I also find that if I dampen the leather just a little, it tends to reduce the wicking beyond where you want it to stop. Tom
Try to get a thinner piece for the inside. The cover won't lay flat, but will stretch over time and be easier to lay flat. And yes, the inside radius is always shorter on a fold. That is why you see the puckering if it was done totally flat. Try a sample with a fairly wide groove in the flesh side of the cover. Start gluing from the spine and work your way out. Trim the excess after gluing. Tom
Make sure it is properly cased, too wet will do what your bottom line did, especially if you rest your hand on it like Tree Reaper says. Tom
Use thin material, like pigskin, or other choices you have available for the lining in the spine (rings) area. Glue it down solidly. It will still pucker a little. Another option is to groove the spine on the inside where you want it to fold. And again use thin leather for the lining. Make sure you get your glue down into the grooves and use a boning tool or similar to work the lining leather down into the groove. You will have a sharper fold, and less noticeable puckering inside. While gluing, in both cases, fold the cover about half way closed and let the glue set before opening or closing the cover. Yet another option is to use lighter weight leather for both the inside and outside, with a stiffener, like cardboard, between the two. Need the stiffener cut in three pieces, two for the front and back (same size) and one piece for the spine. Leave about 1/4" or more space at the folds. Look at the typical vinyl covered loose leaf binder as an example. Pull an old one apart, might even be able to use the board as your stiffener. Try it out on some small scraps to see what you like the best. Tom
Small Bag
Northmount replied to LTC's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice bag. I like the colours too. Tom -
Welcome! Your English is doing just fine. In fact better than some where English is their native language. Tom
If you leave the post too long, it is likely to bend so the burr doesn't sit flat. Also while peening, use gentle taps and work in a circle going around the top of the post. It will flare more evenly and helps to pull the burr down tighter. The biggest mistake people usually make is being heavy fisted and pounding too hard. Keep the leather and bottom of the post flat against your anvil. Tilting any of the pieces will make it hard to properly set the rivet. I set my first copper rivet when I was around 12 years old. What a mess. I hadn't trimmed the post at all, I pounded the heck out of it, and of course bent the post over on top of the burr. Then my Dad showed me the right way to do it. Tom
Wallet Id Pocket Cover
Northmount replied to retiredff's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
They can be stitched or glued in. If the pocket is tight and you won't be pulling the ID out too often, then no stitching or glue is necessary. You might recover some nice flat pieces of plastic from clamshells that a lot of goods are packaged for sale in Tom -
Attacked My Boots With An Engraver
Northmount replied to leatheroo's topic in Shoes, Boots, Sandals and Moccassins
Nice! You have a very steady hand to do all that. I'd have squiggles all over the place! Tom -
Messenger Bag
Northmount replied to rosiart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
$350 plus if your market will bear it. Tom -
Tandy's little 2# anvil http://www.tandyleatherfactory.ca/en-cad/search/searchresults/3101-00.aspx is adequate but I prefer a larger one that stays where I put it. Needs to be solidly supported as camano says. Tom
Messenger Bag
Fantastic job. Tom -
It's called a slit braid. Did a Google search and found several references. Try this link Also some examples and photos here. Tom
And Another One
Northmount replied to olivier79's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Pretty good looking bag. Just burnish all the raw edges will make it an over-the-top bag. Tom -
Pocket Notebook
Northmount replied to Bob Blea's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Really nice job. Your backgrounding is really consistent and smooth. The mockups often take more time than the real thing, except for tooling time. Which tools did you use for the geometric pattern on the back? Tom -
Ordinary disposable paper masks don't do any good for volatile chemicals. And the leakage around the "seal" at the nose severely reduces their effectiveness for dust. For dust, at least get the type with an exhale valve. Get a proper respirator type mask with cartridges labeled for organic vapors, or just dust if you are sanding or such. Note that the cartridges for organics must be kept in a sealed container when not in use, else the activated charcoal will be used up next time you want to use it. As soon as you start to smell the vapors through your mask, it is time to change cartridges. For exhaust fans, look at where the motor is in relation to the stream of flammable vapors your are disposing of. If the motor is in open "fresh" air, any type of motor is suitable. If the motor is in the exhaust stream, or in the spray booth, make sure it doesn't have any arcing contacts like most motors with a starting winding. Or use an explosion proof motor if it does. Shaded pole induction motors don't have a starting winding, and no internal arcing contacts. Most bathroom and kitchen exhaust fans are shaded pole motors. Tom
Harmonica Case
Northmount replied to Manypawz's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I was thinking of a case for a single harmonica when I read the title! Looks great. Good layout. Tom -
Interesting box. Looks great. Tom
Link to Ray's photos http://leatherworker.net/forum/index.php?showtopic=826&p=295067 plus post 175 in the same thread. Tom
Take a slice on an angle through a log. Diameter only needs to be as wide as the width you want. your angle can be as acute as needed to get the length. Tom
It's looking pretty fair. Lines that are beveled can be softened some by running a spoon over the sharp edge to round it over some. You can do some small practice pieces where you just experiment with eyes, nose, etc. There is an Al Stohlman book called Figure Carving. It has lots of info for both human and animal figure carving. 132 pages. part of it is in colour and includes using dyes. Tom
3M and other companies now have water based versions of contact cement. Check your local hardware/builders supply. Not so strong solvent smell. Much easier on the sinuses and safer. There are also several thread about what type of glue to use and about contact cement here on LW net if you want to search for them. Tom
