cord1974
Content Count
30 -
Calendar
Everything posted by cord1974
I'm in a similar situation. My left ankle is fused due to nerve damage. I have my cobbler put zippers in all my left boots. Brass teeth YKK is what he uses. Not sure of the actual name of the product line.
Yep.. Should have picked up a lot of Barry's tools
I got a good one. Not going to lie.
When I went to Sheridan in 2022, we stopped by. My wife and son stayed in the car. Spent about 20.minutes trying stamps and talking to Barry. I come back to the car with a maul, a basket weave and two bevelers. Wife says, "that's all you got? I mean you're AT Barry King's!"
Steep checkered beveler: B936 Medium checkered bevelers: B701, B702 Pear shader: P206, P208 Flower center: J816 Backgrounder: A114 I have the others but these are the ones I've used so much I remember the actual numbers.
Edge Kote is just that, a costing. It will sit on top of the edge. My experience with it is that it will eventually flake off. Dye penetrates the leather and if properly finished, vis pretty permanent. Can't help with question about lining as I've never used felt. Chamois would be similar to suede, I suspect. I think the contact cement would be fine for it.
Dyeing, 2nd Attempt
cord1974 replied to Gosut's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Tandy's imported veg tan will darken with NFO. I use it on almost every project in lieu of dye if I'm trying to achieve a lighter brown color. I use multiple light coats until the desired color is achieved. -
Steel Belt Liners
cord1974 replied to 327fed's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I've always said "bonded" leather is nothing more than a leather version of presswood. It doesn't even rise to the level of OSB. -
Steel Belt Liners
About 25 years ago, back when I was shooting competition heavily, I made a steel lined belt. 2 ply 8/9 oz 1 3/4" Ranger style belt with a thin strip of steel centered. The billets were sewn on the outer strip to avoid the need to punch through the steel. But we did do a double stitch line on the belt. It worked well for several years of daily wear and weekly matches. Eventually I got tired of the stiffness and took the steel band out. I unstitched on edge, pulled the steel with pliers and sewed the edge back up by hand. The belt is still in my closet. Unfortunately I'm not as thin as I was back then. -
20 year old products?
cord1974 replied to Bryan's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
With black you really have to buff it well. Start with a soft cloth or wool. Buff it. Buff it again. The buff it some more. When you think you're done, take a soft paper towel and buff it. If any dye pigment comes off, start over. After buffing seal with your sealant of choice. -
I've been noticing Tandy is carrying less and less of a selection in Pro Dye in quart bottles. I've been to two larger stores (Jacksonville FL and Tampa FL in the last several weeks) and only found a few shades of brown available. I would guess they're phasing out a lot of the Fiebings dyes in favor of their Eco dyes.
Natural Colored Letters on Dyed Dark Leather
cord1974 replied to vthokie7227's topic in How Do I Do That?
I recently did a few belts this way. After stamping I resisted using Wyosheen. After that dried I mixed a bit of dye with the Wyosheen (I read about that trick in one of Stohlman's books) and carefully used a small paint brush to go around each letter. After I'd gotten enough distance from the letters I dyed as usual. -
Tandy Neat Lac
cord1974 replied to cord1974's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
That was my thought as well. I do like Resolene. And I'll end up using both eventually. Between Leather Balm, Resolene, Gan Kote, "Neat Lax" and Wyosheen I have all my finishing needs covered. -
I haven't ordered from him yet but I've read nothing but great reviews about him and his business.
Tandy Neat Lac
Edit: Springfield says Clear Lac has been discontinued. Ordered through Barry King! -
Tandy Neat Lac
Thanks! -
Tandy Neat Lac
I'm on Springfield's page now and can't seem to find it. Any suggestions? -
Tandy Neat Lac
I know Springfield has the "old faithful". I guess I need to go ahead and order some. I was just very disappointed. -
I was in a Tandy store a month or so ago. Hadn't been in about a year. I got all excited because they had brought back "Neat Lac". Has anyone else used this yet? Because unless I'm losing my marbles I don't think this is the same as the old Neat Lac they used to carry. Old Neat Lac was thicker and had a much different smell. The new product is thin like Resolene and behaves and smells very similar. Anyway, just wanted to see if anyone has had a similar experience.
Sorry to drag a thread back from the dead but... If I'm doing something that will be worn I generally don't dye the flesh side. I do coat it with a finish though. My personal method: tool or stamp then one light coat of neatsfoot. Dry at least overnight. Sometimes as little as 8 or up to 16 hours. Then a second coat if antiquing. If not then dye. That again dries at least 8 hours then buffed and coated.
Glueing large areas?
cord1974 replied to tH3dOuG's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Used it before to glue holsters. Great for a lot of stuff.
