What you see is not a reduction, it is a separated clutch. See where the chain from the pedal goes to. Some early "electrified" heavy machines had these separated clutches. Adler used them as well. You sometimes find them on top of the table and sometimes underneath the table as in this case. Will see if I can find my old Adler brochures...
BTW - what I can tell from the pictures is that both machines DO NOT have the bobbin winder installed. So check if they are present or not. I have one for the 45K if it does not come with the machine. http://leatherworker.net/forum/index.php?showtopic=58471&p=376093
A thousand or more is too much I´d say. Thats probably a dealer price but as a private seller I think 400 - 700 is realistic. It depends on how the market in your era is. If you want to sell them fast the price has to be quite low but if you have storage space and the time to wait for a customer who really wants exactly the machine you offer you can ask a bit more I´d say. The 45K has no reverse and it is 1940 built (according to the serial number). New build Chinese versions of it cost 995 w/o reverse to 1295 with reverse but they are new and come with servo motor, speed reducer, table, warranty, a dealer service and so forth. So I don´t see a thousand for the 45K. I think 400-500 is realistic. If it had reverse maybe a 100 more but it is w/o reverse. The Adler 30 is one of the later models, the early ones are all black but the greenish ones are about 1950´s - 1960´s build as far as I know. And since it is a 15 subclass (double digit) it probably is from the 1970´s I guess. So it is a "relatively new" machine compared with the black Adler 30´s in general. Considering the overall optical condition I´d say you can get 500 - 600 for it - maybe more but I don´t know how the prices in the US are for these machines. The documentation for this machine is quite good, I think I have a manual and a mechanics instruction PDF so I can add it here if you want. BTW - ask if the machine come with some accessories and / or spare parts. This would be a big advantage as parts are quite expensive and you can make some more $. I´d test them before you pay big $ and if they don´t work you have to be careful. Look for manuals in advance, read them so you don´t look like a fool when you are testing them. In general the needle and hook timing are not a too big issue on either machine. But I cannot judge the overall condition from the distance. Asks the seller how much he wants and don´t make offers otherwise he will probably go up with the price. I personally would buy both but depends on the price and if they are in working condition or not, if parts are missing or not and if the machines probably have extra accessories or spare parts. As I said, if it is just the needle / hook timing it would not be a big issue.
Not sure if it will help you but you can adjust the fly wheel on the upper shaft. You have to loosen the set screw and then turn in the adjustment screw (which is in the center of the fly wheel) a little bit. I hope the adjustment screw is still present as it is missing sometimes. Don´t forget to fasten the set screw again. Is it possible that the "clanking" comes from the hook era? That would be quite normal of the old 45K.
You could look for a used one instead. Another option could be to check out some dealers on the Continent. You save the import taxes as the UK is (still) in the EU. Not sure if you will find a Consew 206 over here but there are for sure other machines with similar specs.
I have a Singer 307 G2 which runs like a dream. I use it for zig zag tacks, some zig zag darning and sewing lighter materials. Great machine with M size bobbins! The feed dog that came with the machine is pretty wide as it can produce 6mm zig zag stitches. Interestingly the 307 G2 can accommodative needle plate and feed dog of my old Duerkopp 252 (needle plate it is a bit narrower but it fits) though the needle plate has different screw positions but the 307 G2 has 2 extra screw holes so it works. The Duerkopp 252 is obsolete and accessories are no longer available. But I know the Duerkopp 252 is pretty much a "clone" of the Singer 107W or 143W. So I wonder if someone knows if the Duerkopp 252 and singer 143W or 107W are using the same needle plates and feed dogs? Or is it possible that the 307 G2 is using needle plate and feed dog of some newer models like the Singer 457 (not the domestic of course) or other models? Looking forward to some input Some pictures with measures:
Have you insert the needle correctly? Are you using the correct needle? The 29K takes 29x3 (332) or DPx17 (135x17) needles. There is not very much to time on the 29K. Check this post, it should help you - hopefully http://leatherworker.net/forum/index.php?showtopic=52583&p=336139 You may have to do some "fine tuning" but thats basically all you can do. Not sure how your gearbox looks inside but when it is a 29K71 clone you´ll find the correct set up for the gearbox in a manual you can download here: http://leatherworker.net/forum/index.php?showtopic=57862&p=372012 It is not for exactly for the 29K71 but gearbox looks the same inside - see page 24 / 25 in the manual.
You´re welcome. I´m glad when I can help.
Singer 29K51 Info Wanted, Keep It Or Junk It?
Constabulary replied to boilernspector's topic in Leather Sewing Machines
It depends how dirty your machine was . The 29K is quite easy to adjust. You should have asked here in the forum before. You can download a manual here: http://leatherworker.net/forum/index.php?showtopic=57862&p=372012 Not exactly the same machine but the basics are pretty much the same. -
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
I know nothing about it but for this price I´d buy it anyway. I think there for sure a couple of owners around here who can help you to put it back in service. Even the parts would be worth way more than $150. Just my 2 cents
I have a manual for a Rex or Chandler which seems to be the same machine, I think it will help you rex_Chandler.pdf
Balance Wheel / Hand Wheel - Parts No 82404 - $45 This thing is heavy and shipping depends on destination.
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
You forgot the screws and bolts =============================================================================== Needle Bar Clamp - Part Number 91022 - $12
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
Tension Release Assembly - Including the Parts No 82150, 91568, 91567 + 3 screws and 1 set screw - complete $25 This is attached to the presser foot bar and divides the upper tensions discs when foot is lifted
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
Face Plate - Parts No 91006 - $25 Shipping for this particular item is more - registered Airmail will be $12
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
Shuttle Race Slide Plate (Back) - Parts No. 91057 $20
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
- 28 replies
- bobbin winder
- spare parts
(and 1 more)
