Everything posted by leatheroo
Pfaff 335 Manual For Older Version Needed
leatheroo replied to CaroCaro's topic in Leather Sewing Machines
pfaff335 parts.pdfpfaff adjustment.pdfhey all, i have an older 335 and i find these documents relevant to my machine...cheers -
From the album: Leatheroo
Hi all, here is a couple of round bags that i made. The big one measures 28cm and the small on 20cm. The small on has an inlay of emu leg. Hand sewn. Thanks for looking. Cheers
I had a request for a lawn bowls carrier. The customer wanted something to carry two bowls from end to end. Heres what i came up with. cheers and merry christmas
Pegasus Document Folder
leatheroo replied to leatheroo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
hi colt, yep the stitching on the left joins the two sides together. i was originally going to lace the left side, but cut to much leather off when trimming!!! -
Hi all Here is a small document folder that i have just finished. The original drawing was used with permission by the owner, Desiree Kerns at http://www.greyscalestudios.com I started by using this method http://leatherworker.net/forum/index.php?showtopic=54298&hl=transfers, to transfer the image to the leather. I used photoshop to convert the image to mostly line drawing. I left some of the shading in to help with the painting. Here you can see the image is now carved, using the transfer as a guide. Next i painted the pegasus with a mix of black, gold, copper, etc. Mostly acrylics mixed with black dye. The shiny paint makes for difficult photos and different lights cast different colors. Inside the folder Finished Document folder. Cheers thanks for looking caroline
First Five Leather Masks
leatheroo replied to LilyLionLabyrinth's topic in Books, Journals and Photo Albums
lily, do you have an airbrush... i couldn't live without mine. -
I use a slightly different method. I complete wet the top layer and mold it around the stone using fingers and bone folder. (I am using kangaroo for the top). After it is dry, i use contact cement, completely covering top and bottom pieces and glue together again using bone folder and fingers. I always make the top and bottom much bigger than i need and trim with a head knife to correct size later. After it is dry, i use a scalpel to cut out the middle section to reveal the stone. I find the polished stones don't get marked from the scalpel and this way the hole doesn't get stretched and glue is right up to the edge. I then trim and burnish edges. cheer caroline
great work, love the colour of the minotaur. -
wow, great work
Pfaff 335-17B S Journey To The Unknown!
leatheroo replied to jimi's topic in Leather Sewing Machines
pfaff335 parts.pdfpfaff adjustment.pdfba_335_06-09_e.pdf these might help cheers -
such an impressive tutorial...very generous, very detailed...many thanks.
- 15 replies
Cylinder Arm Table Attachment That Converts To Flatbed?
leatheroo replied to mcfingrs's topic in Leather Sewing Machines
My pfaff 335 came with a homemade attachment when i bought it. It works GREAT. You don't need a really close fit...the leather is not going to fall down a 1/4 gap. The cut out bit measures 9 inches on mine. cheers caroline -
Lefflers are the main place to see in Melbourne, allow a couple of hours....big place. Ballarat, an hour away has a nice little tannery also. http://www.leffler.com.au http://www.gretannery.com.au have fun
Ok, i admit i don't measure at all....just eyeball and punch. Round holes are stronger. cheers
Leather Perforation, Not Many Answers Out There
leatheroo replied to tparrish's topic in How Do I Do That?
You could try sewing machine with very large needle and no thread.....makes for nice even holes...not sure about the crosses. Gotz make brogueing punches but are very expensive, they are in their catalogue under tools. cheers -
I had this problem.....i had the needle facing the wrong way!!!
So i have been buying poly thread from the thread exchange because i can't work out the aussie thread sizing system. I have spent many hours researching this, but i can't seem to find a plain answer anywhere. I know i what to buy US size 69 and 138 thread and the thread exchange has a nice chart for thread size to needle size. I found Anne Bonnys Locker selling 40 ticket thread that says is equivalent to #69 so that gives me some idea. Can anyone tell me the equivalent aussie sizing or point me to a conversion chart that makes sense? cheers and thanks caroline
