toxo
Contributing Member
Everything posted by toxo
  1. Looks good to me. If not quite right just turn those discs.
  2. That one looks way better than mine.
  3. Not the proper way to do it but inside the black cover you'll find two discs, each one has a cut out and the cutouts will be opposite each other, These cutouts are needle up and needle down. You can slacken them enough to turn them by hand to get them where you want. But don't tell anyone I told you.
  4. It's easy. You should have an L shaped rod with a thread on one end. Probably a hole quite close to the handwheel. The threaded part screws in there. It's sole purpose is for the L bit to sit in the slot in the black bit just to stop it turning around. Only by that black bit keeping still can the machine work out where the needle is.
  5. Exciting innit!
  6. I already have done. I have her on WhatsApp. Trouble is 8 hrs difference. I could probably work it out but I doubt I'll be using it. The actual roller is quite small and whichever way it goes together, there's very little sliding going on. More like unscrew and move to another hole. Can see it being set up for one job and left there. @DieselTech Thanks mate but I hope yours is better than this. I hope I'm not missing something and it turns out to be brilliant. Finished messing with the pedals. Just moved the big one as far to the right as possible and the little one as far to the left. Will still take getting used to but better than it was. Just the needle positioner left to do now.
  7. Some great advice here but before all that, does your project warrant edge beveling at all? In the image above, I don't think so, Not thick enough for beveling. A good straight cut, maybe a light sanding, job done. Especially with soft Chrome tan leather.
  8. First demerit - threaded hole missing for the L shaped rod that arrests the needle positioner. Not much of a problem, just annoying. On the plus side there's a QR code on the side of the machine that instantly gives you the instruction manual. The drop down guide has defeated me. If anyone has a pic or anything that makes sense out of this - Please. Just messing with the foot pedals at the moment. Just tweaking really. Gonna take some getting used to, having a pedal instead of a knee pad for the presser foot. The flatbed is good and simple to put on. The arm is a bit chunky compared to some but I guess it has to be to house the massive 28mm bobbins and I can't say I've ever needed the thin one on the Adler 69. I will do a video when it's all done.
  9. welcome Ingrid from the UK. Lots to learn here.
  10. Update! Everything done except the drop down guide which is a nightmare. loadsa strange looking bits and no structions. Not for the main build either. Had to match up all the screw holes. Had a little sew, was good off the bat. Oh and still have the needle positioner to do as well. More later.
  11. You could cut oversize, then glue and turn the long edges. That would add substance, slightly reduce stretch and look better.
  12. It's here. Putting it together as we speak. Haven't found any damage so far. Can't wait to sew something.
  13. JL341L-2 WALKING FOOT SEWING MACHINE. #sewing #handmade #leather #diy #sewingtutorial #embroidery (youtube.com)
  14. Got a phone call today tom say I've got a pallet coming tomorrow. "What's on it?" Says I. "Don't know" says she, "we're just the courier". Dare I hope it's my sewing machine, come to visit me from China? Thing is, I was told the ship wouldn't be docking until March 30th and then I didn't know how long to my door. If it is the captain has done well to avoid all those missiles so well done. I'm beginning to get excited.
  15. Not the same but I'm having a similar problem with the foiler ie lining things up. The letters/stamps point downward and then you have the foil between the stamps and the leather so you have to ensure everything is lined up before you pull that lever. 400mm sounds enormous. My diddy Laser does nothing like that.
  16. Even a Brit can see that is a thing of beauty. Well done sir.
  17. No need ! Just get in a position where you tap the chisel and immediately put the hammer/mallet on the leather. It's enough to pull the chisel out and much quicker than those plate things. Mauls are not so good in this respect, they don't get as close as a mallet.
  18. Firstly you need to sharpen and polish your chisels just like any other cutting implement. Then run some wax along the stitch line. Then every now and then stab some wax with your chisel, even a bar of soap will do the job. You won't have any more trouble getting it out.
  19. If using a dauber, don't put it in the undiluted bottle. It will colour very easily. Try putting some 50/50 in a different bottle as a stock solution and don't put the dauber in there either. Pour a little in a cupcake size container and dilute that if necessary.
  20. Don't over think it. A pricking iron or a pricking wheel will mark for penetration later. A stitching chisel will mark and penetrate at the same time. Just scribe your stitching line, then with your multi pronged chisel you hang the first prong over the edge which ensures everything will marry up and start to drive the chisel through the leather along the scribed line. Start sewing.
  21. There are many variations of hand stitching. A punch will make a hole whereas a chisel will make a slit. It takes a certain amount of skill to use an awl and look good when finished. If using a pattern the holes will often be marked. This is where confusion comes in. You may buy a set of punches/chisels for one project only to find the distance between stitches on the next project has a different distance. A single punch will do for all until you know what you're doing, a good set of punches/chisels are not cheap. If wanting a sloping stitch you can use a pricking wheel which has spikes and will mark all the places to make your hole for stitching, or use a pricking iron which is designed for just marking the leather. The trick is to go through both pieces together or if doing each piece separately, make sure you start at the same place else they won't match up.
  22. I had exactly the same problem a while back. I had some nice faux croc that I wanted to make a gym bag out of but it wouldn't stand up. I ended up lining the whole inside with veg tan and it ended up more like a stylish suitcase. I sold it.
  23. Firstly there's no mystery to leather work. Most of it is common sense. If you want to do two needles, use a bigger hole or smaller needles. Nothing wrong with one at a time. The learning curve comes when you want it to look good. You don't want to see half a hole next to the thread. I would advise you get a single hole punch with changeable heads. Will also do for rivets and belt holes.
  24. I've done this on both of my machines. A Durkopp 239 which is almost the same as a Singer 111 but with reverse, and an Adler 69. A very cheap way to slow down. Bear in mind this is on a servo motor. You'll find me on here somewhere with more details. You want to look for a "Taperlock Pulley" You choose the size of the pulley you want (270mm for me) and the center boss you get to fit the back of your machine. IIRC the whole thing inc small pulley and belt cost around £40. I can do a stitch at a time.
