cord1974
Everything posted by cord1974
If you can print it out, I'd use tracing paper or vellum to draw the pattern out.
I made one many many moons ago. About 8 oz of #6 birdshot worked well. They were, at the time, legal for CCW holders on Florida. Not sure how the law would have reacted if used though.
Here's an Ernie Hill for sale. If you look at all the pictures you can get an idea of how they were constructed. https://vintagegunleathertoday.com/products/ernie-hill-speed-plain-black-leather-competition-holster-for-s-w-745 I'm trying to think of the other big names of the late 80s era but my memory isn't as good as it used to be. If you really want to go old school (late 70s era IPSC) look at the Milt Sparks 1AT or Hackathon Special. Or a Davis Omega. https://shop.joesalter.com/Vintage-Milt-Spark-s-Hackathorn-Special-45-1911-Competition-Holster https://www.1911forum.com/threads/gunsite-omega-and-or-liberty-holsters.1030638/ Sam Andrews has discontinued his IPSC Saddle style holster. But it's a good design for competition. http://www.andrewsleather.com/ipsc.htm I haven't made any of the above designs but I have thought about it. Ernie is still around. He's on Facebook and has answered a few of my questions over the years. Hope any of this helps.
Do yean something similar to the old leather IPSC rigs like Ernie Hill used to make?
Why buy Tan Kote?
cord1974 replied to toxo's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I use to "wash" after antiquing. I also use it as a topcoat for items that will need conditioning in the future. -
When I'm making a new strop or reloading an existing strip I grind up green compound as fine as I can get it. Then I add a bit of of oil to make it slurry. I then run that into the leather. I have no evidence that it works better than just rubbing the compound directly on the leather but it's how I've done it for over 20 years and it works for me
Sorry so late in responding.. I only use lacquer as a resist. If antiquing a projects my steps are: Tool Oil Dye (if color other than oil tan) Resist (lacquer) Antique Finish My main finishes are Tan Kote, Bag Kote or Resolene depending on the article. As for the lacquer itself I think it's Minwax or whatever the brand Lowe's sells. I've used both liquid applied with a dauber and the spray can version. I've noticed no difference in the result. But again, it's only used as a resist.
Dye Reducer
cord1974 replied to Dwight's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I use either denatured alcohol or 91% isopropyl alcohol. I haven't ever noticed a difference between the two. -
Best hide for belts, and best edging tools
cord1974 replied to shadowryder's topic in How Do I Do That?
If you follow Hidepounders instructions you will have an amazing edge when you're done. The real game changer for my edges was going with saddle soap and a canvas rag. So much better edges than the wooden slicker id been using could provide. -
I'm in a similar situation. My left ankle is fused due to nerve damage. I have my cobbler put zippers in all my left boots. Brass teeth YKK is what he uses. Not sure of the actual name of the product line.
Yep.. Should have picked up a lot of Barry's tools
I got a good one. Not going to lie.
When I went to Sheridan in 2022, we stopped by. My wife and son stayed in the car. Spent about 20.minutes trying stamps and talking to Barry. I come back to the car with a maul, a basket weave and two bevelers. Wife says, "that's all you got? I mean you're AT Barry King's!"
Steep checkered beveler: B936 Medium checkered bevelers: B701, B702 Pear shader: P206, P208 Flower center: J816 Backgrounder: A114 I have the others but these are the ones I've used so much I remember the actual numbers.
Edge Kote is just that, a costing. It will sit on top of the edge. My experience with it is that it will eventually flake off. Dye penetrates the leather and if properly finished, vis pretty permanent. Can't help with question about lining as I've never used felt. Chamois would be similar to suede, I suspect. I think the contact cement would be fine for it.
Dyeing, 2nd Attempt
cord1974 replied to Gosut's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Tandy's imported veg tan will darken with NFO. I use it on almost every project in lieu of dye if I'm trying to achieve a lighter brown color. I use multiple light coats until the desired color is achieved. -
Steel Belt Liners
cord1974 replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I've always said "bonded" leather is nothing more than a leather version of presswood. It doesn't even rise to the level of OSB. -
Steel Belt Liners
About 25 years ago, back when I was shooting competition heavily, I made a steel lined belt. 2 ply 8/9 oz 1 3/4" Ranger style belt with a thin strip of steel centered. The billets were sewn on the outer strip to avoid the need to punch through the steel. But we did do a double stitch line on the belt. It worked well for several years of daily wear and weekly matches. Eventually I got tired of the stiffness and took the steel band out. I unstitched on edge, pulled the steel with pliers and sewed the edge back up by hand. The belt is still in my closet. Unfortunately I'm not as thin as I was back then.
