catskin
Everything posted by catskin
  1. Would Lily white be the same as the regular sewing machine oil that Bob Kovar sent for my Cowboy 4500?
  2. A bit off topic because it doesn't sew leather. But we are looking at a JUKI MO-358 sub class 8 serger. It calls for defrix num.2 oil in the JUKI manual. What would be the equal to that oil? And if anybody has an estimate of what it should be worth.
  3. One thing that has not been suggested concerning bottom thread tension is there may be lint or dirt under the tension spring on the bobbin holder/ shuttle. try taking out the screw that holds the little leaf tension spring on and see if there might be something under it that stops it from tightening down far enough.
  4. I don't see why anyone would spend the kind of money I see being asked for round ( half round ) punches when you can make them in about 1/2 hour on a lathe. I made mine and showed the cuts to others and was told that they likely were as good as ANY I could have bought. And sharpening is just as easy. Put in the lathe and redo the edge. Plus there is no limit on the size you can make. I could make a whole set for less then Tandy wants for one. Other shapes could be made with a bit more time and a few basic tools.
  5. I would also check for even a microscopic burr (rough spot ) on every thing that the thread slides over as it goes around the bobbin. Something might just have worn a thousandth and made a burr enough to catch ever so slightly.
  6. Big s, . What I have done with bad thread is run it on the bobbin, I have some VERY expensive black thread from tandy that I can not run on top but it runs okay on the bottom, ( Better the scrapping it )
  7. I THINK I have it fixed, thanks all for your advise. I checked all those things. I had a 106- 23 needle in it, that is what I had been using with 207 thread and it HAD been good. BUT this one had a microscopic size burr on it. So changed to a 180- 24 new one and checked the spring travel and it never missed a stitch in 6 inches, it had been skipping one about every 2 inches. The spring was adjusted about as low as it could go, the stop still has room in the slot but the bottom end bottoms in the hollow in the casting. If it needs to be lowered more I will have to use my dremel grinder to remove a bit more cast.
  8. Thanks, will check these out and report back!!!
  9. I know this has been covered before but have not been able to find it. My CB 4500 is missing stitches when using 207 thread top and bottom I am using the needles that were sent with it for 207 thread. I never misses with 277 or 346. I think it just needs a minor adjustment. But rather then go messing around and maybe getting some thing else wrong I decided to ask you experts, Wiz, Bob, etc. It has been inclined to do it since I got it but seems to have gotten worse. Thank for any help.
  10. I can't help wondering if the Cowboy on Ebay was there because it was faulty form the factory. Ebay is the place junk is disposed of. Very often. For someone who knows splitters it might be fixable.
  11. Thank you.
  12. I am looking for dies to cut leather conchos ( I think that's what they are called ) the small round pieces with scalloped edges that go on the laces on saddles. Any info. on where they could be bought or if you have used ones for sale I would like to hear.
  13. I've been looking but as yet have not found any information on where I can buy small dies for cutting leather conchos like the ones used on saddles that the laces go through. If anyone knows where they can be gotten or has used ones for sale please let me know.
  14. Chayne, You haven't answered my PM asking if you got the book I tried to send you. Did you get it ?
  15. I replied to your other post, Singer 78-3 is flat bed.
  16. I guess I was somewhat misunderstood. To me BEATING implies using insult and intimidation. I prefer respect on both sides. And it has not hurt me. It seems ALMOST every person on here complains that they can't get the money to buy the machines they want or claim they need. My problem is more like I buy more machines then I need just because I CAN. So using my system, as some might call it paying full price has made both profit and earned me respect.
  17. Where on the first post does it say it is on Craigslist or any other junk site? I am referring to private sellers pricing things at what they feel they are worth. While you likely do not, I respect sellers right to price the things they have for at what they feel they are worth and I take them or not. Just as I feel I deserve that same respect.
  18. BEAT the price down? Does that mean that EVERYTHING you sell is priced to have the price BEATEN down? Like if you price something at $100,00 you expect to be offered $40.00 and you will gladly take $60.00? After all every person with any sense treats others as they expect to be treated don't they?
  19. I have an American straight needle machine, and looking at what this thread has to say I wonder if someone with a bit of skill and tools could make a good box stitcher attachment for them being that they are made to stitch very near the edge. Looking at the pictures on here I think it would be worth it for any one doing much box stitching. What do you experts think?
  20. HA HA YEAH but none of them sew a decent stitch EVER!!!!!!!!!!!!!!!!
  21. To explain better the grooves I am talking about are not ones across to feed the material (although they to could do it) but the one that is length wise that is supposed to clear the thread to allow it to pull up. If you look on the bottom of the foot it will be one groove in line with the needle hole or slot. Having this one would make it less likely to hold the thread back.
  22. Wiz is the expert no question. But here is something I have had happen, some times under some conditions sewing in reverse and then forward the foot puts more pressure on the thread at different times and affects the amount that the take up arm is able to pull back up. This could depend on if the foot is grooved on the bottom or not or if the groove is small for the thread size. Disclaimer: I do not own a machine of that model, this is just general observation.
  23. I recommend making a flat plate sooner rather then later unless boot soles are about all you intend to use it for. I found sewing flat with the boot sole plate made it MUCH easier to break needles since there is so little support outside the needle. I made my flat plate what looks like wider and longer then the factory ones look to be from the pictures and vids but it gives good support on wider and longer things. I made mine 8" by 10"and made a guide for the inside. Some parts are available from Landis international in Montreal. I also have a message in to Pilgrim but am waiting to hear back. In Montreal needles are expensive but if you can't get them somewhere else the machine is worth it. There can be a bit of a learning curve getting the top thread tension right, read that part in the book several times. Have fun with it.
  24. Thanks for your replies . I intended to use friction drive by putting a thick O-ring on the pulley that way when the bobbin is full it would kick out. So the crossed belt wouldn't be possible. Might have to use a belt yet. Would switching the wires on the brushes do the same thing as switching the brush housings?
  25. I tried turning it over, it then turns the winder in the wrong direction that's why I want to reverse it. So that it turns the winder right with it turned over.
