Keeping Linen Thread Looking Slick And Tidy
Northmount replied to KiwiLeatherLearner's topic in How Do I Do That?
Brown paper bag works well for burnishing the thread too. Tom -
By sized I'm supposing you mean cased. The leather should be properly cased before tracing your pattern, and thus still properly cased for all your swivel knife work and stamping. Tom
First Attempts At Bible Covers
Northmount replied to grywolf's topic in Books, Journals and Photo Albums
Pretty fair job for doing new stuff. Two things stand out. Bevelling is choppy. Either was still too wet, or need more practice to get it smoothed out. Can run over it with a modelling spoon to smooth it out. Second item is the raw edges of the leather needs to be burnished. See http://leatherworker.net/forum/index.php?showtopic=18101 for a tutorial. Keep working at it. Practice makes perfect. And, welcome to the forum! Tom -
As the leather heats up, it gets hard, warps, and chars. As plastic heats up, it wrinkles and burns, not just char. In both cases, sample held in open air. If held against a table top, tests won't be as effective. Tom
A certain BB phone in a tight case will lock up. Have to remove the battery to reset it. So, yes, be careful about how tight it is and whether the buttons are being held in. Tom
Really depends on what you want to be visible. Some cases you may like the matte, in others you may want to see the shiny side. If you are gluing the shiny side to something, then rough it up well so the glue will adhere to the surface. Tom
Sno-Seal Turned Very Sticky On Briefcase
Northmount replied to Roger J's topic in Leatherwork Conversation
I'd heat it and buff the heck out of it to both work it into the leather and remove the excess from the surface. By the way, products that have been finished with a lacquer don't absorb oils and greases well. Same applies to woods finished with a lacquer. Oils sit on top and get sticky instead of being absorbed. Tom -
Mitsubishi Ls2-130...good Enough Starter Machine?
Northmount replied to sproggy's topic in Leatherwork Conversation
Clutch motors have been around for many years, very reliable. The inertia of the rotating mass helps punch through heavy or harder material. Just hard for us to get used to feathering the clutch and maintains control at low speeds. If you have a 3" pulley on your motor now, a 2" will reduce the top speed to 2/3 of what it is now, still quite fast, at least for me, but at least a little more manageable. Low cost servos are relatively new. Some cheap ones have had problems. Old clutch motor ... throw it away unless you know someone that needs one or can find another use for it. Tom -
Canadian source: Princess Auto has a 12 piece drive punch set for $16.00. Sizes from 1/8 to 3/4". Made in China. Knurled handle. Need sharpening, but what do you expect for the price? 3/4" on 8 oz leather, took around 20 hits with a 1# dead blow hammer versus 3 hits with a sharp arch punch. So for the beginner or for occasional use, I think it's a good deal. http://www.princessauto.com/pal/en/Sets/12-pc-Hollow-Punch-Set/2920169.p Tom
Put a small 2 to 2.5" pulley on the motor whether you use the original clutch motor or a servo motor. If you want to run even slower with the clutch motor, then you put a pulley speed reducer set between the clutch motor and the machine pulley. For the light weight sewing you are doing, a servo with a 2.5" pulley should be fine. No additional speed reducer pulley needed. Rheostats or varac transformers can be used. There is a risk of overheating the motor. The motor has a cooling fan. If it is running too slow, it will not provide the required cooling. Running an induction motor (the kind on your clutch motor) slow also causes more internal heating in the motor. Don't expect the motor to be able to run at half speed. That is probably too slow to provide the cooling it requires. I have a digital servo on a Singer U20-33 (It is a high speed commercial sewing machine used for draperies and dress making originally, came with a clutch motor) that I use for wallet interiors and such. This is like my servo http://shop.raphaelsewing.com/index.php?main_page=product_info&cPath=2&products_id=293 This is a pulley speed reducer http://shop.raphaelsewing.com/index.php?main_page=product_info&products_id=354 You can build your own speed reducer if you are handy with tools and have a source for the hardware. See http://leatherworker.net/forum/index.php?showtopic=45336&hl=pulley#entry284770 post #11. You are probably further ahead time wise to buy the set already built. Tom -
White or yellow? Yellow glue is usually the woodworker's type. Dries stiff and cracks when bent. White glue usually dries flexible, so shouldn't crack. But, I suppose amongst all the manufacturers, there are sure to be disparities as to how their glue dries and behaves. As an aside, for those interested, diluted yellow glue can be used to stop water stains on your ceiling from showing through your new coat of paint. Tom
You need a small pulley on the motor to reduce the machine speed, about 2". Then you may need a shorter belt. Changing from a 3" to a 2" pulley will reduce the belt length required by about 1". Your mounting bracket might have enough adjustment to accommodate the change without a new belt, needs to be able drop down 1". With clutch motors, you slip the clutch to run at slow speeds. Ever drive a car with a manual transmission? You slip the clutch to get started. It takes practice. Sometimes you may be able to adjust the clutch mechanism to make it easier to feather (or slip) the clutch. Pulley reducer set may be around $125. And you need to get 2 belts. You will have to measure to figure out the belt sizes. Servo motor is around the same price and up. Servo is easier to operate. Still need the small diameter motor pulley. Depending on mounting and range of adjustment, you may need a shorter belt. Tom -
Probably A Stupid Question...machine Weight
Northmount replied to MadMorbius's topic in Leather Sewing Machines
The trucker set the pallet on the curb for me, I broke it down and brought in the table, head and boxes individually. Tom -
You should also rough up the fibreglass so the cement can stick and bond to it. Smooth, especially shiny surfaces don't bond well and can be pulled apart. Tom
There are several grades of lok-tite. There are grades that are not permanent, so you can adjust or dis-assemble after it sets. So if you can't easily get the parts, you could use it and have your machine in operation, at least until you get good parts. I used an oversized nut on an eccentric on a business machine. Went back 2 weeks later with the right parts and replaced them. Had stayed in position, doing hundreds of cycles per day. Tom
Welcome! Lots to learn here. The have been some really nice quivers posted here the past couple months. Use the search function on the upper right of this page and you should find them quite easily. What part of town do you live in? Tom
Good idea rc. I was making a prototype zippered case for a tablet. Shorted myself about a 1/4" around the three sides because of some in attention and too much hurry! So I ran into trouble with the stitch line. Couldn't stay in close enough using the sewing machine. Decided since it was a prototype (second try too) that I would dye it dark brown to help hide the ratty stitching. Dye did help a lot, but still didn't look too great. So I decided to see if I could punch close enough and lace it to hide the ugly stitching. Used double loop lacing. Got a good straight line with an angled chisel. The dark brown lace I used hides 95% of the ugly stitching, so it is hardly noticeable. Any how, my son is happy to have and use it. After three of these, I have learned how to get the zipper lined up correctly, and do a good sewing job. Practice eventually makes perfect! Tom
Which Servo Motor For Consew 206Rb-1
Northmount replied to BoonesDaddy's topic in Leather Sewing Machines
That's why I added a pulley reduction set as well. Most motors lose torque at slow speeds. So when going slow on thicker leather, the motor has lost much of its torque and needs some help, but chances are, I have both hands on the project and don't have a third one yet to help wheel the machine. There are larger specialized digital servo motors that have more torque at low speeds, but it's going to cost you! Tom -
I Guess If It Helps Sell Your Stuff...
Northmount replied to TXAG's topic in Leatherwork Conversation
The picture comparing lock-stitch with saddle stitch omits some reality. It is rare that only one stitch is abraded or cut. Usually several stitches are abraded, so the integrity of both threads is lost. Anybody do repairs on old tack and harness? If not, take the time to look at what happens to the surface stitching on well used and worn equipment. I realize most tack is machine sewn, but my point is the abrasion the tack and harness is subjected to. I do appreciate the skill and time that saddle stitching takes. I also love the same appearance on both sides of a well done quality job. I'll use a machine where I can, and hand stitch where the machine can't reach. Though in many of those cases I would lace the project. It all comes done to personal opinion and experience. Many customers have little experience. They just want the cheapest handmade item, some regardless of appearance. To them, the ratty look is a mark of pride in owning something handmade. They support the underdog. Tom -
Watch Cuff
Northmount replied to rosiart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice job! Hadn't considered snaps on a watch strap, but no reason not to. Always good to get back to hands on work. Tom -
Chances are your stitching holes will be too close together so will not suit the lace. Tom
The leathercraft library has an example with instructions on an Al Stohlman Christmas card https://www.leathercraftlibrary.com/p-713-christmas-card-by-al-stohlman-series-10-page-11.aspx? Tandy has a craftaid #76604 with pine cones. Good instructions on the back of the paper. Except for 2 typos. In step 1 and 2 the beveller is B202L and B202R. I used these instructions for a billfold craftaid #74010 since it didn't have any description and the photo was not detailed enough to see clearly. Tom
Thread Tensions On Multiple Machines
Northmount replied to piddler's topic in Leather Sewing Machines
Also make sure you hang onto the top and bottom thread when starting to stitch. Tension is more even on the starting stitches and prevents bird's nest under the bobbin. Also, do test runs and reset the tension as required each time you change leather, thickness, thread and needle size. Use the same materials in the same configuration for your test/setup runs. Tom
