Everything posted by Colt W Knight
Holster Sewing Machine Questions
Colt W Knight replied to cleanview's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I change mine before every big project, and about every 4-5 little projects. As someone pointed out above, they are a relatively cheap expense in the expensive world of leather working. When I first started sewing, I would go too long between needle changes, and things would always go wrong like: frayed thread, skipped stitches, and these things lead to other problems like the feed dog hanging up the thread and changing your stitch length or pulling your work from the center line or just plain breaking the needle. -
Preparing Leather For Tooling Even Before Casing
Colt W Knight replied to whimsicaldragon's topic in How Do I Do That?
I dunk my leather in water and give it a rinse. Then I clean it with saddle soap. Then I let it sit out for while for the casing process. On some projects, I use a glass slicker to kinda prestretch and give the leather a smoother appearence. The rinsing and cleaning seem to be more important when I use cheaper leather like the stuff I get at Tandy because it seems to be pretty nasty. -
Techsew 2700 Vs Consew 206Rb-5?
Colt W Knight replied to Northman's topic in Leather Sewing Machines
How does the 441 clone do on light material? -
I have a consew 206rb and its a great machine. However, the Techsew is a cylinder arm machine, and that is way more versatile for sewing hard to reach places like bags and zippers. -
Second Purse
Colt W Knight replied to Colt W Knight's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks yall -
A friend asked me to help her fix up and clean an old elephant hide saddle she aquired. Does anyone have any information about the maker? ROSS WESTERN, Wichita Kansas Wonderful saddle. I helped her fix a few rips and tears. Stitched some of the cinches, made a new cinch, polished the silver conchos ( made in england) and add some new straps). Oh yeah, We also gave it a good scrubbing and oiling. Beautiful saddle. I wish it were mine. Unfortunately, along its lifespan, someone spilled some nasty junk on the seat. It has penetrated through the entire thickness of the seat leather, and made the leather "goey" in places, and brittle in others. This repair is beyond my abilities. Such a fine saddle like this doesn't need an amateur hacking aways at the seat to replace the seude.
Really Bad Problems With Fiebings Oil Dye
Colt W Knight replied to bylinesupplyco's topic in How Do I Do That?
Did you c lean the leather with saddle soap before dying? Did you oil before dying? Was the leather still damp when you dipped? In my limited experience I got those spots if I didn't clean my leather prior to dying, or I oiled too heavily or didn't wait over night after oilin befire dying. I've also noticed that if I was impatient and dyed before the leather was completely dry. It has always buffed off though. If I didnt get good dye penetration after buffing, I clean with saddle soap, let dry, and redye. -
I also use Murphys Oil soap to clean horse tack. If its really nasty, I will make up a bucket of warm soapy water, dunk the tack, and scrub it with a stiff brush. Once it dries, I apply leather conditioner. Lots of products available. I avoid vegetable oil because they can go rancid over time. I oil all my tack with Extra Virgin Olive Oil because I don't care for feedstore/tack store neatsfoot oil.
Second Purse
Thank you. -
I put it on an ironing board, and iron it. Also works good to crease edges over for easier sewing. Just did it yesterday.
I made my mother a purse, and everyone seemed to like it, so I used the left over material to make one for the Arizona Cattle Growers benefit auction this week Soft red leather bag, cloth lined, with ostrich strap and trim.
Swing guides are expensive for the 206, but it would be nice to simply swing it out of the way. Uwe, have you experienced the material wanting to jam up against the spring loaded edge guide when you sew thick leather? I
This is what I have on my Consew 206rb-1 Bob Kovar from Toledo Industrial Sewing Machines sold it to me for a few dollars. You have play with position to get the hang of using it correctly or it will cause jumped stitches, but once you figure it out you can sew a belt or purse strap with the roller touching the inside presser foot as quick as you want to sew. I just did a 42" purse strap this morning. Took me longer to do the lock stitches than it took to sew down both sides. Ive found that I need to put the center of the roller even with the needle, and then I feed my work in from a slight angle .
How does one go about ordering direct from the tannery, do you have to place large orders?
I should have clarified the difference in the original post. Spray can clear coat designed for leather is completely different than the clear enamel and lacquer you buy at the store for 3-4$ a can.
What it looks like to me is a dry veg tan leather thar was coated with a matte or satin enamel. Then bent to crack the finish and the leather. I've done the same thing on my guitar straps ( by accident). Never had any finish peel off before. I quit using rattle can clear coat (stuff you buy at the hardware store or lowes) because of how it cracks.
How To Do A English Point Useing A Round Knife
Colt W Knight replied to gmace99's topic in How Do I Do That?
I have one English point chisel I bought from weaver when I made 30 GPS trackin g collars. Great tool that saved me a lot of time. However, they are very expensive, and I can't justify buying one for all the different size straps I make. The method you demonstrated is awesome, thanks so much. -
Suggestions Needed For Pouch Flap Fastener
Colt W Knight replied to bigstripe's topic in How Do I Do That?
http://www.tandyleather.com/en-usd/product/button-stud-11310-007.aspx Traditionally, I have seen these button studs on similar design pouches. If you wanted more mechanical solution, numerous style clasps are available. -
You can spray a heavy coat of rattle can clear coat ( enamel or lacquer). Let dry completely, then bend it tightly ( roll it up tightly both ways) and the finish will crack.
