Knife Sheaths With Stingray
Northmount replied to malabar's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice! Tom -
Make a small platform that clips over the bottom cross braces at the height you want. Chances are a chain will work for your speed pedal. Then when not in use, move it up to the top braces. Using chains, you won't have to disconnect anything. Tom
- 181 replies
- diy sewing table
- industrial sewing table
(and 3 more)
Had a Tandy email today where they are clearing out the key posts. So try the Tandy site. Tom
As mentioned above, reduce the top tension. It is too tight and pulling the knot right through. If the tension disks are loose, remove a wrap from around a guide post too. Make sure the thread is pulling off the spool and not getting hung up. Tom
If the iPhone has a magnetic switch in it (like the iPad) to blank the screen when the cover is closed, that is the only effect that magnets will have on modern solid state devices. Does not affect memory, etc. as magnetism is not used for storing information. It is easy to test, just move a magnet around the front and back surfaces to see if it triggers any switches. Some models of Blackberry phones use a magnet in the case to switch the screen off automatically when the phone is holstered. The one thing to watch for with phone cases is that they are not so tight as to hold push bottom switches in the depressed position. Software can get mixed up with the "unusual" condition and require a hard re-boot, taking the battery out and replacing it, to restart the phone. Some after market cases were being blamed for these software problems, blamed on the magnets, but really was the case was too tight. Tom
Try reducing the time you have the stamp on the leather. Just want to burn the impression, not cook all the leather under the stamp. Tom
You need to buff off all the "loose" pigment on the top of the leather after it dries. That's the stuff that didn't soak in. That will reduce the amount that gets spread around when applying a finish on top of it. Water based dyes dissolve easily with water based or alcohol/acetone or other strong solvents. So as you say, air brushing is you best answer to avoid mixing it up again. But really buffing the surface stuff off will help reduce the spread. A waxy finish is really a conditioner, not necessarily a sealer. But might be adequate for what you want. Mop n Glow is just an acrylic floor wax/polish used for vinyl tiles and such. Should find many other brands that you could use. There are some additives in the acrylic floor wax that helps to clean the floor. So rubbing it around on your dyed surface will lift the dye as well. You may be able to find an atomizer spray bottle that will work for you to spray the finish on with. It needs to emit a fine mist. Any droplets will leave marks on the leather. Windex window cleaner spray bottles are supposed to be good. The misting type for plants or ironing that I picked up are not fine enough. Tom
Read post number 127! Tom
8 oz leather needs at least 1/4" additional for each bend. Cut a strap and test it. Tom
How Do You Make Perfectly Round Corners?
Northmount replied to joobacca's topic in How Do I Do That?
Here is another option I just found http://www.allimageprinting.com/corner_cutter.html corner cutting press and pliers type with dies. Tom -
Another source for small bearings is the guide bearings for router bits. Go to your local power tool store. Tom
Can also use wood carving tools ... sweep, gouge, etc. available in various curves. Tom -
This is the only one I see http://calgary.kijiji.ca/c-ViewAdLargeImage?AdId=503460943&Keyword=industrial%20sewing%20machines I wouldn't waste my time on this one, unless you are a collector and want to fix it up. Tom
Looking To Get A Machine But Totally At A Loss Which To Get
Northmount replied to Pip's topic in Leather Sewing Machines
And there are many threads on this subject, some recently from the UK and Europe. So a few searches may be in order too. Helps to broaden your exposure and to answer many of the questions you should have. Tom -
Barry King and other Sheridan bevellers are steeper and easier to bevel neatly with than what the Tandy kit tools and current Tandy standard tools are. Good tools do make a difference. Tom
Dog Collar I Made For My Vet's Office
Northmount replied to DoubleC's topic in Collars, Cuffs, Leashes and Leads
Lookin pretty good! I see you are getting along fine with you new machine. Did you purposely put the top side stitching on the inside? I'd put it on the show side to show off a bit. You should be able to make a lot of sales through the vet's office. Good going! Tom- 2 replies
- dog collar
- embossed leather
(and 1 more)
How Do I Prevent The Leather From Stretching?
Northmount replied to TLM2281's topic in How Do I Do That?
Cut oversize to start, do your tooling, check the fit and line up all joints, mark start and end points of stitching on both sides of the seam, trim to fit perfectly on at least 1 end, mark out your stitches, trim the other end to match if you haven't already. Pay attention to any twists or stretched parts as you are trying to line up the joins before you do any trimming so you can get the best fit with no strange twists. I have had to place a weight (not heavy, just enough to keep it flat) on top of some thin items to ensure they dry flat after tooling before proceeding further with assembly. Just leaving the item laying on your bench to dry, it can still warp. Keeping it flat helps a lot. Always test fits before gluing, punching, marking stitches, etc. That is the time where you can easily fix small miss-matches. Tom -
Camp/tripod Stool - Extra Step Necessary For Strength?
Northmount replied to BrieForShort's topic in Leatherwork Conversation
Depends on the thickness and quality of the leather. Light weight low quality leather will definitely need doubling up. 8-9 oz minimum should be adequate for a single layer. With the type of attachment to the legs that is shown in the tutorials, I would double up the corners to improve the durability, resist stretching if it gets damp, etc. Have you done a search here for photos and examples? There have been a number of camp stool threads here. Tom -
You have a couple options, one is to purchase from one of the suppliers listed in the top of this page banners. I purchased from Ron at http://shop.raphaelsewing.com/ in Montreal and had it dropped at the curb in front of my house. If you locate the machine you want, the cart will estimate shipping for you. The machine will be set up for the type of sewing you want to do if you work with him. Another is to check http://www.leightons.ca/catalog-general.html located east of Red Deer. John has new and used machines. Also check out WIz's post to see a number of modifications that are made to machines to make them suitable for leather. This post http://leatherworker.net/forum/index.php?showtopic=49955&hl=+leather%20+machine#entry317799 is specific to a 441, but gives you some idea of what needs to be done to a machine. Tom
There have been posts about tooling rough out. Do a search and see what you find. Most contact cements soften when heated. (That's how you remove laminates without damaging the surface they are glued to.) You should do a test to see how it behaves. Glue a couple pieces together, flesh side to flesh side, press it down tight so you get good adhesion all across. I use a roller. Leave an edge unglued so you can get some leverage to try pulling it apart. Leave sit after gluing for a few days. The cement continues to cure for a few days and adhesion improves. Then try heating with a heat gun and see how much it softens and if you can pull it apart. Don't need to heat so hot that the leather shrivels up. By testing, you will know how it is going to behave. (If you have an oven with a low enough minimum temperature setting, you can use it and have a better idea of the temperatures you are dealing with.) Tom
Does Anyone Know How .... Bench Grinder To Burnisher?
Northmount replied to RoosterShooter's topic in Leather Tools
Do a search here for burnisher and adapter and motor and see what you get. There was a thread running here for a while on building or converting a motor to a burnisher. Parts and sources were listed. Tom -
Read post number 127 Tom
