toxo
Contributing Member
Everything posted by toxo
  1. Wasgoinon? You're all supposed to be using blunt harness needles?
  2. Without proper tools, what I would do is take a piece of wood or maybe a 2ft ruler and two pieces of wood maybe 5 inches long. Put ruler on top of head on edge, clamp the two short pieces front and back and clamp when they're touching the head. Do one measurement for front to back and another side to side. Measure the circumference of the head with a soft tape measure and draw it on paper making sure the circumference touches the measured front/back and side to side. Add a seam allowance for stitching.
  3. Been asked for a pink dog collar. Got red fiebings, got white acrylic, they don't mix. Any ideas peeps?
  4. toxo
    Dog collars.
    ThanksTom, although no longer puppies by some way. Although there's no danger of them running off I don't want to risk it. People ask why I'm not worried about them running off? Not a chance. If I'm sitting on the loo the three of them will lay at my feet. Teddy looks good. Terriers have so much character.
  5. Here's a little gadget that I use for cutting circles. It's plastic but if handled gently will do the job. I've had this one for at least two years and I love it. If you don't want the hole a small piece of leather stuck in the center with double sided tape will do the trick. Here's a small video.
  6. Well that's the point isn't it. We can all find the center but these gadgets just make it easier and maybe quicker.
  7. This thread should be gold for those that come after. A couple small ones to start. How often do we need to find the center to place a tag or line up stitching? I might be slow on the uptake because I've only just stumbled across these centering rulers. One is stuck to the bench and the other is a plastic ruler that is see through with a metal edge for cutting. This next one I've ordered but not here till tomorrow. I needed one of these the other day and didn't have one so like a lot of things I improvised. Flexible Ruler 16 Inch 40cm Curve Ruler for Engineering Drawing, Design Graphics | eBay More to follow.
  8. toxo
    Dog collars.
    I daresay there are but my point was that there is no standardisation so if you intend getting into foiling you'd best buy your three sets of letters from the same company at the same time. If you look closely at my original set, the shoulders are bigger below the number. if you turn one around they won't line up. This latest set do appear to be more equal top/bottom so the "9"s and "6"s probably will match but they're no good to me because they're bigger overall and in the shoulders and won't fit in any of my three letter holders.
  9. toxo
    Dog collars.
    Not sure why you're asking but this is the 1st set I bought after some searching because of the extra letters. The second pic shows the extra set I bought to get the 2nd "9". The two on the left are "6"s and the bit that set's them apart from the "9"s is the shoulders. If you turn them around they won't fit in the holder. The ones on the right come from the second set and are completely different. They would be fine if all your letters were the same but this is what you get when ordering from different companies at different times. I had to file down one of the second "9"s to alter not only the the shoulders but the overall fit in the holder.
  10. Thanks guys but it would've looked better without the flat simulated sinew. Only went with it for the colour. Still - one of my favourite sayings - Don't let perfect be the enemy of the good.
  11. I'm not complaining. Had the good stuff, 4 bed house in London. Horses in the garden. Acorse that went to the ex wife and kids. Happy enough now with the little bungalow and small garden for me and the three dogs. Have a massive park and woods fifty yards away. Have a library/media center 70yds away, a great shop 100 yds away for groceries. A nice drinking club 2 mins in the car or a longish walk. All I'm missing is a good woman to put me in my place now and then.
  12. Oh my heart bleeds for you Chuck. Try doing it in the bedroom.
  13. Maybe not. Depends on how much thread is sticking out past the securing nut. The aluminium boss that the nps slides onto is hollow. Don't have a lathe anymore but I'll give it a try.
  14. I think I'm gonna try to fit the normal NPS onto the motor pulley. The machine is perfectly usable and will get better as I get used to it but I do like my NPSs.
  15. Thanks for that 1hp. I'd kinda figured out that much but was thinking was there more to the first part where it talks about needle up/down. Is it saying the motor can do this or only in conjunction with a traditional NPS? Here's what mine looks like.
  16. I appreciate that but the blurb seems to be saying that the motor is capable of needle positioning on it's own. If you look at the picture the two dots above the "P" are for needle up and needle down. I like having needle positioning. On my other two machines I've replaced the handwheel with a larger pulley to slow down the machine which it does very well as well as giving more torque and the normal NPS works very well on both. I wonder if the normal NPS would work on the motor pulley?
  17. Does anyone have an English user manual for this motor? It came with my new machine which is a copy of the Techsew 2750. The motor seems ok and I can get it to start really slowly and speed up on the treadle but apparently it has a needle up and a needle down setting. It came with a normal NPS as well but I can't get that to work properly because the machine has a speed reducer. If someone was really good on this machine they could almost get the needle up/down on the treadle but I can't do it with any consistency. The user manual for the motor is mostly Chinese and the English bits just make me laugh. Any advice anyone?
  18. toxo
    Dog collars.
    Finally got their collars done. Modern advice is no name, just phone number in case they get stolen (was a spate of it over here). Trouble was my letters only had two "9"s and my number has three. Eventually ordered more letters and numbers from China and the damn things were slightly different. They wouldn't even fit in the "T" slot holder. Sending back wasn't an option so I set to with the Dremel and file and got it done. If you look closely you can see the odd one out but at least the dogs can go out with their new collars.
  19. Finally got it done. Not perfect by any means but it does what it's supposed to do. Didn't help using the wrong thread and had a blip with the stamping but overall I'm pleased and as usual I learned a lot. It's already had a couple of turns through the Microwave. Still not sure about smelling leather whilst I'm drinking my tea but no doubt that will go away. Mistydog was my soulmate. She would bring my slippers whenever I came home. Now I have two of her Granddaughters and her great Granddaughter.
  20. Welcome from Medway, Kent
  21. Not that I've done it but a good way to shape wood severely is to laminate thin pieces steamed around a jig or form and glued up. I know it as the West system and they lay up yacht hulls with it. It's very strong.
  22. toxo
    Spikes
    Got some dog collar types with fold over tines somewhere but can't find the damn things.
  23. Is the wheel part of the press? If so what does it do?
  24. Looks good. That watch needed a nice strap.
