Thanks for finding the forum and jumping right in. Here is a link to a discussion we had on bronc halters a while back and it drifted to flank trips. - Clink on this and it should get you there - Flank Strap Buckles
Troy, I guess those bugs are pretty common around the gulf coast area. I have had other guys tell me they use synthetic woolskins for that same reason. The weevils or whatever they are don't bother synthetics apparently. I kind of remember a pleasure/reining horse trainer from the southeast, maybe Georgia promoting the foam lined saddles at the QH Congress in the late 70s. I got to take apart one of the foam lined saddles a while back. I want to say it was from Denny Sargeant or Pard's. This particular saddle had been through a few tack sales and finally a buyer noticed it was loose and wanted to see what was up with it. The fork was loose at the base. He opted for me to remove the silver for him, and just throw it away and learned "when a deal looks to good to be true...". I took off the bottom lining for grins. The foam was starting to crumble and powder in spots, much like some of the seat foams or the firmer foam in some splint and bell boots. Probably not much difference than woolskins that start to wear at pressure spots and get thin.
Leather Shop for sale.
bruce johnson replied to froginthefog's topic in Saddle Supplies, Tools & Trees
One of those deals you're just gonna have to go look at. If the handtools are all Gomphs or HFOs in great shape, they could almost be worth the dough by themselves. The splitter just depends on what kind and condition. Three in ones are fairly common and handy to have one for the skiver if nothing else. Benches are good if you don't have any. Hardware could be alright, but usually not a lot of resale value in it. If there are old stamping tools, they could be a great addition too. Depends on who made them and condition. Notice how I'm avoiding the machines?? The Singer patch machines are common as dirt. Every shop had one seems like. Some are still functional and some aren't. Some are finicky and some aren't. They sell on ebay for a hundred or so up to $500 in good shape from a reputable seller. The Randall might be OK as a user. Again depends on condition and who wants to buy it in your area. These are not easily shipped. -
To get the easier one for me out of the way first. I use woolskins. Haven't ever used felt, but would have to question some of the reasons for it. I know it was used for either supply issues (war rationing when wool was going into war production) or cost issues on lower end saddles for the most part. Not sure how much of history it has ever had. Skirts have a few functions. One factor that is sometimes overlooked is the protection from rigging hardware and distribution of pressures of the riggings, latigos, and billets. One of those things that matching the right hardware with rigging type and skirt size and plugging would all be inter-related. No defintie answer to just skirt size without considering the other factors in play there.
Trees Explained<--that's what I want.
bruce johnson replied to Echo4V's topic in Saddle Construction
Broken forks off the top of my head. One was torn off intact after the horse hooked a squeeze chute handle under the gullet and took a jump. That was when the guy decided it was time to leave the buggy. One was broken next to the horn - flipped over on in the salebarn alley. One was a barrel racer with fiberglass that wiggled after it fell off the top saddle rack in the trailer to the driveway below. Not really broken except at the joint where it was stapled to the bars. Most of the breaks I see in users are in the bars. Most all of these breaks have occured from being flipped over on. I can only think of one that had scored rawhide. Several of the oldies I have worked on have the higher thinner cantles. Seems like the common break on them is the upper part breaking across the width of the cantle. -
Darryl, Actually I think for me this is one fo the better products they have come out with. I used the old HiLliter some. I didn't like it because it was too dark. I used Leather Glow but it was too light. No, I this isn't about 3 bears or anything. I did without special colorants and only used a final sealer. I used to like Drake's X1 and rediscovered it was back - right before they took it off again. I tried a few shades of the new HiLiter. I tried the coffee brown and it was bit too dark, the briar brown is my favorite. I use it a little differently than many do. I have cased my leather in lexol and others. I have NF oiled it. I have sealed it with a couple coats of LeatherSheen and let it dry. I used to like the way it looked right there. Now I take my briar brown and dilute it about 2 parts BB/1 part water in a squeeze bottle. I squeeze it out on a cellulose sponge cube and wipe it over the piece and squeeze a bit as I go. I want it to puddle just slightly in the cuts and low spots. I wipe over the high spots lightly to remove any up there. I leave the piece undisturbed and let it dry. I wipe on another coat of LeatherSheen to seal it. The sponge for the final LS application will slightly lift a bit of the dried HiLiter but not much. A guy who likes to clean an airbrush could use that for the final seal, I toss the sponge and cleanup is complete. I tried it like I was told first. Resist/apply full strength, wipe off quickly/ wipe off that part that got over the edge/ do all the stitch line because some got in there in one place and won't come out/it all wiped out of a beadline and you have to reapply. Now if I get some in the stitchline it looks alright. The water gives me a chance to wipe over applications before it stains something I wish it didn't. There are a lot of people where finishing is religion, I like simple by the time I get to that. The one experiment that did not work. I tried to mix the HiLiter with some LeatherSheen and come up with roll your own X1. It resembled Mountain Dew/Copenhagen spit.
Ed, Norm's slicker that I have is made from 1" stock. It is the first one he made and I am not sure if he still uses the same stock. I used to go through one of Weavers about every 6 months or so. I am still on the first one. Seems like I have had it at least a couple years?? It's the real deal.
I was taught this tip by a Tandy manager several years ago. It has worked well for me. The tip should just protrude from the leather. Forget the domed setter for now. I set the piece on a small bench anvil. I use a normal ballpeen or regular hammer - usually a 16 oz is handiest on my bench. A good smack or two sets it. If I want a "dome", then I grab the domed setter and dome both sides (I use the double capped rivets) after the rivet is set.
Pictures from the Boot and Saddlemakers Show
bruce johnson replied to Rawhide's topic in Leatherwork Conversation
I haven't been to a IFoLG show yet, but we have been to Sheridan 3 times, Wickenburg the first year, Reno a few times, and Elko for Ferdco's show. If I had to pick one, Sheridan would be it for the first time. I hear from suppliers that do most all of them that Sheridan is far and away the biggest in attendance and definitely vendors. More total classes, more variety, and more sponsored social events. This past year had issues because the management was late in getting out class info and the schedule in any timely manner. Hopefully that is going to be fixed. I didn't hear the foot traffic numbers, but class sizes were down because of that. Three vendors said sales were average or better compared to past Sheridan shows. I got my money's worth out of every class I have ever taken at these shows. It does help to research the class a bit to see if it is over/under your skill or expectation level. The social events are a blast, and a lot of friendships come out of the classes, socials, and vendor booths. -
Marlon, Thanks a bunch for posting the link to the pictures. I appreciate it, and a special thanks for showing pics of some of the exhibitors booths. Nice to see faces of some friends too. We haven't been to Wichita Falls yet, but plan to. I hope this kicks up some interest too. A lot of people on these lists wonder what goes on at these shows, or asks "where can I get this or that?". Folks, this is it in a nutshell. You can go to these shows and put your hands on this stuff. People wonder what makes some old tools better than what you see in the catalogs now. You can handle them. You can look at stamps by Bob Beard, Wayne Jueschke, or Barry King and see the differences. Sit down and test drive mauls from a couple guys, swivel knives, whatever. Everyone is welcome. Attendance is the lifeblood of these shows. It has been worthwhile at every show we have been too. The friendships with vendors and other attendees have been just as valuable. Seeing the works on display is just the icing, the cake is what you can take home. -
The splitter has been sold. Thanks for the inquiries.
On my recent travels I picked up a Krebs splitter and an old museum kind of piece - an HF Osborne Chase style splitter. I already had two Chase splitters, and don't need them all. One Chase has some sentimental value, and I am offering the better one for sale. It is a CS Osborne 8" Chase style. For those who have never used one, they are the most reliable splitter style besides the Krebs. Like the Krebs, they have top and bottom rollers feeding your leather into the blade. It just can't flip up and chop like the other pull through styles. It can't go anywhere but into the blade. Everything can be adjusted with a flat blade screwdriver as the only tool. The set of the rollers as the blade wears, the pitch of the rollers, position of the latch spring - everything. The handles on top adjust the height with a simple turn. Anybody who has asked about a splitter on these lists knows how happy I am with these Chase splitters. This particular one I am offering for $400 plus shipping. That is less than new models of other styles that are not half the splitter this one is. It might be a little higher compared to some other Chase pattern splitters you'll find, and there's a reason. I have seen a lot of these splitters in several shops, ebay, and from the guys who resell quality old tools. This is one of the cleanest, which anybody can clean one up. I have yet to see one that has any more blade left than this one though. Look at where the adjustments are, this one has its whole life ahead of it still. It's a good one.
A few factors from where I sit. First off - Is there someone close by that can teach you what you want to learn? Some makers are not really good at teaching. Some are just too busy with maintaining their own production. Some just don't know but the way they were taught. Just because a guy makes saddles doesn't mean he can teach you how to put in an all leather groundseat, a strainer seat, a skirt rigging, plate, one piece fork and seat cover or other variations if he doesn't do them. There are some really good guys at doing each of these, and you may have to travel some to find the right guy who can teach it. Classes - I did the saddle week at Sheridan a few years ago, and it is funny how many guys on this list did it that year. We all probably learned as much from each other as we did from the instructors. I got my entire money's worth when Don King stopped by and held court for a while during a break. A couple of special times spent around him, and that was one of them. There are classes at several shows. You can ask away. You may or may not do anything like the instructors, and may not after you leave. At least it makes you question what you think you know. The biggest thing I have learned in the last few years is how many different approaches there are to do things that seem to work. The old "closed shop" mentality seems to have faded from the guys I visit and talk to. Yeah, they may not be telling me everything, but nobody has withheld the big stuff. You can pick stitches on a few skirt relines, then someone tells or shows you how to skin the topstitches before you pull the wool. You appreciate it that much more. I am pretty lucky. I have had access to some old guys who can tell you how it used to be done, and on this list you can talk to some modern makers at the top of the game. Not everyone agrees and shouldn't. I am in an area kind of thick with saddlemakers on several levels. I have only ever had one guy totally refuse to tell me something, and that was pretty minor. I used to get a lot of telephone advice, pre-internet. I have had guys invite me to "come and spend a day, and I'll show ya how I do that". They have universally refused any money. Later I have either sent them a pair of monels, something I have that we talked about, or a gift certificate for a toolmaker. It has been worth that and more in every case. I am lucky with my wife too. She is pretty tolerant of me visiting folks when we're traveling. Last spring we stopped by to see Clay Miller in Rapid City. He told me that I should really go visit Ken Nelson. About 4 hours later we left Ken's. We stopped by Keith Pommer's and looked at machinery and tools for a few hours last week. I always end up smarter after I have talked to Bob Douglas, too. Last week we were at a dance in Cody WY. We met Keith Seidel there and he invited us to his shop the next day. Had a very enjoyable visit that morning. Most all the people on these lists are pretty approachable, and some of the best talent in the country is right here.
zippered rifle case
bruce johnson replied to Hilly's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hilly, I can only think of one item I ever did where I sewed the zipper directly to a case. I sew to gussets. I don't much like to use vegtan for most gussets. You either use thin enough leather that the integrity might be an issue or score it for the sharp crease to stand up. And that score might be the weak link. Another downside is they stand up once you do that and can be a pain to get things in and out of unless the piece opens flat. I like to use something flexible. On planners I go down to thinner chap. On bigger things like briefcases I like to use either heavier chap - 4/5 or so, or hair-on hide. I did one for a guy who is liking Diamond Tan better. For rope bags I use the heavy chap if they want a bag that collapses or my preference - Siegel's Diamond tan. The DT has a little more body and doesn't slouch like chap, but not as firm as latigo. Holds its shape, but you can reach into it and it moves out of your way. All of these can be had in a color that either matches pretty close, complements, or contrasts depending on what you want. Remember if you want a match, your vegtan will age and darken faster than the chap or DT. -
Exotic Ethics?
bruce johnson replied to badLoveLeather's topic in Exotics, Reptiles, Furs and others
I come from a livestock background, and am just as narrow minded as anyone. Hides are a by-product, although now they call them "co-products" and animals are "harvested". I worked on the "kill floor" of a ''slaughter plant", so I guess that makes me a senior. I have no issues with animal rights people if they are informed and actually have seen the issues for themselves or might be affected. I had issues with people in San Francisco or LA, people who will never own a horse or be affected in the least, voting and telling me how I can or can't dispose of a dink horse. That was the the start and it ain't over yet. Legislated animal rights is not probably the answer to most of these issues. Ask the folks on the CA Monterey peninsula who voted to ban mountain lion control. Their dogs and semi-pet deer are being eaten in front of them now. Most of the exotics we deal with are not endangered, and that distinction is sometimes lost on the uninformed. The non-farmed exotics covered by the CITES program may not be perfect, but it is probably closer to the bone than other systems. Our generation didn't make all this mess we are in, but I am not thinking we need to go back to ripping out fence and great buffalo herds on the plains, or things like that. World-wide the whole thing is off - prey animals with limited territory and feed, limited or too many predators, and disease due to concentration. Things got off at times without our help too. If they are managed by controlled hunting (and then utilized) to enable the rest of the species to at least maintain, I have no issues with that. If those hides are used and not fed to bacteria, bugs, and buzzards - so much the better for the by-product users and the awareness it brings. -
Art, MS Collins may have some more info on these. I think his great uncle made the Newell saddles. I expect they might be a little hard to drill the rigging screws into.
Art, I finally got the time to go through this thread. I've got a few to add. The first is Rundi and I at one of the horse sales my son was auctioneering. The next is my son Travis selling at a western art sale he put on. His first sale for his company, not contracted out to sell for someone else. Finally a few recent pics. Rundi and I flew back to Indiana to visit my parents in Indiana. My mom is dealing with cancer and their camping days are done. They gave Rundi and I their pickup and camper. We are selling the Capri rodeo camper that has been the home on wheels the last few years and movin' up. The final pic is me standing in the driveway of Harvey Lutske's place in Wapiti WY on the trip back. Harvey was in LA , but I got to see the summer estate anyway.
Russ, I have a B-100 and was in the same boat a while back. I couldn't find anything locally. Ironically, the worst selections of staples I found was at... Staples. I ended up and got a box at an antique store. I am getting low on them and looking again. One guy I talked to said that some of the Arrow staples will work, but I haven't got around to trying them yet. Anything on Google searches leads to places with pretty big minimums that I found.
Shell Cordovan Belts
bruce johnson replied to antipaladin's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I'd like to see some cordovan sometime. I was thinking that shell cordovan was a thinner leather. The "horse butts" are left over after the shell is removed, and it is horse butts used for holsters? The one horse butt I had was about 8/9 oz. The hard roll vs. soft roll horse butts has to do with the amount of pressure they apply to them to compress. Ringing a bell with anyone? I talked to an old guy a while back that likes the hard roll horse butts for lining monel and brass bound stirrups. -
Looks like just the footwear I need to wear to the upcoming season of lutefisk/meatball supper/pickled herring feasts. Tak skal du have.
I have been taught two ways to skin the handhole. Originally I was taught on the swell forks to make the hand hole cuts in my ground seat buildups as I went. The first few slickforks I did it that way too. I then went to cutting the handhole last on them, and like that smooth transition behind the horn better. Curious how everybody else does this, and any tips and tricks are always appreciated.
Jon, Good looking saddle. I especially like how you made the back string button the center of that swirl in the tooling. It makes it look like that button just belongs there. Bruce
A couple of newby questions from the mom
bruce johnson replied to hvl's topic in Leather Sewing Machines
hvl, There are lot of loyalties among leatherworkers for sewing machines and suppliers. You'll no doubt get a lot of advice. I am keying in on your description of "reasonably priced". Also since you are doing tack work, cylinder arm machine first. You can always make a flat bed for it. If you find more need for a dedicated flat bed machine, those are more available. If there is any way you could get to a trade show, or spend some time in a shop with a few different machines, it would really speed your learning curve along. I've had both of the machines you mentioned. I bought a Boss when they were the only thing that could sew what they did for any kind of lower price. Even early on they were about $1600. I had very little problems mechanically with mine, and they were taken care of PDQ. It would sew chaps, skirts, or tooled corners on felt pads with ease. Actually ease on the machine, a little tiring and boring for the guy cranking the handle. Once I got the tensions set the way I liked them, the only adjustment I ever had to do was the stitch length. The Boss machine tends to keep a decent resale value. Tippmann will rebuild them and warranty a used machine like new. The throat is only about 6" though. When it was time to move to a powered machine, the Ferdco 440 was again the only thing available in that price range. The biggest problem I had with it was the feed system. It is a needle feed, and the throat plate has dogs (teeth slanted back) to keep the leather moving through with the needle pushing it, and not back up. Those teeth made a heck of a mess on the backside, and especially going around corners. I know guys who have these same type machines (sold under several names by different sellers) and some like them for what they have them dedicated for. I don't have that luxury. I called Ron and told him this wasn't going to be the machine for me. For not a whole lot more money, he sent me an Adler 205-64 head, and I sent the 440 head back. I was green as a gourd about machines. I didn't ask the right questions, and didn't understand and communicate very well when I ordered the 440. I have since traded up in machines, and sold the Adler for more than I had in it. Those machines are probably past the "reasonbably priced" entry machine. Now there are more choices. There are at least 4 or 5 sellers that have the short arm Juki clone machines. Looks like everyone has had a recent price increase, so they pretty much are $2100 or better. A much more versatile machine than the Ferdco 440. Most everyone is happy with the machines. Soooo, what would I do if I was buying right now? If the budget was $1500 or less, I'd get a Boss - new or used (less) and let Tippmann rebuild it - used to be a flat $100 fee. If I could go up to $2500 or so, I'd look at one of the short arms if I had to have a new machine. Figure you are going to pay shipping and need attachments too. Negotiate for some attachments when you buy it. They are not inexpensive usually, and will cost more later. For the same $2500, I'd also think about calling around to the dealers for a bigger used machine. The Adler I had was a great machine, in the end I used it for 4-5 years and sold it for $200 more than I paid for the table, motor and the head. I used it for better than free. There are other good machines sitting. Ron at Ferdco usually has some or knows of them, there are some other dealers who pop up on the forum. A lot of guys use a screen name, so I don't know all the players. ShopTalk has ads from most of them. Tell these guys what you want a machine to do, your level of experience, and most of them will bend over backwards to get you the right machine or refer to someone who has it. They know it won't be the last machine you buy. Final thing since you probably have not dealt a lot with these big machines - service. Most all of the guys selling machines can service them, and talk you through problems. You normally don't pack them up and take them to the VacNSew guy at the strip mall. Artisan has an exlempary reputation for service, as does Ryan Neel. I have bought 4 machines from Ferdco, because of their service and the way they treated me on the 440. I had a part break on the Adler, and knew zip about it. The tech talked me through the diagnostics until we found problem - over an hour on the phone and quick shipped the part. I work early mornings in the shop. He offered to call me at 4:00 or 5:00 am his time to talk me through installing it, so we could do it before I had to leave for work. I'm pretty happy with them, yep. -
What are you drinking right now?
bruce johnson replied to JustWakinUp's topic in Leatherwork Conversation
Saturday night here - Pendleton or another gin and tonic - The first G/T has been very enjoyable. I haven't had one for a good long while and it is reminding me with its smooth taste and drinkability just why I gave them up years ago. Probably go with the Pendleton to do a comparison. Home for the night, so I can do that I guess.
