Everything posted by Colt W Knight
Yeah, its got an added pedal for the reverse. It works just fine. I would rather have a machine that had lever you could just flip for forward and reverse.
<iframe width="560" height="315" src="https://www.youtube.com/embed/ojhh3gJr2KM" frameborder="0" allowfullscreen></iframe> http://youtu.be/ojhh3gJr2KM
I wouldn't run that machine with no oil, you don't want to scald the bushings and shafts. Ill post a vid of oiling points
Here ya go That wick looks really dry, how much oil is in the machine?
Those links aren't working for me.
I have a hair tool, but I don't think it would work that well for wood grain.
looks great
Looks like hardwork ( by a good artist) with swivel knife, modeling spoon, and a few bevelers to me. that eyeball and the wood grain look great.
Mine falls in the same hole in reverse.
When I back my thread length all the way back, I can get 4.33 SPI. So looks like about the same as your machine.
Let me check
I really like my Craft Tool Pro line swivel knives, and some of my stamps from tandy work really well. The Al stohlman maul is working well for me to. Lotta crap from there though. When I first got into leather crafting, I could go to the local tandy store and buy relatively inexpensive good quality leather. Over the last two years, my local store has quit stocking "acceptable" grade tooling leather, and the prices have nearly doubled. Im at the point now where I only go to tandy for buckles, conchoes, gromets and dye.
Those hand held shears only worked if they were razor sharp. They did use stones. Its a miserable job with motorized clippers, I couldn't imagine doing very many with those hand shears.
Glad to hear your clipper aren't gettting hot. Wahl and Oster both good heavy duty clippers and they typically market to Home Users, Barbers, Livestock folks, and pet folks. The barber and livestock models are generally the same bodies ( but they market them as different) The real difference is the blades made for people are finer and the blades for livestock accomodate the thicker hair better. When we trim livestock and sheep, we have to contend with natural oils and dirt on the animals, and they dull very quickly. Human blades typically wont last through one job. Sheep shearers go through so many blades while shearing they carry their own sharpening station.
How do you keep the trimmer cool in a production setting? When we shear sheep we actually have to use shaft driven shears. Are your clipper blades designed for people or animals? The ones designed for animals will perform a lot better on that wool than people ones.
Is your adjustment knob on the reverse lever loose? I can get about 5-6spi on my consew 206rb1
Love Arther's videos
On all my leather punches, I have started "dipping" them in beeswax before punching. Tools really like to get stuck in thick leather, and the beeswax makes it easier to removes and keeps them sharper longer. It also prevents bending tools because you don't have to wiggle and pry them out of the leather. I have a chunk of beeswax I keep on my table, and before I punch something, I just dab the tool into the wax. Ultimately, if you want the best stitching holes and uniformity, I would move to using quality pricking irons and a sharp/polished diamond awl. I got tired of hand stitching and bought a sewing machine. Hand stitching yields better results, but in the grand scheme of things, I don't think many people care about the difference between well done hand stitching and well done machine stitching.
I couldn't say because I don't have any experience with them. Now that I have a sewing machine, I don't use these chisels as much anymore.
Homemade Modified Arbor Press For Border Stamping. Video Link.
Colt W Knight replied to Tallbald's topic in Leather Tools
I have been thinking about making a similar setup for a while so I could border stamp at night without a noise issue. Thanks for the post. -
The prongs on my Tandy chisels bent when I was working on larger projects. Once they bent, they lost what little strength they had and became worthless. I am also over Tandy Tools. The holes are big for 2 reasons. 1) They are cheap tools and need the extra metal for strength 2) The bigger holes are easier to pull a needle and thread through.
I waited for almost a year before I found an affordable used machine. They pop up, but not frequently.Once you have a machine, you realize they are worth it!
Thanks Bill , I learned a lot about dyes and painting building custom guitars. Whenever you mix products - I cant emphasize TEST OF SCRAP first enough. Even when you don't mix products, you still need practice to get your thinning ratios and applications just right to where you can get good results. Folk who are new to these things don't understand how they work, and are usually disappointed when they start using more than one product on the same project. Hobby stores always make their products out to be better than they really are.
I am having a little trouble following your process. Why did you apply super sheene, then wipe it off with a wet sponge? Here is how I do it 1). Case the leather - while its wet I give it a once over with saddle soap to clean - most leather is really dirty and has oily residue 2). Tool - let dry 3). light coat of neats foot oil - let dry 12-24 hours 4). Apply dyes - let dry thoroughly 5). Apply a couple light coats of clear/resist - let dry 6). apply several light coats of color ( acrylic )- let dry 7). Apply a couple light coats of clear/resist 8). Apply antique gel to highlight all the tooling - let dry 9). Apply several light coats of clear. When you apply stain, it needs to be applied to clean dry leather, and once its dry and has enough coats to get the color saturation you need, you need to put some clear or resist on it to keep the dyes and antiques from bleeding into the color. If you are going to brush on the clear/resist - you need to do so in such a manner as you are not wiping away the stain/color. Spraying is the only way I have been able to accomplish this. I finally broke down and bought an inexpensive airbrush. You can do it without an airbrush, but expect to get a little color bleed.
Can you post a picture?
