Everything posted by BDAZ
I believe Wyoming Slick posted some interesting links to the dangers of using saddle soap a few days ago. One of the issues is that it is very alkaline and will alter the PH of the leather. My question is; Will saddle soap neutralize vinegaroon eliminating the baking soda step with something more productive? Thanks! Bob
I picked up some Aussie at Tandy this morning. I first asked what they recommend for a natural finish and Aussie was unanimous. I picked up a can and used it on a prototype I am working on. It's baking in the sun but at first glance looks great! Thanks for the tip. Cya! Bob
- 14 replies
I was able to play Sunday and I am heading out tonight. Carrying the instruments is tougher than playing! Great excuse for not carting PA equipment! I wonder how long I can milk it?! Thanks! Bob
No time to get to Tandy so I used Super Sheen and it did a good job. A bit too shiney for my taste but I am sue the customer will be happy. Thanks for the input. BTW I was wet forming a black case in the sun and measured the surface temperature...145F Cya! Bob
- 14 replies
There's another chappie from Paarl on the forum as well. Dip dye some buffalo scraps and see if the white stuff appears. Then it's probably not salt which is not soluble in solvents Then dip in water. Either way I wouldn't trust it! Totsiens! Bob
The black wet formed leather can get pretty hot! Helps set it up and hardens really well. Cya! Bob
- 14 replies
No need for hair dryers here. Wet forming takes about 20 minuets to dry. I'll probably give it a shot. I'll bring it along. My guys are pretty knowledgeable too and more interested in the customer than the sale! Cya! Bob
- 14 replies
Thanks! I was just about to edit my question because I found it at the Tandy web site. I did a search on the stuff and it sounds interesting. Could I apply it and then deliver the product a few hours later or does it need to settle in? It going over 100F tomorrow so that may help? Thanks! Bob
- 14 replies
Do they sell it at Tandy?? What's the full name? Thanks! Bob
- 14 replies
I have just finished a case and the customer wants the leather as light as possible. It's been wet formed and lightly oiled with neatsfoot and dried in the sun and has darkened just enough. I have a bunch of options but I want to get a natural sheen on the leather and tooling without darkening it or making it look tacky. Options are Resolene, Mop and Glo, Leather Sheen, Super Sheen and Atom Wax. I could also make a run to Tandy if anyone has a killer product they recommend. I have to deliver the case tomorrow and if I can get the right finish, they will love it. I don't have time to experiment. Thanks! Bob
- 14 replies
Howzit! Here in Arizona, it's a bit like the Karoo and the water has a lot of minerals. I only use distilled water for wet forming carving and stamping. If your white stuff is only on one of the typesof leathers, say the buffalo, then it may be salts from the tanning process leaching out. Are you using water based or solvent based dyes? Do you have these issues with your spray gun? BTW I was a lecturer at Michaelis for many years, originally from Joeys. Cheers! Bob
I am still waiting for my pots and connectors to arrive. The pot mod is mostly about controlling speed between 0 and 60 SPM. I have ordered connectors, leads and pots from China so I can test various components and produce a "plug and play" configuration. I'm hoping to get my components this week. Bob
Not to highjack this thread but I hope you guys can help. I suffered a serious bicycle crash last Saturday. I skidded on some sand and slammed into an iron pedestrian bridge at 20mph. I lost consciousness and I spent the rest of the day in the trauma unit. I was was lucky to have no broken bones, only a separated shoulder. The guys who scraped me off the pavement were kind enough to take my bike back to the fire station. I'd like to make something out of leather as a thank you but I have no ideas what so ever. Any suggestions would be most appreciated. Cya! Bob
On mine it is a 220K pot connected to a connector on the board. The initial problem was setting the maximum speed more accurately since only a few degrees of rotation of the pot results in the full range of required top speed. So both mods should result in much better control of the motor. Thanks! Bob
The speed control IS a 220K linear pot and changing the value to a 100K log pot WILL achieve the desired effect but your system may enhance the effect assuming there is a magnetic sensor on the motor. Cya! Bob
I ended up skyving down the spongy part and gluing in a piece of 3oz veg tan and then stitching. On the back side, as an experiment, I glued and stitched in a piece of nylon ripstop, which made for a thinner loop. I did some tests on a similar piece and the nylon looks like a good solution. I used a hot knife to trim it so it won't fray. Barge seems to hold the nylon to the flesh side well. Cya! Bob
Don't get me wrong, I think the strap is killer but even a slight translucent red in the roses would work better for me. I am a former fine arts professor so I guess I can't help going into critique mode. Again, fantastic job! Cya! Bob
I totally lucked out! I saw the ortho today and my rotator cuff is perfect. I suffered a separated shoulder and I just need to avoid anything that causes pain for 4-6 weeks. I was told that traumatic rotator cuff damage rarely ends well. Thanks for all the information and encouragement! Bob
I'd love to be buried in a case like that! Stunning! Was it a commission of favor? If commercial, what did you charge if I may ask? Whatever it was it's far less than it's worth! Thanks! Bob
Wonderful concept, great products and excellent web site. If I were you guys, I'd also look at a facility in PR. Lots of incentives, good labor and $$.. Cya! Bob
Thanks! I have a meet with the ortho tomorrow.. The pic attached is my good shoulder that hit the bridge. I ten bounced off the bridge and slammed the pavement with my right shoulder...which is where the main problem seems to be.. By changing the way I hold my tools I have been able to work cutting, tooling and sewing, but it's tough reaching for items on the shelves and I am doing things with my left hand it's never done before heh heh.. Cya! Bob
Beautiful carving. What strikes me as odd, is that you have colored the leaves but not the roses, so the eye tends to gravitate to the leaves and it almost looks unfinished to my eye. I would have at least some color in the roses and used moe of a wash on the leaves. Cya! Bob
Part 2 What Are These Tools Called And What Are They Used For?
BDAZ replied to jmkjmk2's topic in Leather Tools
The last one looks like a fret saw used for cutting slots on an instrument fretboard. Cya! Bob -
WS, you are absolutely correct. I totally missed that. Thanks! Bob
Macca. Have you actually tested your "theory" or is it pure speculations. I just tested some pricking irons on a suitable poundo board with a TWO ton press on 9/10 oz leather with ABSOLUTELY NO PROBLEMS! The only issue will be that the 1/2 ton press does not have the clearance for a standard pricking iron handle, nor does the one ton. Consequently you will have to trim the handle or purchase one with or have the ram modified with a hole bored to accommodate the handle. A small set screw would keep the iron in the ram. I think it's an excellent alternative to eviction. Also great for cracking nuts! Cya Bob
