toxo
Contributing Member
Everything posted by toxo
  1. I knew you guys would come through. Thanks guys.
  2. This may be a stupid question but I'm gonna ask it anyway. I want to make some piping for a leather bag using lightweight soft leather. The problem is all the cordage I'm finding is like a loose soft rope and the result is lumpy and bumpy. There must be something out there that's smooth. I'm even thinking about hanging it up with a weight and a tighter twist and some glue. I know you knowledgeable guys will have the answer, preferably in the UK.
  3. Just ordered one of these. Looks like it'll do what I need. Would've referred to get the German Scharfix but couldn't justify another £250 for something that'll get used probably twice a month. https://www.ebay.co.uk/itm/DIY-809BP-Leather-Craft-Edge-Skiving-Machine-Leather-Splitter-Skiver-Paring-Tool/312839114575?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  4. Go watch Chechaflo doing it and be amazed. https://www.youtube.com/results?search_query=chechaflo+steering+wheel
  5. Update. For future information the bolts are M6x1 and takes a 5mm drill for the tap. I got over the siting problem by cutting the end of the bolt hole to the right just enough so the presser lift is clear. I ran into a slight snag when drilling the left hand hole. I got part way in when the drill snagged. put a torch on it and it looked like hole in the casting. Was deep enough for the tap so was ok. Was a bit fiddly but all working as it should.
  6. Firstly, can the manual skivers that are around six inches wide adnd cost around £120 do edge skiving? Secondly here's one for those that like the old stuff to mess around with, Just found it on ebay, https://www.ebay.co.uk/itm/143489686887
  7. Interesting! It reduces the bulk by the bump caused by the second fold. So the first stitch goes through two layers and the top stitch goes through all three? What leather is the black one? I have a light blue skin like that. It's floppy and heavy, I was told it was goatskin.
  8. I will get the proper stuff dog but I'm itching to get on. It's only the glue on the needle I'm concerned with. If you look at the French seam above, the the two stitch lines are 5mm from the center I'll cut the tape around 12mm/15mm and those stitch lines will go through it so it can't move and then over that I'll be contact glueing some 0.7mm pigskin over the whole panel. It might turn out that it'll look ok if I leave the side stitches until after glueing the lining and then stitch through the lot in which case there's no need for extra reinforcing. Even the proper tape has to have some glue along the center to hold it in place for stitching. I've never done anything like this before and I'm loving the experimenting and the designing. It's going to be a gift so I'm not worried about the cuz asking for her money back.
  9. This might be pie in the sky and the first part needs a post all of it's own but what if these drone were armed with the kind of explosive that starved the fire of oxygen? A bit like Red Adair putting out an oil fire. I know there's the updraught and smoke to think about but might be feasable in the future.
  10. A lot of shops over here are still on holiday until Monday. Have looked online but haven't found it yet. I'm thinking "Duct tape" for now (don't know what you guys call it). It's sticky backed fabric but my only concern is will the glue stick to the needle/thread? I can't sew at light speed so it's not likely to get too warm. I guess I'll just have to suck it and see.
  11. I think you're right on both counts Tug but is this guy ever on a commission? I wouldn't buy a raffle ticket from someone that smarmy.
  12. So assuming you use the French seam, what do you reinforce with?
  13. Of course all of our hearts goes out to those in dire straits at this desperate time. I know hindsight is 20/20 but surely there should be mandatory firebreaks in places where there is even a slight possibility of this happening.-
  14. Yes, I love Cesars vids. He's a maestro around a sewing machine and he teaches very well considering he never says anything.
  15. Oh you silly man! You've inflicted hours of torture on yourself. I can feel the trepidation from here in the UK. Turning the volume up on the radio isn't gonna help. But if it helps, buying quality will never come back to bite ya and the price will be of no consequence a short time down the line. I think you've already made the decision so firm it up now in your head and then smile and enjoy the rest of the trip. Good luck.
  16. Ah yes! The skive. Forgot to mention I don't have one.With the amount of edges I'm talking about I'm not about to do it manually. Plus the leather is soft. This is the main reason I came up with this idea because the skins I have here are only .75 and 1mm thick so doable. The glued on pigskin idea is to cover the seams and to ensure that it's strong enough. Some kind of edge skiver might be on the cards for the future. Any recommendations for something that's not Mickey Mouse and not an arm and a leg?
  17. My cuz has asked me to make her a largish tote and as I have a few coloured skins I thought I'd experiment with making the front and back panels using patchwork or strips. This brings two questions, what method of joining would be strong enough and which has more bulk on the inside. I'm thinking of glueing some pigskin on the inside to cover. I've forgotten the proper name for them but there's this one which has both seams on the one side and so is bulky but strong with two rows of stitches.... Or there's this one which I think looks better but the two seams are splayed out on both sides and so the side stitches are only decorative and don't add any strength. This means a reinforcing strip has to be used behind to maintain strength. This way uses three rows of stitches versus two for the other one but this one even with the reinforcing tape is less bulky. Have I missed an obvious alternative?
  18. Thanks for that Dog. You've cleared up a few points for me which is unusual because I read and learn a lot. I think some of the confusion comes from the likes of ebay and some suppliers when they list all the designations for one item just to suit the search engines. I couldn't find any neon or flouro on either of those link you gave. Mind you i only looked in the search boxes which are sometimes not comprehensive.
  19. Looks really good to me Tim. Well done.
  20. I believe this is what's called a double welting foot Folker. Can this be used as a piping foot? I don't have any here yet else I'd have already tried it. Or would it be better to use a cut away zipper foot in the absence of a proper job?
  21. Update! These are now on Ebay if someone wants to bag a bargain. https://www.ebay.co.uk/itm/274179684331
  22. Anyone know where I might get one? Preferably one that doesn't require a mortgage. Thanks guys.
  23. Still haven't got my head around this thread lark. Waxed polyester? Bonded nylon? Cotton? Does anyone know where to get the neon threads from preferably in tkt 20/30? Thanks guys.
  24. This technique is quite popular for camouflaging rifles and scopes. Love it.
