Double loop stitching is a lacing technique as shown here http://www.kingsmerecrafts.com/page96.html or
and here on this site if you search for it. It may or may not be right for breast collars.
You are correct, I was able to loosen the upper screw and lower the shaft a bit but it is very tight which I assume is due to the lower screw. I planned on taking it to someone but they are tied up until after Christmas so I figured I would fuss with it until then. I downloaded the navy manual and will try to disassemble and reassemble to figure out whats up. it seems to me something has seized but I'm stumped. I appreciate you pix and ideas. Im trying to identify what actually moves that presser foot up and down during sewing
Working on loosening the screw with liquid wrench. You are correct that the presser foot is stuck in the position. Does the presser foot eccentric play a role in the movement? If so how?
Thanks for the input guys, and the pix. The knee lifter seems fine, as does items 1 is loose. 2 and 3 are not moving , maybe that is it. I cannot turn screw 2 yet. Should they be loose or tight?
Not sure what I did exactly but while cleaning and oiling my machine, the rear presser foot is not lowering even though the lever is down. It is also not moving when I run the machine. I did not intentionally change anything but must have. Would it be the presser bar spring or knee lift lever? Any ideas? I appreciate any leads.
I am looking to get another machine and the above 2 are available in my budget range. They are both walking foot machines but no reverse. I will slow them down with smaller pullies. One has a large bobbin but other than that, seem similar. Any thoughts on one over the other? Thanks.
Ive bought some from tandy and hidehouse. I just came upon this place , but haven't brought from them yet. Looks like its probably all upholstery leather not veggie. http://www.waterhouseleather.com/scrap_leather_pounds.htm
