Card Wallet
Northmount replied to rosiart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very neat job. Tom- 10 replies
- card wallet
- gift
(and 1 more)
Biker Wallet, 2Nd Try
Northmount replied to RavenAus's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very neat job. Practice really does help improve the job doesn't it. Tom -
Very nice work. Shoes are way beyond what I can aspire to do. Tom
Right click your mouse on the link, select "save link as" and save it on your computer. Depending on your settings, it may ask you for a location, else will save it to the default location, probably under "My Documents, Downloads" or something similar. Tom
Tandy has a lacing book, in store or for download off their site. Kingsmere crafts has free pages. Tom
I'm saving this for future reference. Thanks Tom
Problem Purse
Looks pretty great considering the problems it gave you. It is a learning experience sewing the first bag or purse on a machine. Tom -
Why start a new thread with the same question? Why not continue the original and ask any more clarifying questions? http://leatherworker.net/forum/index.php?showtopic=52281&hl= Tom
Look up hot foil stamping. Both here and using google. Still need a level surface to work with. Tom
There are other threads on rust removal here. Try a search. There are a number of commercial products now for removing rust. Recommended instead of wire brush, etc. that remove or damage the original material. For antique stuff, usually want to avoid damaging the original surface as much as possible. Those are a number of dies used to cut those shapes. Use a mallet to drive the dies through the leather. The first one looks like it is for cutting short straps used to sew buckles to a case or heavier harness strap. Fold it over, insert the buckle and tang, stitch it down. Tom
Apple products display this upright. PCs don't normally use the embedded orientation information. With apples, have to remember which way to hold the device so it displays right on PCs. Really nice job. I need to try this someday too. Tom
Wood or leather, if it is too porous, it doesn't leave enough cement on the surface. So yes a second light coat helps. Tom G Ha ha! Two Tom Gs
Check your machine specs and look at needle and thread size charts. Make sure your tension is adjusted right, then go make some more practise corners. Tom
Great job! Tom
Get Bob Park's book, Creating Western Floral Designs. It will help with how to do the layout and get the flow to work for you. http://s486.photobucket.com/user/hidepounder/media/Active%20Links%20file/Flyer2.jpg.html or search LW to find more info. Tom
When you lift the presser foot too high, it releases the tension disks, so you lose the top tension. Just lift the presser foot enough to allow you to turn the leather. And another thing, the needle should be down and starting to rise so the hook has grabbed the thread loop. Else it may skip a stitch. Yours hasn't skipped a stitch so currently this is not a problem for you, just keep it in mind for the future. Something I have found that helps me go around rounded corners and to keep a neater stitch line is to mark the stitch line so you can follow it around the curve. Guides don't always keep you where you want to be. Tom
Cover For Keys
Northmount replied to Tanya's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Great looking dog! Tom -
The red wavy line is your spell checker installed in your browser. Older slower machines have trouble when too many add ons and memory resident software is loaded. Firefox add ons are easily added and removed if they are giving you problems. IE explorer lets you decide what add ons, active x, and com components you want to run. Knock off the ones you don't need. If you get the stuff out of the road that you don't need, you will see improvements in your computer and browser speed. Note that wireless connections are slower than hard wired. Check your old hardware (switches, hubs, routers), see if it is limited to 5 or 10 Mbps. If you have one slow speed device in series in your home network between your ISP's modem and your computer, it is a bottleneck. Latest versions of IE aren't handling the enter key correctly on this site (on PCs obviously). For each enter key stroke (carriage return) hold the alt key down and type the decimal code 013 on the keypad, then release the alt key. Or easier yet, switch to a different browser. You need to do some hardware and software troubleshooting on your systems to see what the problem is, so you can decide where the problem is. When you find the trouble spot, then of course you will be able to fix it. And obviously this site is slow when overloaded, or when your ISP is overloaded, or throttling your throughput. Tom
It looks somewhat like the saddle tan colour. Tom
The gusset needs about 2" extra length on both ends (4" total). Mark the gusset at the mid point on each side. Unzip it. Mark the mid point on each side of the case. Use seem tape or contact cement and start attaching the gusset at the mid point on each side of the case. Work towards both ends. If your case is going to be 1.5" thick at the spine, keep that space clear on the case material, and bring your gusset/zipper down inside the case. Don't sew or glue the piece that goes down inside the spine. All glued in place, punch and lace, or sew it together. Don't sew the gusset piece in the spine. Tom edit ... thicker cases require longer gusset/zipper to be able to open flat.
Old singers will sew lightweight leather. May leave marks on the back due to the feed dogs. If you are serious about sewing leather, get a walking foot machine. Look at the dealer ads at the top of the page here. Each time you refresh the page you will see new ads, so you can flip through and see who is who. Tom
No problem here right now. Sometimes the site seems a little overloaded, sometimes it is your ISP that is slow. Tom
How Do I Measure The Length Of The Thread When Stitching?
Northmount replied to leathervan's topic in How Do I Do That?
Get "The Art of Hand Sewing Leather" by Al Stohlman. Lots of good information. Available at Tandy and other places. Tom -
8 oz is too thick for small items like wallet and iPhone case that will be folded. For larger items like iPad case, depending on your design, the fold should be gouged on the flesh side to make it easier to fold. For a lot of small things, not subject to lots of wear and tear, 3/4 or 4/5 oz is easier to work with and not so bulky. Tom
