Cumberland Highpower
Everything posted by Cumberland Highpower
  1. Here, Facebook Marketplace. Auctions.....
  2. Ok, so I am doing something I should have experimented 20 years ago when I got in the business.... I've bought a Seiko TE5 that is essentially a modern version of the Singer 17. I want to run some really thin soft leathers through it, and I have seen online that it's a common trick to superglue a thin strip of rubber over the feed dogs. Now I've never done that before, it's a new concept for me. Are there any commercially available ready made rubber bonded feed dogs for it? What about teflon presser feet? I see some around for textile machines of other makes? I've probably lost my mind buying this TE5, but I was seriously intrigued by it for some odd reason and I don't want to mess with any of my other machines, they're all set up for other things.
  3. I used to work miles of Biothane, what are you using? I ran mostly Beta When you say hot stamping, you mean an embosser or foil type machine, right? About any will work. If you're talking about a hot cutting machine, if you're running beta it depends how thick. SH Beta is hard to run through a hot cutter, you have to set the machine to run as slow as possible. I often resorted to a lube pad made from foam to lube the top surface, that aided surprisingly allot in the cleanness of the cut.
  4. Just make sure you ask how much! I had Weaver resurface a stack of clicker boards once...I got a little sticker shock. Be sure to ask about shipping also. I once ordered a 2 oz plastic ball (foot lift) for an Adler 205 and they charged me $17 fedex after charging me 10x what the ball was worth. FWIW my son found that ball and lost it, so I ordered one on ebay for $5, free shipping Just saying to be careful with assumptions, I still deal allot with Weaver and like the outfit, I but know before hand what I'm paying-lol I sharpen all of my punches on a 2x72 belt sander. Very carefully to avoid making them larger. Yours needs trued up a bit then the bevel shaped a little.
  5. I almost bought a Damasko once. One of the more "basic" tool watches. Decided against it though, it just didn't seem to offer anything a Seiko that looked about the same did. So I took the Damasko money and bought a spare ATOM SE25 with it. I usually can't keep a watch more than 1-2 years. 1 is about the average. I tend to kill them. Impact. Knocking off the counter, putting in the washing machine, etc. Broke one once hitting my arm on scaffolding. Not surprisingly, lost one to the concrete from a failed strap/pin as you point out. Watches are rarely an investment in honesty. Maybe 10% are and those are top brands/materials kept in pristine shape. If I had bought the Damasko, worn it for 2 years and put it up for sale it would probably bring $400 at best. The Atom I bought with my Damasko money is worth at least 2k.
  6. That type of machine usually brings top dollar, might be out of his price range? 3x the cost of his PFAFF?
  7. That's mostly the nature of unison feed machines unfortunately. You're turning your work while the outer presser foot is down, and your center is anywhere other than under the needle. Unison feed machine basically suck for leather work, but they've become the standard as they can do about everything. Leather, nylon, plastic, etc. You could try to train yourself to turn your work on sharp curves while the outer presser is still up, and the needle down, that might help some. You may also want to check and see if your inner and outer foot lift is balanced. Maybe your feet don't sit square against the needleplate? You may need to hone on the feet to fit better, more squarely. Also try an open toe inner foot if you haven't. Roller feed are good for tight curves and give great visibility, but really are only good on leathers that don't mar up. They'll leave knurled tracks on top or a bit of a trough, and pretty heavy feed dog marks on the underside. That's why they're mostly used for shoe/boot uppers. I have a couple machines set up with large rollers that have rubber covered wheels, for visibility mostly.
  8. Does anyone know if Nippy presser and roller feet will fit the FAV Skiver? They're both fortuna-ish clones.
  9. I admire this member's dedication to the craft. All that hand stitching just to showcase a sample. Only in Japan! lol
  10. That's a serious watch. I like it. I appreciate your thoughts and advice. I think for me, personally, would be pretty easy to market straps. I have 2 "machine shops" full of machines already and have been making everything from competitive shooting gear, holsters, belts, slings, tools and other goods on exclusive contract runs for over 20 years. I think I could target a market in the $35 range w/good quality materials and lined with French Calf. Basically the "average" buyer. I personally don't like those QR pins, but I think an "average" buyer with an average watch wants those. I know an Amishman that made a living for 10 years making straps for Nick Gabarro. I'd say I learned a thing or 2 from him along the line. some were from shell cordovan, some nylon, some common chrome leathers. What's motivated me to a degree are the "Trump Tariffs" Some things that were not profitable last week are more likely to be actually profitable in a year. Strap Code's prices are going to go up, maybe 10-60% in the near future? Let's not comment further on my ambitions though, I don't want to hijack the OP's post. I think his work looks pretty sharp and I'd certainly wear it.
  11. I'm curious, when did Seiko switch paint colors on it's machines from Grey to White? An even tougher question, when did they switch from black, to grey, then grey to white? Did the grey to white color have anything to do with the end of the sales relationship with Consew?
  12. I've been tooling up myself to make leather watch straps. Only by machine. I guess I'll just include "Not for $5000 watches" stamped under size and maker stamping. LOL
  13. i think your work looks pretty sharp. Professional. How long did it take you to make the set? Is that hand stitching? I'm not familiar with your leathers, are those leathers produced in Japan or imports from Italy/etc?
  14. Well, it sounds like your chain needs to be taken up a link or however your'e adjusting it. First thing you want to do is see if you can back off the pressure on the feet. if that doesn't work, Sometimes you have to think outside of the box. You can COUNTER the force of the feet if it's too high by attaching a light spring from the hardware store to your lift chain and then somewhere on the table (pulling it down). Don't use a spring heavier than the one in your machine, you just want to reduce down pressure. I've made pressure extremely light this way on a couple machines. Light, but consistent. If you're using a very large needle with large thread, you could run into issues with a very light pressure on the feet.
  15. I've got another needle system question today. I've agreed to purchase a machine that uses a DBx1 or 16x231 needle system. I've not owned a machine as yet that's specd. for these needles. Are they in any way compatible with the 134/5 needles? Machine is a Seiko Te6
  16. When I looked the machine over I noticed it has an older style timing belt with the crimped steel teeth. Looks to be in fine shape, but I wouldn't mind replacing the belt with a modern one while I clean it up. Judging from your link a part number 234003 was discussed, but looks like an obsolete/NLA part. Is there an updated alternate available? I'd just like to change it if possible while I have things apart. I also have a "spare" machine assuming both of my machine's belts are identical. The other 51w I have is the earlier version with the take up arm out the front. Of course I don't know if they are.
  17. That's a pretty good share Constabulary!
  18. So I retrieved a couple Singer 51w54s I had lost away in a shed for over 20 years today. One rusted up, one looking really good w/no rust. I'm planning to clean up and go over the clean machine. But having never used these I have no idea what needles they take. I can't seem to find any reference to needle size anywhere. What needle system is used by the 51w54? I feel from a quick look over it's something else, like maybe a 128? Like everyone I have about a million 134/35 needles laying around. Any easy way to make it take a 134/35? Maybe a retrofit needle bar?
  19. Up for sale is a Nakajima DBU 180-L-2 Double feed machine. (Walking foot and feed dog). No Needle feed. Great for heavy textiles, Canvas, vinyl, etc. Can be used on leather with different feet. Practically same machine as the Juki DU 140. (Juki bought out Nakajima). Good tight machine, decent external condition. large bobbin (M). A few extra feet, etc. Similar to Weaver 303 as well. $350+UPS head only shipped UPS. (I estimate around 80lbs). $450 with complete table/clutch motor. I can ONLY ship the head. If you wish the outfit complete, you must pick up SE OH.
  20. I've got a Singer I'm setting up for a small run of goods, A cylinder arm Singer 17. What is the largest thread I can run through it and expect decent results? I'd like to use 138 top/bottom but may run something smaller underneath. I also have a 51w54 I may resurrect, will it also run 138 top/bottom? I've never used either of these machines, so tips/advice help a bit.
  21. What thread are all of you members using for watch straps? Size/composition? Anyone using linen thread on a machine? Probably questions that can have have a hundred answers no doubt. Just wondering what the typical set up is for everyone using a machine.
  22. He needs to just buy a bottle of 10 spindle oil. It's cheap and readily available. $40-50 a gallon. It's all over the net in pints and qts as well. Many sewing machines call for common spindle oil and it would work just fine on his Pfaff. Most Pfaff machines are mostly clones or based on Singers, the same machines everyone else copies and recommends 10w spindle oil on. It's also widely used on textile machinery in general.
  23. True to a degree, but then not really at the same time. A straight non detergent SAE "motor" oil can be the same exact oil as an ISO oil, they just use a different scale. SAE30 is ISO 100. It's the detergents/additives in most SAE oils that would be undesirable to a degree in a sewing machine, but in real life it's kind of a "so what" deal.
  24. I think you can use about anything really. My Adlers called for Esso Millcot K68, that's essentially just a first cousin to 20w bar and chain oil. Seikos, Consews and Brothers I have just called for common spindle oil, so I bought some Gulfport Gulfspin that I buy cheap on Ebay. I'd imagine a Pfaff is about the same deal. You can use about anything, although I'd shy away from detergent oil. Synthetic oils are a + I use straight 30w non detergent oil on all the big stuff. Don't like the idea of ATF as lubricant in a machine and all over my fingers, but no reason at all why it wouldn't lubricate (that's what it does).
