toxo
Contributing Member
Everything posted by toxo
  1. Will this cheapo be ok for a newbie with a hobby? Probably one or two projects a month for belt and edge skiving? https://www.ebay.co.uk/itm/Splitter-Set-Cutter-Skiver-Aluminum-Craft-Leather-Metal-Machine-Paring-Kit-Edge/401795252129?hash=item5d8cdcffa1:g:3QkAAOSw8BNdEZ9A
  2. I think it's a long handled fruit picker that should have a spring in the jaws and a string in the bottom hole.
  3. Thanks guys! There are it seems many versions and of course vanity comes into it. I'll have to get her to choose. No good making something she won't wear.
  4. She won't carry a handbag. Any good patterns around? She also has back problems and was gonna make her a support belt. I suppose combining the two would be overkill?
  5. I'll just throw this out there for what it's worth. I've used "Gorilla" glue a couple of times. It works on moisture so the work has to be dampened. Don't know how flexible it is but for stickability on leather I can vouch for it's effectiveness after I weighed down the work with some books but inadvertently moved the work. Next day I had to cut the leather to get it apart. Doh! Have plenty of clamps now.
  6. A very good summary.
  7. Are the patterns in ASs download ready to be printed the same way that Nigels are?
  8. I'm a complete newbie and I might have it all wrong but I've been striving to get the stitch line as close to "the work" as possible.If a seam is say 1/4 inch wide and the stitch line is 1/8th then you have 1/8th of the seam relying on a glue line, that's if glue has been used. If not surely there's a potential for stretch
  9. Plus one! The OP is just a whippersnapper. (Looked peculiar writing that. Wonder where it came from?)
  10. Great inspiring work for a newbie such as myself. Well done.
  11. toxo
    Radio Holders
    I like this a lot. I've been pondering how to make a pouch for my night vision and this is just right. One piece from the front lip all the way around and up to include the front flap. Thank you. Looks good by the way.
  12. I was experimenting to see how much I could cut out hand stitching with a ground down outer foot. I was feeling quite pleased with myself at a plan coming together. - Then I broke the bobbin case. :(
  13. Thank you Folker. Once again you come to my rescue. Let me know the cost.
  14. Don't know how I managed it but the center post of the bobbin carrier on my Durkopp 239 has snapped off. Can someone tell me what models are compatible and where I might find a replacement please? Thanks.
  15. Thanks guys. Appreciate all these little gems of information. This is the stuff the books don't tell you.
  16. So glad mine is working now. I would have had nowhere to put em. Well spotted.
  17. Looks good to me. I've just recently found out that this stamping malarkey isn't as easy as some people make it look. Well done.
  18. Welcome and well done. Dunno about the learning bit, you could certainly teach me a thing or two.
  19. I think you've nailed it Mike. Just wanna get used to it now.
  20. I'll watch that shoe but sometimes it locks up and I can't move the hand wheel either way.
  21. Thanks Gymnast. As I explained earlier, the lower disc would sometimes lock up solid and I couldn't see why so I dismantled it and then I realised the purpose of the adjuster that's fixed to the machine (I think the thread was getting behind it). Then I realised it was to adjust the position of the spring. I altered that and things were a lot better. That's when I switched to TKT20 thread and a 140 needle and tried it on the leather. The main reason for trying to persevere with the M60 is firstly because I have a lot of it (anyone wanna swap some?) and secondly because I wanted a contrasting colour for the bottom thread when I was playing with the tension. The TKT20 and TKT40 that I have are both white. I've ordered some TKT20 in another colour. This has been going on for a long time. I took it to two "repair" shops who said they couldn't do it. I've changed parts on it and every time something didn't work I had to get away from it until the enthusiasm came back. Now that I know (With the grateful help of you guys on here) it wasn't all in vain I'm really happy and can actually think about projects to do with it.
  22. Thanks guys. kgg, haven't thought about that for a long time. Have seen vids threaded this way and started off with fewer holes but nothing seemed to work. Have since changed the whole tension unit so definitely will look at that again. Constabulary, have been using the back hook since you told me about it but the thread was still jumping out and snagging on the knurled knob. It only seemed to work properly after I fiddled with the adjuster thing in back of the tension unit. Maybe I did something wrong when installing it but there were times when it just wouldn't pull through at all even with next to no tension. That disc is still a complete mystery to me but at least it's working now. The bit when, after you finish sewing and pull the work away is still a battle sometimes and I rock the wheel and sometimes it 's free and sometimes it just won't free up. Is there a trick to this or is it just fine tuning? Now I'm looking forward to playing with it. Constabulary, do you happen to know the size of the shaft on the Jack motor. I have a 40mm pulley I can put on if it's 15mm.
  23. You've done me again Mike! I've done just that a few times in the past. In fact I have an imgur account somewhere. (Don't think imgur does video) Here's the one breaking M60 tread. And then I dismantled the lower disc and had another fiddle. Things seemed to be better so I loaded up with TKT20 and a 140 needle and, hooray! I don't have to throw it away. Still a way to go with presser feet and tension and stitch length but I'm a lot happier now. https://youtu.be/g5bU5A38NbI
  24. After much trial and tribulation I have it sewing again with no shredding. It is still breaking thread, sometimes under the needle plate but more often at the lower tension disc. Can someone please explain how this disc is supposed to work? There seems to be no uniformity to the breakages, sometimes after an inch, sometimes after about eight inches but never more than that. I have taken a couple of videos but I don't have anything to get them below 1.4MB. What do you guys use?
