Cumberland Highpower
Everything posted by Cumberland Highpower
  1. Controlling Multiple Motors with One VFD | Rockwell Automation | US Here's a little primer on the basics With the really cheap VFD's on Amazon/Alibaba and what not, that are pretty small, you'd probably be handicapped right out of the bubble wrap. I don't use a VFD for anything, although I am warming up to the idea. I've got one disc grinder I need to set up that is too far from my 3ph lines. A vfd would be cheaper than wiring/conduit, and it's within 20' of my 220v.
  2. It's kind of novel. I wonder if you can find a ready made one somewhere like that? Maybe with an extension cord already built in? a cord of 20' or so would be a plus, must hobby leather shops here in the US don't have 220v outlets as a standard thing so they maybe just wire up one. If you have lots of 3ph machines, you'd be better off with a rotary phase converter and just wire your shop for 3ph. That's what I have. I can run every piece of machinery in there at once. I have 2 converters, both surplus units from DuPont that cost $200. One is supposed to be a spare, but after 15 years I still don't need it. Some machines can't work properly on a single VFD, for example a machine that has multiple seriously mismatched motor hp ratings or has motors that start and stop independently of each other.
  3. It would run at 2/3 power with the capacitors. Probably not as bad as it sounds, my FAV came straight from Grande Italia this way. I guess FAV didn't find it worthwhile to offer the FAV AV2 with a factory single phase motor at the time.
  4. That was my idea as well Dwight. But, I have to say that's probably a pretty well built quality clutch motor he has there! I have a single phase CM made in Belgium here (3450rpm ) and it's a pretty well built unit. Wish I had more of those. It came on an Adler made in the late 60s so it has some age to it.
  5. I'll give you an honest set of answers. Hobby: It's a great hobby, make all the goodies you and your friends desire. I'd consider a retiree making a few dog collars or chaps or whatever for sale at a flea market a great hobby. Business: RUN, AND RUN AWAY FAST I wish someone had told me that! LOL I've been supporting myself for 20 years doing this. Some good times, some bad. There is a limit to what profit you can make working for yourself. 10 employees, maybe a sunnier day there. It's not a good time either. With the looming import tariffs, costs will be way up. Domestic leathers are likely to be in shorter supply and higher in cost as well (HO for example imports wattle bark from Argentina). Nobody really want's to say it out loud, but nobody has money these days. Festivals and events are packed, but you'll find there's hardly a dime changing hands. In 2 years everything will be better. If I had it all to do over I would have bought a kettle and sold Kettle Corn! Yes, you're for sure wasting time if you dont have a machine or 2. I bought my first Randall in 2005 to fill a holster contract that I won and had no way to fill. (I was not a leatherworker at that time). Either way, it will wear your hands out and your sanity about the same.
  6. I am curious, are clutch motors an easy thing to find in Belgium? If they are, why not just change it to something single phase? I've probably purchased maybe 20 machines so far that were set up for 3ph clutch motors, and on almost every one of those, I swapped the 3ph motor for a single phase. Used Clutch motors here are usually $20-50. In the US that makes them cheaper on the used market than a good VFD, and you don't have to do any work around other than a little with the wiring. Most motors like that are designed for delta on the lower and Wye on the higher voltages. You're not planning to install on 380v are you? I'm guessing not? Your VFD will wire up as a delta 220v. Every 3phase machine I have that didn't get converted by a motor swap is run off of a rotary phase converter, wired delta. Everything from Clickers, to Band Skivers, Belt cutting machines, CNC stitchers, bell skivers, etc. Often several at once. You could also just add a capacitor to your motor and effectively convert it to run on single phase, but it's been a long time since I've done that so you'll have to research.. Some factory built machines come like that, for example my FAV bell skiver has a 3ph motor with a run and start capacitor added to make it "insta" single phase). There are ready made static converters that do the same thing, they're just a box with capcitors and your motor would run at 2/3 power once it starts up. Static converters seem to be fading away with the VFD being around.
  7. Sure it can be fixed. Can you post some details like Wiz asked? You "May just be able to use it as it is...Maybe forever? Or maybe not? If it looks like it's holding pretty well, you can just cut a small relief in the cracked areas and work in JB weld, grind flush and repaint the machine. Nobody will ever know. Check to see if it works freely w/o any binding or misalignment before doing anything. Are you certain it's a crack? Some machines are made from more than one piece and bolted together. (Like my Seiko TE6). It has 2 pieces that are bolted together and finished smooth on the exterior, but "look" like a fine crack. Is it a hairline crack or a crack that allows some daylight? If he's a welder by trade there is little doubt he can fit it. Cast iron you have is best brazed. Probably in 'stitches" to keep anything from warping or cracking further. It can be welded also, but I'm not sure I would do it on a sewing machine.
  8. Is there any resource anyone can share regarding the templates or cutouts in industrial sewing machine table tops? Surely it's not a closely guarded trade secret? Looking for factory drawings/etc. I have a couple Consews, but nothing for any Jukis or Adlers....
  9. I think they're all pretty much of the same overall specs. I feel like the -3 meant it was the "improved quality" China produced version.
  10. I have one of those and I never use it to speak of. they're ok for some uses. They're made from a sewing machine servo motor and have an adapter to allow the use of Galli burnisher wheels made in Italy. the wheels they use are the best part. There are lots of wheels made by Galli, everything from grinding and shaping wheels, to wheels embedded with diamonds (no joke) to plain old leather and canvas flap types. I have a FCE burnisher and I can swap wheels, hot wax to grinding, etc. The worst part of those machines is that because they're made out of a low cost servo, they have no torque and at low RPMs pretty much give up. When I need to do belt tips or whatever flat work needs burnished I use the DC burnisher that's on the front of my FCE. It's about the same concept, only a better execution. gallispa.com/wp-content/uploads/2022/02/GALLI_2022_ACCESSORI.pdf
  11. On a small machine like that, you are better off using a box speed reducer. The one thing I don't like about belt reducers or jackshafts is that it creates drag/resistance when you want to finesse the handwheel. You're correct about the belt alignment and engagement of the clutch. you should try to have the belt as straight and square as possible when the load is applied. Being a real low horsepower outfit, it's not really critical like you might think though. Really no reason why you can't master a 206rb with a standard clutch motor (provided it's a 1725rpm motor) with a small pulley. With a little practice you'll both speed up your pace of work and at the same time learn to slow the machine down with light feathering of the clutch.
  12. Sure you did pretty good for $200. The table/motor has some value and the head is probably worth a minimum of $400 if it's timed and functional. Probably worth $600 total if you can prove it can sew.
  13. It's probably just due to lack of demand I'd imagine. I run allot of poly thread and I often have the same complaint. (Poly is hard to dye). Black and white are common colors for nylon rigging/slings, etc. That's what thread of that size would be used for on any commercial scale. I'm sure any thread maker would make a run of nylon for any customer who purchases a large enough lot? I'd guess the outfits selling hand sewing thread have lots made just for that. If you have the needles, I somewhat doubt you'd have any issues running it through your machine though. I bet you could run greased masonry line through your machine if you had needles/feet/feed dogs cut for it! Most any time I come into threads larger than 277 I either sell it off or toss in the trash. Really large threads are somewhat counter to the norm for sewing leather. (One should really use as small a thread as practical). Of course if you're trying to make a bold statement larger threads work pretty well, no set rules there. A little bit of the norm on some holsters.
  14. Sounds like a common tubular rivet? Does it look like this?
  15. That just means you have a good machine! If it's been here for 40+ years it will probably be around another 40? I'd rather have a 40 year old Italian or US made machine than a "new" Chinese machine anyway! We have exactly ONE machine here made in China, a hot foil embosser. Every time I look at it or use it, I feel like tossing it in the scrap pile...Poor casting, machining, assembly, etc. No heat treated parts, etc. I bought it at an auction so I wasn't into it for much....
  16. You can get spacers made in just about every configuration. +/-. I have a handful of Randall 132's. Older machines, but work just fine. They had spacers in exact lengths, undersize, oversize, etc. I tend to use single spacers that are 1/16" under that way the straps come out exact as 1" 1-1/4" 1-1/2" etc. Some spacers are also meant to cut straps oversized to compensate for what's lost from an edging machine. Spacers are also intended to be stacked. For example, you can use a 1/4" spacer with a 1-3/16 spacer to get your 1-1/2" strap. (The missing 1/16" is the width of the cutting blade). When you're calculating what spacers to use, you take the desired strap width and subtract 1/16" to get your total stack. What's the make on your strap cutter? Looks metric to me. Could also be your spacers are metric 28mm, etc? It also looks to me you're stacking spacers (At least 2 of them) that are each 1/16" under and you're stacking tolerances as a result. The 1/16" under on each spacer is the width of a blade. You can correct for that by either using just a single spacer that is 1/16" under actual width of your straps, or you can ADD a thin spacer to your spacer stack that's like 1/16" or 1/8" or whatever you need to make up for the loss if that's all you have to work with. You can as a last resort have a machine shop make you some up or cut some down. I had a relative cut some down for me on a surface grinder. Hope that makes sense?
  17. Thanks MClark, I hadn't heard of Decocuir. I looked over the site and they look like pretty good quality creasers. I'm starting to wonder what the "French Connection" is with creasers? They're either made in France or China from what I can see? What types of goods are you using your creaser on? I might go for the creasers from your link, still doing some thinking. I'm not set on a Regad Creaser. Long life/durability/ergonomics are my main criteria. That....And being able to take the occasional impact with a concrete floor. LOL
  18. I like your thread layout, under the table. I think I'm going to have to start doing that. The machines I want on the U tops are pretty light. Seiko TE5, TF6 and a LSC-8 binder. Now that you mention sagging tops, I need to do something about one of my strap cutters. I've got a Randall 132 on a plywood dop that's sagged enough to look like it's sitting on a banana.
  19. Thanks for the reply KGG I've actually made some tops in the past. 4x8 workbenches and table tops for machines as you describe. I just don't really have the time to spare for projects at the moment, was hoping I could just do it the lazy way. I guess you could say both "classes" in Juki talk. Also a Markem Foil machine for Shoes on a regular top. I see you're Canadian, where are all those Canadian made tables from? Any place still in business? Local Cabinet maker isn't an option Nearest one is probably an hr drive...Maybe 2? Maybe you can get tops made pretty reasonably up there, but down here you can't hire out such work, most independent shops wont turn on the lights for less than $500........
  20. I've been looking for a couple decent machine tables/tops over the past months and got to wondering a few things... I've probably got a dozen tables that are marked "Canada". Who made these tables and are they still around? Most are pretty heavy gauge steel, either K or H legs and darker grey paint. I'm sure they're older tables from the 1980s-90's. Steel is a bit heavier gauge and slightly heftier in dimensions than the Chinese imports. Where can I buy a couple good THICK plywood table tops? Something plywood w/Formica on top. Looking especially for a couple U cut full size table tops for K Legs... I've seen a couple U cut tops listed at Atlas levy and Ebay, but are not so thick and made in China as best I can tell?
  21. Does this company still exist? I have some riveting machines made by them, wouldn't mind getting some drivers for them.
  22. You know, I have one just like that in my junk pile. Kinda the same reason as yours! It's a 3450 RPM motor, that's about double what a normal clutch motor for the average sewing machine motor should be RPM wise. Are machines that need such a motor though....
  23. That's an interesting point. I never cared for a treadle machine. I always found it distracting and less controllable. Less controllable that you have to keep a hand on the flywheel for braking more than you would with an electric motor. Of course each to their own style and preferences. I've probably watched 200 Japanese videos on youtube and the older treadles are real popular, even for light leather machines in production environments. Over there it's just because of the tradition and many don't want to pay for the electrification of older machines.
  24. What color were you aiming for? Use Feibing's oil dye (Pro dye nowadays). Dip dye your part and lightly work any dye that didn't absorb after 10 seconds or so so it does absorb. Some dyes such as med or dark brown require 2 dye events to get a consistent shade/color. Use a quality leather!! Herman Oak is the best for dye work. Not only does it absorb dye evenly, it dries more quickly than imported leathers. Don't use a daubler/foam brush unless you're just doing edges or something real small, same for an airbrush, why would you torture yourself with that? You'll run the risk of uneven penetration and streaks, plus it takes longer if you're making more than one item. Make sure your dye is blended well and at a proper temperature. Really cold dye will not give good results.
  25. Your bobbin tension isn't supposed to be too high, rather on the light side. That's something you need to experiment with based on your work and threads. Start with a light tension on your bobbin and adjust the top. Once you're pulling the lock to where it needs to be, see if you like the look of the stitch. If the stitch needs to be pulled tighter, tighten the bobbin a little more and then reset the top. You may also need a different needle as well. Run black on top and white in the bobbin and it's easy to see what's going on.
