a Can". The spray can lubricant I use is the MK-30301-12. They make a fuel additive and the Hyper Lubricant, probably some others, these are the ones I have used. We have a '92 Olds '88 that doesn't get driven often. Last winter it wasn't running too great so I put the oil additive and fuel additive in it. Took one day for the car to sound like a new vehicle. I use the spray or the oil additive on hand tools. We have a 10 horse Vacuum Pump on our CNC machine. This thing uses a ten gallon tank for hydraulic fluid. I put one quart of the additive in it and it smoothed it out like honey. When you change your oil in a car or truck you add 2 ounces per quart. It will not overflow the crank case no matter how much you put in it, within reason of course. Only need to add the additive about every third oil change. We have a large sliding table saw. I have , before MotorKote, used several different lubricants on the bearings in the slides. Needed to re-lube at least once a week. I applied the spray one year ago and have not lubed again. Back to the sewing machines. I check the rod in mine every day. No residue, accumulated dirt, gum or anything else, it moves without hesitation. They have a special on for the remainder of this month I think, don't remember the discount but it is worth it and they do not charge shipping. Please understand: I do not represent the company in any way. Simply a very satisfied customer among thousands. Forgot to mention, I don't know that there is a statement on the product saying explicitly, "Satisfaction Guaranteed" You won't be disappointed. They are good people, I am sure if you have a specific problem with any of the products they will be more than happy to work with you. ferg
  20. Looks to be a very good grade of leather, simple, clean design with no clutter. The Ranger Belt Design is an eye catcher where ever you go. Nice work. ferg
  21. I especially like your designs and quality of workmanship. Herman-Oak or W&C? That is a great looking piece of leather with a great color and finish. Did you stitch after stamping your edge? ferg
  22. I am sorry. I have a hangup on hand crafted product that is sold or given to friends that is sub par. I done Stained Glass for a number of years and was simply appalled at what is being sold as great work when it stinks. I have thrown away more product than some folks make over the years, simply because I didn't think it met standards I placed on my work. Strive for excellence in what ever you do, even if it means your friends and family won't get to even see what you done when starting out. Just trying to be helpful. ferg
  23. I am not trying to be hard on you BUT. If I was going to give someone a gift of what I done, it would be at least the second of these. This is pretty bad. ferg
  24. The photos included are of a test piece I done. Sorry I don't have any of the stained pieces available for taking photos. This is Veg tan natural with a couple applications of Neat Lac. The image of the 57 Chevy is 2" long. That should give you a reference for the other images. Sorry for the bad photos. That is what you get when in a hurry.
  25. I will take some pics and post them this evening. ferg
